PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. new to me car. no start, coolant blown out of radiator.
  2. Temperature guage almost reaches Hot when idling
  3. Power steering fluid OEM brand
  4. Camshaft pulley bolt replacement
  5. DLC connector not communicating
  6. How to remove plastic panel
  7. Got an interesting problem on a 02 Civic
  8. Redundant timing belt replacement
  9. 2002 CIVIC SiR hatchback
  10. 03 Civic Radio Switch, Harness Radio Not Clear. please help
  11. EP3 with a few problems. Need help.
  12. Engine computer
  13. Door Lock Issue
  14. A/C Head Scratcher - SOLVED
  15. Transmission swap
  16. Ep3 6spd swap help me! Lol
  17. Civic 2001 gauges went off and now car won’t start
  18. AC stops cooling
  19. Alt plug wiring
  20. 03 Civic fan problem
  21. Bypass immobilizer
  22. suspension bushing kit 2001 honda civic
  23. 05 Si hatchback misfires
  24. Is the 2001-2005 Honda Civic a generation I should modify and daily drive?
  25. New valve cover gasket leaks
  26. 2003 good battery no crank
  27. 2005 civic clicking noise when driving low rpm
  28. 05 civic Water pump bolt sizes
  29. 2002 Civic DX ignition key alarm and intermitant wiper out
  30. 04/05 front sway bars
  31. 2002 DX instrument lights out
  32. 2005 Civic DX Power Steering Questions
  33. 2002 Civic SI - Engine denomination
  34. 2003 Civic Ex overheating
  35. Maybe speakers aren't blown
  36. Under the hood insulation pad
  37. 2004 Manual Transmission Help
  38. cooling issue
  39. 02 Civic flywheel coming apart?
  40. Radio install
  41. 02 Civic EX fuel pump issues
  42. Time-Sert question
  43. 02 civic ex coupe heat/ac not blowing dials dont work
  44. '03 Civic Hybrid electrical issue?
  45. Anyone have info on 05 civic vp interchangeable with other makes and or models?
  46. no power at A/C compressor
  47. Wheel spacers
  48. Help with lambda probe on d16v1
  49. F (12P) under-dash connector location
  50. HELP!!!
  51. 2005 Civic Lx Special Edition
  52. 2004 Honda Civic LX automatic - Smoke from under hood
  53. long crank before car starts
  54. Engine bay squeak when first minute car starts often
  55. Car wiring issue 2005 honda civic dx
  56. Dashboard wiring diagram
  57. 2003 Honda civic lx engine upgrade
  58. Bmxa trans assembly instructions
  59. 04 honda civic passenger rear door handle replacement
  60. 2002 civic lx 4dr - gauge cluster lights partially out. Bulb issue or fuse issue!
  61. Flood damage inquiry
  62. is my dashboard shot?
  63. Oil leak 2002 Honda Civic
  64. P0505 - I'm Stumped
  65. Annoying noise
  66. Anyone knows about this little device on my Honda Civic 2004?
  67. d17 hunting idle update new problem need help
  68. 2004 honda civic EX
  69. 05 EX Tricky Missfire
  70. 2003 EX exhaust system brand recommendations
  71. Part in between coil on plug.
  72. d17 hunting idle ( back story)
  73. 03 civic ex rpm drop slightly and engine noise when using accessories
  74. Nagging ECM issue, someone must know.
  75. Need engine
  76. High idle 2k rpm 05 lx
  77. 2003 Civic Hood latch mounting bolts size?
  78. 2004 Honda Civic VTech head gasket replacement
  79. Ignition switch swap
  80. 2005 Civic K24 Swap AT chassis to MT - wont start
  81. grounds
  82. 2003 honda civic Si 2.0L. replace the engine, crank no start. P1361
  83. Honda Civic 2002 Intermittent camshaft position error.
  84. EVAP Code trouble
  85. ECM plug and play
  86. 2002 Honda Civic ex engine light on and code PO128 on acanner
  87. Honda Civic mk7 ABS sensor diagnosing.
  88. 2002 Honda civic lx no start confusion
  89. EP3 Lower Control Arms Ect.
  90. Green Key flashing while driving now won't start
  91. honda civic 2001 resonator box removal
  92. EP1 door panel removal, help
  93. Manifold
  94. 2002 civic ex won't start in cold
  95. 2002 honda civic belt covers
  96. I need help diagnosing a problem
  97. 2003 Honda Civic LX Sedan Replaced Both Front Door Speakers & Starter
  98. Water accumulation in spare tire well in trunk
  99. VERIFY MY KNOWLEDGE ECM Swap
  100. 2004 Civic Overheating = maddening
  101. 2003 Honda Civic LX 5 speed 1.7L
  102. 2002 Honda Civic Drifting/pulling and shaking wheel
  103. Immobilizer issues
  104. Civic Lowering springs on a 2002 Crv
  105. CV Axle Boot
  106. Drum wheel cylinder
  107. New cat is too short?
  108. Rattling noise when accelerating/shifting and when let foot off gas
  109. Looking for a rebuild manual/book
  110. Ep2 brake issue
  111. 2004 Honda EX, Manual, Cruise control
  112. replacing brake line on 2001 Honda Civic
  113. 04-05 civic coupe hood on sedan
  114. A1 to A2 swap
  115. d16w7 tuning
  116. 05 civic dx rough idle/ stalling at low rpm
  117. Given different harmonic balancer with long woodruff pin?
  118. How do you adjust the timing belt? (TOO TIGHT)
  119. A1 to A2 swap
  120. Saying hey, questioning what do to with my Si..
  121. Very bad vibration/shaking after 5 lug swap @80mph
  122. If hybrid pack tests ok, what else could it be? Opinions needed.
  123. 2003 Civic GLI Fan Issues
  124. Gas smell after putting a cold air intake
  125. 2002 Civic DX: Never ending air in brake lines
  126. 2004 Honda Civic VP will not start
  127. '05 Civic VP Green Key light / Starts every other time
  128. ECU Replacement
  129. Caked up stuff in my coolant expansion tank
  130. CRACK INSIDE RADIATOR OR PIPE???
  131. 03 acura el p1259 vtec code
  132. D17a2 block
  133. Bmxa rebuild kit
  134. 2003 Honda Civic LX Sedan Advice for a Non-Mechanic
  135. issue with third gear
  136. Em2 brake problems, soft pedal, no e brake
  137. 04 Civic EX 1.7L Sedan -- Catalytic converter stolen :(
  138. Lean misfire under 3k rpm
  139. 2002 Civic LX with D17A Singing engine...
  140. Honda Civic alternator fuse#4 is grounded out possibly short somewhere?
  141. P740 error code options
  142. P1361 code
  143. Honda Civic 2002 strange OBDII pinout.
  144. 2001 Engine Upgrade
  145. Won’t start after thermostat and fan switch VIDEO/pic
  146. 2005 Civic- P1129 MAP Sensor (Higher Than Expected)
  147. 2002 honda civic weird issue
  148. Strange Voltage Issue
  149. Honda Civic Si ‘02 Hatchback windshield
  150. 2001 honda civic lx ac issues
  151. Honda Civic making noise when AC is on
  152. Airbag resistance values? SRS light 1-1 code... been at it a month
  153. 2001 Honda Civic ex p0730
  154. Lack of power and strange noise
  155. Can't shift out of park
  156. POP then nothing
  157. D17A2 Intake Manifold Plastic Spacers/Washers
  158. 2001 honda civic ex
  159. Fuel cell on em2
  160. No spark no start, why?
  161. Wheel Skidding on Sharp Turns
  162. I hate Honda's 51R battery usage
  163. Oil leak
  164. Putting 2003 cluster into 2005 civic
  165. How do I keep audio system on when starting the engine?
  166. 2003 dashboard lights , .
  167. 02 Honda civic SiR clutch replace
  168. Starting ideling and acceleration problems
  169. Rust near front jack stand support
  170. in need of a new rear bumper cover
  171. Alternator not charging battery
  172. No AC
  173. Electrical problem/starting
  174. 2002 civic dx d17a1 swap to d17a jdm
  175. 01Civic No Spark
  176. Election. Problem
  177. Help. civic Popping out of 5th
  178. Random slow acceleration after new o2 sensor
  179. Electrical issue ( car wont start ) Civic EP2 europe
  180. overheating 04 civic
  181. 2005 honda civic ex coupe
  182. 2004 Civic Electrical(?) Problems
  183. EP3 Starting Issue
  184. Code P2647 A Rocker Arm Actuator System Stuck on Bank 1
  185. Interior electrical issues (door locks, interior lights, etc)
  186. 2001 Civic EX battery fuse
  187. 05 LX (d17a1) plug/coil melted in tube
  188. D17 to K24a MT Turbo swap
  189. Main door actuator
  190. D17a1 to D17a2 swap fuel injection issues
  191. 2001 civic won’t start after changing crankshaft position sensor
  192. 2005 Honda Civic brake lights dont work
  193. Fuel pump ground location??
  194. Weird electrical performance 2001 Civic
  195. What to change when changing water pump?
  196. 01 LX: Sudden CEL, limp mode, P1361
  197. Check engine light Code P0420 Catalytic Converter
  198. 04 Civic acceleration and deceleration issue.
  199. torque specs 2004 honda civic
  200. Need Help with SRS Code
  201. Long crank no start on my EX.
  202. 05 Civic LX cant get axel to fit into spindle on pass side
  203. Alarm Not Working!
  204. 2003 Civic Cruise Control Disengages While Driving
  205. Ring me up
  206. Do you think my engine block is warped?
  207. Backup Fuse Battery Drain
  208. Bringing Civic out of storage?
  209. New Clutch?
  210. can't fix
  211. Neutral safety switch wiring questions?
  212. Lowered bump-steer problem solved
  213. 04 civic m/t cranks, no start
  214. P0131 error after working engine hard
  215. civic 1.6 lx 98 ATF draining 6 quarts!
  216. Wiring under the dashboard by steering wheel
  217. Trying to find EVAP leak
  218. 2002 SiR clutch recommendations
  219. Door lock actuator
  220. 2000 Civic GX
  221. Bucking on coast
  222. 02 Civic::drivers side door won't lock, unless the door is shut?
  223. Door locks and handles
  224. Wheel hub and bearings
  225. K24 Half Shaft Bolt Hole - Leaking Oil
  226. 02 civic engine bay ground locations
  227. 2002 honda dx/ex
  228. 2002 civic front ball joints
  229. 2001 Civic DX Tranny Swap Noise
  230. 2002 Honda Civic clutch line issue.
  231. What ECU works with a 2004 EX..
  232. Oil pickup tube torque spec?
  233. Can I use regular temp Hondabond for an oil pump?
  234. How much used oem catalytic converter scraps for?
  235. Second O2 sensor question
  236. '05 Accord
  237. 04 Brakes
  238. Ignition coil connector
  239. ex exhaust to dx exhaust
  240. Remove stripped power steering nut / bolt ??
  241. will 205 45 17 fit 2004 civic 4 Dr Ex?
  242. 2004 Honda Civic EX coupe
  243. Window trim on passenger door is bulging?
  244. 2001 civic si p0300 random miss fire code
  245. 01 Civic what part is missing in this picture?
  246. Non vtech to vtech swap
  247. 2002 civic misfiring, relay clicks behind glove box
  248. 03 ep3
  249. 2002 Honda Civ ic SI Slave cylinder replacement
  250. Coolant leak from timing cover
