- Wheels for the winter
- LED Taillights.
- I'm looking for a wing for an EM2 for my BF---HELP!!!!
- strang
- engine swap
- if you know about suspension call me now please!
- Cracked manifold....Should i just get a Header and high flow Cat
- 2001 civic Suspension Popping
- Does RSX door panels fit EM2?
- Air flow problem 2001 civic, please help!!
- 2001 Honda Civic Starting Issue
- Skunk2 nightmare, poor exhaust fitting.
- clutch linkage problem... help.
- motor and tranny swap
- Where is the illumination for fogs?
- rubbing/grinding noise?
- fits a k20 in a em2 - need infos
- Transmission swap
- 05 leather steering wheel in 01
- DIY Timing belt kit
- towing ninja 636
- warranty question?
- Overheating!! -Adding coolant help.
- Lip
- HELP AND OPINION ON MAKING A DECISION WITH MY EM2
- HELP!!!!!! 2001 - 2004 Civic Ex Auto Trannys.
- Front Sway Bar - ST Suspensions
- 05 cluster in a 01
- HID and Projector headlight
- 2008 accord
- abs light on, hazards & brake lights not working.
- Weird Noise from Timing Belt?
- starter
- Is 6500 enough to do a kswap in a automatic vp going manual
- Brake fluid amount
- need opinion on struts/shocks: 2 of mine jus blown
- Fuel Managment...
- steering wheel emblem on si
- In the market...
- Steering noise?
- rbc k20
- Steering Wheel Shakes
- Squeaky sound..?
- sway bars.
- Help Me Understand!!!
- How much is a head swap
- grinding drivers side front???? help...
- Hood Ratles at high Speeds
- blower transistor issue
- Factory Service Manual
- Power lock not working
- 02 Civic LX Auto. tranny shifts hard
- LX Cat??
- Anyone heard of Tsudo????
- Jacking points on a 03 Civic EX Coupe
- valve clearance info help please asap
- EDFC Unit for Tein SS - Need some info please!
- transmission question
- SUSPENSION...HELP! for 03' civic EX
- weird noise
- pleaseeeeeee help.
- i need a good exhaust manifold gasket for my turbo civic
- 02 cupe HX?
- New Guy Here
- car randomly turning off and on
- my first official run
- Power Steering Noise
- [Searched] Window Visors
- Problem List / Crap Engineering List - 7th Gen
- neuspeed bar
- 2002LX.. please help???
- Pics of my EM2
- 2001 LX parts
- Thinking of trading in the 04' EX for the 07' Civic Si
- In car computer
- Thoughts about megan coilovers.
- oem retrofit
- HKS Hi Power Exhaust Question
- timing belt problem
- transmisson
- Unlock Radio Code for CIVIC 2005
- New picts of the civic
- boomslag wire harness?
- Rev limited to Vtec RPM
- SRR Purple LCA
- Grillz
- Pic Request: White rims on silver em2
- Where to get a rear C-Pillar for the EM2? help
- valve adjustment for 02' coupe model ex
- sprint hart CPR or the wheels i got...need honest opinions (smart asses dont reply)
- used exhaust
- Maint req'd light ON
- OIL PANS............
- 05 sedan-fogs, sidemarkers
- Sunroof wont close all the way !
- 01 - 05 civic transmission petition!
- How many ES1 are in here?
- cant alien front shock bolt holes with brake bolt holes?
- UGH THE PROBLEMS KEEP COMING!!!
- Center Console Armrest available??
- clicking/slapping when you break
- DC5 pedals in an EM2
- looking for your opinion here
- simota
- ABS computer jumper location
- info on a h22 swap into civic
- engine light is on!/maintenace required is on(HELP)
- car starts and runs but dies while driving then starts again
- Axle Nut
- Outlet size of AEM short ram on 03 civic ex
- Whats the difference between DX/LX/HX/EX ?
- Recent EM2 problems, confirmation on my thoughts?
- why is my 2005 civic coupe sitting crooked?
- Neutral Safety Switch
- projector headlight help (angel light) (halo)
- Got new 265/70/16's... and they fit!?!?!?
- what do you guys think about this grill.
- Appreciate some help with my car.
- 2004 civic ex stock wanting to go turbo HELP
- Changing Interior Lights
- Uploading Pics
- Fuel Pump and Filter Replacement
- Apex and skunk 2 exhaust for a civic LX?
- new w/ a question
- What are ur jobs and how many hours a week do you work....
- Radio Problem
- DYNO SHEET AFTER BUILD!!
- Rota Grids
- 04-05 taillight on an 01-03
- What is you favorite hobby?
- Shift boot
- Your age...?
- I need ideas for my 2001 black Honda Civic LX (4-door)
- Block heaters
- DIY for shock/struts installation
- thorttle body size?
- dc5 5 lug
- 1.8 SOHC?
- HID's not wrking...
- Revo SS + RSX knob = awesome
- What rear camber kit is this?
- progress swaybar kit w/built in tie bar
- location photo shoot?
- can water get into the fresh air vents?
- OBD2 TO OBD1!?
- anyone have this rear lip?
- K20 group
- 01 LX Oil Problem
- Finally some pictures of the beast (56k warning)
- rotors
- Please Give a Warm Welcome to the New EM2.
- Concerning nitrous...
- EVAP problem
- final decision time, opinions please
- catalyst efficiency below threshold....
- Still have a crappy whistle sound at cold start up
- Skunk2 VS Buddy club
- k20a vs k20a2
- 2002 Civic EX Headlight Switch
- aero skirts do not fit
- strut spring scrape
- help with ball joint
- Exhaust Choices
- boost or k20?
- JRSC d17?
- return fuel line
- brakes noise
- Buying Used Lowering Springs?
- Fuel return line
- boost question
- 01 civic tail light/ gauge/ fuse problem
- dc5 seats?
- Anybody own a CRV?
- exhaust bolts, help!
- B16 swap.
- Honda Civic 2002 EX HeadLight Problem
- What type of spark plugs?
- tein h techs
- Anyone have ebay LED taillights?
- Rear bumpber 2003 civic lx (canadian)
- Civic vibration
- 2003 Civic EX ignition (Performance)
- Front control arm bushing replacement
- CV Boot Replaceable?
- PROBLEM BACK AGAIN!!!!!!!!!!!!!!!!!!!!!02 civic ex a/t
- Pic Request / RS Rear Lip + Aftermarket Exhaust Issue
- eletrical?
- broken radio and door locks
- How do i make my car quieter?
- twm short shifter
- powertrain control module.....Blue wire???
- Boost Video For $$$
- One Headlight/Multiplex Unit Problem: '03 Civic
- Help with a brake problem
- Shock Sensor Question
- Blown head gasket?
- '02 Civic EX. RPM's and Acclerator - strange behavior
- Camber Kit
- Radio Question
- NOZ IN D17A2!?!?!?
- where can i get these fogs and lip
- I NEED HELP ASAP!!!!!
- 01-05 honda civic turbo kit ***NEW***
- OEM fog switch + ebay kit
- K Swap into EM2
- hey where can i find a asr subframe for our cars
- Valve adjustment
- Rsx 02-04 suspension
- DC5 to EM2 dash conversion
- folding mirrors
- for those people with em2 emblems
- ► 7th Generation Civic General Chat
- Question about 17" volk racing rays c-ultra forged rims
- OT: Where does everyone live?
- Anyone know where to get this EM2 emblem???
- Drum to disc conversion problems
- Gauge pod in your cluster
- RPM gauge not working
- HID KT
- what should i do when i get my car
- lol please help
- some goodies for you ht peeps
- knocking/ tapping at low throttle
- suspension help
- 24mm rear sway bar? anybody running one?
- 04 Civic Headlight Adjustment (Searched Already)
- 01 civic cruise control??
- What wheels should I go with for my 2001 Civic coupe?
- How to: EP3 steering wheel into EM2
- BEWWWWWST!!!
- HELP GAUGE PROB!
- T3 Turbo
- k20a3 for $150
- disk brakes from a CRV
- Eibach Anti-Roll Bar Kits
- 04-05 Civic EX center cap?
- parking sensor problem
- My 02 Civic is Overheating
- one side of my rear is lower than the other
- "Low Clearence" Sticker: Does Anyone Know Where To Get One?
- ballast placement
- ► FAQ's and Guidelines - READ BEFORE POSTING!
- Need help with aux stereo installation
- mini me
- 01 Civic Sedan LX- Engine Swaps?
- RSX-S 5lug conversion question
- amp wire
- steering wheel hub
- I installed a factory radion and it was easy.... a question though????
- Where can I buy this rear lip for Sedan?
