PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. d series transmission
  2. NEED HELP: Haven't driven car in over a year!!!
  3. rattling when accelerating
  4. Charging System 2002 Civic
  5. 97 Auto into 01?
  6. idle problem
  7. interior color codes
  8. air bag light because of seatbelt ?
  9. Rear Seats.
  10. advice on buying used civic
  11. 2002 Civic EX - Popping noise when turning and going over bumps?
  12. ARP head studs issues
  13. Honda Civic LX cruise control light does not work nor the control works
  14. 01 civic ex. battery light came on, then check engine light, wont run right
  15. 2001 Honda Civic - Dash Wiring Problems
  16. OBD2 Code P1420
  17. Axle/Tranny Issues with 2001 Civic EX Auto
  18. Wich is better...? AEM - k&N..??
  19. leaking gas from fuel rail??
  20. Transmission
  21. Weapon-R
  22. side skirt issues
  23. k20 into an ES9
  24. No immobilizer light
  25. 01 civic coupe prob... PLZ HELP!
  26. oem parts
  27. 2001 torque converter question
  28. 01 LX problems
  29. 2002 Civic LX overheating
  30. Parts needed for Manual Tranny swap
  31. 2005 Honda Civic...STD??? No PL/PW Auto D17A1
  32. when to replace coils on 2005 civic with 1.7 v-tec
  33. Camshafts
  34. Modulo Parts... ($$$...!?)
  35. Brake Drums - What size?
  36. Control Arm Bushings
  37. Replacing Rear Drums
  38. ABS: both wheel sensors out?
  39. Wiring question?
  40. 2003 HC Hybrid heating issues
  41. Help! My Civic has started to make a rattling sound, which seems to be coming from...
  42. OEM Intake question
  43. jdm es climate control
  44. Search OEM Lip Kit 04-05
  45. remote cd changer
  46. headlights?
  47. K20Z1 swap question
  48. AC ON when the hot air is directed to the windshield
  49. voltage stablilzer
  50. 1.7 Civic Swap Gone Bad! Help!
  51. Indash Stolen!
  52. new here......got a A/C problem...it died
  53. 2005 Civic Instrument Cluster Nightmare
  54. Tinted windows
  55. Think twice before you but a salvage titled vehicle
  56. Transmission Help!!
  57. I'm really fed up with my P0420 code
  58. ► 01-05 Civic Cooling System Q&A (overheating, fans inoperable, etc.)
  59. Ran '05 Civic for 2-3 miles without oil
  60. '03 Civic ex,p1505 but not pcv issue,what then?
  61. front bushings shot already. Are there 1 or 2?
  62. HELP: Heat Issues
  63. Help please
  64. >>>4DR FRONT CLIP ON A 2DR BODY???<<<
  65. 2001 Honda Civic LX engine noise
  66. knocking
  67. Electrical fault
  68. AEM F/IC worth it?
  69. 2005 civic ex misfiring
  70. 04 Honda Civic Headlight adjustments?
  71. oil prob HELP!!!!!!!!!!
  72. Odd whirring noise when I turn?
  73. 01-03 rear lip on a 04-05?
  74. aftermarket VTEC oil switch replacement for Civic 2001 EX?
  75. !!!!!!!! NEED SOME HELP 01 CIVIC TURNS ON THEN SHUTS OFF !!!!!!!!!!
  76. loud grinding noise
  77. idle question
  78. Orientation of front control arm bushing '01 Civic
  79. Weird Electrical Problem ????
  80. Charging System HELP!!!! CALLING ALL CAPTAINS !!!
  81. p1361 tdc intermittant error (HELP PLZ)
  82. 01 Civic LX heater quits when stopping car
  83. Engine swap from 03 ex vtec to 2004 non vtec motor
  84. Bought New Honda Civic 2003 LX and have Questions!
  85. 2003 lx sedan OIL PUMP RESEAL
  86. Radio Code...
  87. 2001 Honda Civic Misfire
  88. 04 ex what to do alongwith timing belt.
  89. Crappy gas mileage
  90. Removing Windshield Trim
  91. flipping tie rods?
  92. Brake Bleed Valve broke off
  93. Resurrecting my friends EM2...
  94. Honda Accord 2005 Vs Honda Civic 2003
  95. Blown Airbags replacement question
  96. air intake help
  97. 2001 civic trunk spoiler bolts
  98. transmission problems
  99. em2 02 civic wont run
  100. Rear Drum Stud Replacement - Help Needed
  101. Burnt out climate knobs and buttons..
  102. Oil Filter Bolt/Holder Broke
  103. 2004 Civic ES8 - D15Y3 - High and unstable idle
  104. unknown problem with civic
  105. 01 sedan OEM fogs to hybrid fogs
  106. DRL Problem
  107. Helps with ABS
  108. Tachometer test signal?
  109. OEM Fogs
  110. Temerature gauge spiking when idle, levels out when in gear
  111. Timing belt
  112. Tranny issues
  113. Idle searching, check enging codes, and electrical issues
  114. D17a9 = D17a2 ???
  115. D17a2 Vtec Sound:
  116. Head Gasket Questions
  117. Intake Manifold Questions:
  118. 2003 Honda Civic LX Lights Flicker
  119. quick o2 sensor wiring question
  120. what motors can you swap into an 02
  121. What is the easiest way to check if the timing belt was replaced?
  122. 2003 SPEEDOMETER PINOUT (WIRING COLORS)
  123. 2003 arm rest compartment... removal
  124. Problem With Dash and Parking Lights
  125. reak disc brake
  126. 2002 Stock EX - Strange Shake
  127. D17A2 Ideas?
  128. SOMEONE PLEASE HELP 01 civic lx coupe auto
  129. 05 civic steering wheel swap?
  130. 01 honda civic hp gain tips
  131. No power to driver side headlight?
  132. Greddy ti-c exhaust issue..
  133. 02 coupe front end.
  134. advice before smog
  135. ?!what would be a good turbo for a em2?!
  136. 05 Starting Problems
  137. Question on engine code
  138. bumper replacement
  139. SRS Light On
  140. Windsheild wiper fluid motor?
  141. What else should I get serviced?
  142. New Here! New Car!
  143. Random misfire, running lean, keeps returning.
  144. Owner w/ ABS, are your brakes spongy?
  145. Car does not start 1 out of 10 times runs perfect
  146. changing the auto trans in a 02 civic
  147. help adjusting manual trans cable.
  148. stainless lines with ep3 rear disk
  149. 2002 Civic radio code - help -
  150. 2003 civic: Auto to 5 spd conversion
  151. Widest 15" Wheel and Tire That'll Fit
  152. headers and intake 01 lx
  153. 01 Civic Changing speedometer KM to MPH
  154. Help identify a squeak / squeal please
  155. Noob here from the U.K
  156. Car wont start
  157. Ex Motor-D17// Where do I set Vtec Lower & Upper Boundary Points?
  158. 2002 civic ex stereo wiring diagram. Help please!!!!
  159. headlight output
  160. o2 sensor
  161. The apparently infamous auto tranny failure
  162. CEL P0453
  163. need help what to install on d17 for more power im new to this
  164. Weird Knocking Noise after Headgasket Install
  165. 2004 honda civic
  166. Rain Water in Driver Side Flooring of 2001 Civic Ex Coupe w/Moon Roof
  167. Timing belt & water pump replacement brand recommendations
  168. Auto Tranny fluid: ATF-Z1 vs Mobil 1 full synthetic
  169. What would cause my 2002 Civic ex to run rich?
  170. How to extract SRS codes from 01 Civic
  171. How to replace turn signal bulb on 2003 Honda Civic LX?
  172. 04-05 front end conversion on a 2001-2003 em2 coupe
  173. 03 Honda civic ex sticks in reverse
  174. Keeping Cruise Control with EP3 Wheel
  175. VTEC-e Not Engaging
  176. 2001 EX cel problems
  177. D17A one a interference motor for 2002 Civic EX
  178. HEADLIGHT BUZZER NOT WORKING WHEN DRIVER DOOR OPEN
  179. Civic 2001 LX Motor Mount Question
  180. Car gets jumpy and engine light turns on. 01 Civic LX
  181. Alternator bolt stripped
  182. Screeching Noise at Startup
  183. 2001 civic randomly stalls
  184. Boost help!!d17a2 turbo ..
  185. Boost on stock internals
  186. Poor gas mileage, oil on engine?
  187. Power Inverter Question
  188. Will Acura CL rims fit our cars?
  189. Clutch replacement
  190. 04 civic ex 1,2,3,4 misfire only between 1500-2400rpm
  191. 02 civic ex wasting oil
  192. Awful Fuel Mileage / No Malfunction Light
  193. 2004 Honda Civic Ex/Need a computer
  194. 2005 Civic blown head gasket
  195. 01' LX Instrument swap to a 03' instrument cluster
  196. anyone have experience with kw, zenesis or mosconi?
  197. Auto EX Tranny into LX Motor
  198. '03 civic ex won't stay on after timing belt replacement
  199. How often are 2001+ Civics stolen?
  200. Another engine mount question....
  201. brake lock
  202. exhaust broke at flange... repairable?
  203. How to get rid of shift boot sag?
  204. Need picture of TPS Sensor (wires) up close
  205. floor heat stopped working????
  206. I need 03 ex head unit specs/ speaker info
  207. Mystery connector
  208. automatic vs. manual throttle bodys? high idle after new motor
  209. k24/20 build Questions
  210. Key won't turn in ignition
  211. Are these good clutch replacement parts?
  212. 01 civic ex shut off now will not start
  213. lets talk adapting itbs from other d16s
  214. how do you guys deal with winter?
  215. 01 civic starting problem, sputters alot.
  216. d16 series header?
  217. whats up H-T
  218. My brother lost his radio code
  219. 2001 Civic LX Glowing header question? PLEASE HELP!!!
  220. 03 EX trouble
  221. Issue with sunroof, please help!
  222. Removing Spark Plug Cylinders
  223. speaker removal, replacement, etc
  224. valves making some noise..
  225. Getting a smaller tire size
  226. D17A1 block with D17A6 or D17A6 Cylinder head
  227. Rear window spoilers...
  228. ABS Light On
  229. 2002 Civic EX Automatic wasting alot of gas
  230. OEM 7th gen rims
  231. Radio Clock *FLASHING*
  232. TPS Sensor - Problem Gone?
  233. 01 Civic with 5 codes... Two P0420, two P0133 and one P1298
  234. A few K-swap questions / Acrua EL
  235. Radio code help
  236. lights burned out
  237. jdm civics
  238. Heater blows hot when driving, cold when stopped? Please Help!
  239. 02 tranny blown!
  240. SLW?
  241. headlights
  242. PLEASE HELP!! Check Engine, Click "d" goes out and hesitates
  243. em2 engine electrical advice
  244. honda civic gauge issues
  245. 2001 Civic CVT replacement
  246. front bumper w/ fogs
  247. TYC Projectors
  248. non rsx/ep3 seat install in em2
  249. Should i replace my timing belt tensioner?
  250. High RPMs and acceleration lag
