PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. HCH Transmission Control Module Location
  2. 2004 Honda Civic LX cluster
  3. 2004 Honda DX engine swap in a HX D17A6
  4. Engine starter bearing
  5. I'm out of town and could use some insight
  6. 2005 Civic D17a Crank Pulley Diameter
  7. Will an 05 Civic Hood Fit My 04 Civic
  8. Is non VTEC head casting same as VTEC?
  9. Timing belt too loose on front side and tight on rear
  10. PMR-HA-8 Head on D17A2 Engine?
  11. Setting timing for head gasket replacement 04 civic 1.7
  12. Advice on larger size tire, 2005 LX Sedan
  13. ac actuators
  14. 01 civic lx
  15. Stuck in 3 rd gear , help me please
  16. PO497 and PO139 error codes - please help
  17. Driver headlight and brake light both out
  18. 05 honda civic wont start but lights work
  19. 03 Honda Civic starting issues
  20. coolant bleed leads to check engine light on.
  21. P1263 error code help
  22. Misfire!
  23. ECM question
  24. Car loses heat while driving
  25. 2005 Civic LX Timing Belt help
  26. 05 nonvtec to vtec...vtec not plugged up
  27. Amber turn signal
  28. 2003 Honda civic LX no crank no start. Help!!
  29. OVER HEATING ISSUE
  30. Can an 03 Civic start without the ignition?
  31. What part do I need to buy to replace an O2 sensor heater circuit in a Honda Civic 04
  32. 03 civic stalls and won’t restart
  33. Honda Civic coupe 2dr manual
  34. Little round circle in headlight?
  35. What size wrench to remove battery cable from terminal, 02 civic.
  36. 2003 honda civic lx blows high on all settings
  37. 2003 Honda civic hybrid noise when acellerating
  38. 2001 Honda Civic EX
  39. 2004 dx vp cluster issue
  40. 2002 Honda Civic ex
  41. 2003 civic lx engine and intake faults after head rebuild
  42. 03 Civic- which PCM ground wire causes both P0113 and P0118 faults when disconnected?
  43. E-Brake Won't Lock Rear Wheels (2001 Honda Civic EX Coupe)
  44. Honda Civic head light Low beam not working
  45. Coolant shorts in my honda civic 2003
  46. 2003 Civic LX - Burning coolant after head rebuild
  47. [2003 Honda Civic] what part plugs the hole in the head opposite the timing belt?
  48. Front end rattle/clunking sound
  49. Engine too cold
  50. Only starts and runs but runs like shit when disconnecting crank sensor
  51. Stranded in snow storm!
  52. Come to stop, RPM fluctuates by itself
  53. Clutch went out and Civic won't start (2004 5sp manual non-vtec)
  54. 2002 LX Sedan Suspension Help Needed
  55. High Flow Cat?
  56. 01 cluster to 04 cluster civic EX Automatic
  57. CAr stalls with lights on
  58. High idle from engine swap
  59. BMXA Whining Noise - Valve Body related?
  60. Airbag light issue 03 EX coupe
  61. 2005 civic obd II issues HELP!!
  62. Engine oil
  63. 2004 civic heater issue
  64. drivers side floorboard wet
  65. 2003 Civic Ex. Overflow in Rez. Head Gasket
  66. Help 05 nonvtec swap vtec
  67. 2001 5spd civic Solenoid to starter wire corroded- ideas how to replace?
  68. Electrical Issue help
  69. Engines
  70. Possible to Split Transmission in-car?
  71. Crank pulley weight reduction
  72. 2004 Honda 1.7
  73. Seat upgrade?
  74. heat is not coming in the car and temperature gauge is not working
  75. Confused
  76. 04 civic ex auto trans issue
  77. honda civi ferio es2 auto 4wd
  78. 2002 Honda Civic Lx - Installed New Clutch, Slave &’ Master, Bleed System And Still..
  79. 2003 Honda Civic LX Smoking Out of Exhaust Pipe after adding oil
  80. 2002 honda civic car beep stopped and brake light on
  81. 05 civic won’t start
  82. 2003 civic ex shutting off
  83. Overheating and little/no heat at idle. Help!
  84. Climate Control Airflow Issue
  85. 02 civic lx
  86. 2003 HCH, IMA light after engine swap
  87. 2004 em2 wheel stud question!
  88. Lower coolant temperatures at highway speeds
  89. Air Bag Notice - All Hondas
  90. Slave Cylinder Mount Broken!!!
  91. Seat switch
  92. My Civic makes a great tow vehicle
  93. running a turbo D17A2 civic ex coupe
  94. Low rpm at idle on cold starts random stall loss of power
  95. Changed head gasket. Now won't start
  96. ecu swap
  97. 2003 Honda Civic Overheating
  98. need help plz
  99. How much power does my engine make?
  100. 03 Honda civic intermittent issues
  101. Anyone know how to get this clip out?
  102. SUSPENSION'S INTERCHANGEABLE?
  103. 2001 Civic LX coupe
  104. How much compression should I see on an '01 Civic with 120,000 miles?
  105. Cleaning the catalytic converter on a 2001 civic
  106. 2002 Honda Civic EX Running Rough
  107. P1457 Evap Code
  108. Lost Keys
  109. will a 2.25 Intel muffler fits on a 2005 Honda Civic 4 door sedan value package ?
  110. Idling high, flashing check engine light & clicking noise by glove box
  111. drive indicator light flashing.
  112. 2001 Honda Civic faulty immobilizer
  113. 04 Civic EX MT shift lever question
  114. Quick paint question!
  115. 2004 Civic SiR Coupe U.K
  116. Will an 03 Lx 5sp tranny work in an 03 Ex 5sp car with a D17A2
  117. Adjusting to TDC with broken timing belt
  118. Honda Civic Coupe 2003 automatic transmission removal 60k miles on the clock
  119. 2001 honda civic immobilizer
  120. No speedometer or odometer?
  121. 2001 Honda Civic Transmission BMXA or SLXA
  122. Car will not start, gear shift locked
  123. Fried computer or bad sensors?
  124. 2001 civic
  125. 2004 Honda Civic Si
  126. 2003 Civic Won't Start
  127. Honda civic 2001 AC leaking liquid by the drain hose
  128. Duel Alternators on 01 - 05 Civic
  129. Transmission grinding
  130. Tips on removing fusebox connectors
  131. Car won't start.
  132. my honda civic 2002 won't go in gear only reverse
  133. 05 Civic - can it be saved from rust?
  134. 01 civic lx 4dr drives for 6-10 miles and goes in limp mode
  135. 02 EX D17A2 Power loss/Misfire/Stalling SOLUTION
  136. Catch can/oil separator
  137. Shopping for wheels and tires. HELP
  138. 2002 Honda Civic Si ECU Question
  139. G7 Rod Bearing Failure for the second time?
  140. 04 civic lx crank no start
  141. Pedal Extenders
  142. Front windshield molding trim?
  143. Replaced Cam Shaft Sensor
  144. Why would the battery be overheating and leaking?
  145. 2005 civic lx 4 door Alignment issue
  146. Troubleshooting: 2001 Civic crack in plastic on top of radiator-Solutions?
  147. 2002 Honda Civic Ex Instrument Cluster Issues
  148. 2002 civic rear defogger
  149. Yeah I searched the archives
  150. Motor swap
  151. Why did my radiator crack? Bad mechanic?
  152. Steering rack bushings
  153. Engine Swap Car Stalls in Reverse and Drive
  154. Honda Civic 2001 gearbox automatic replacement
  155. srs light, abs light on after engine wash
  156. 2005 Honda Civic LX on Boost?
  157. No start
  158. Radiator & AC fans do not kick on. Not sure what to test next!
  159. my car only starts when i remove the crank sensor
  160. why wont you start
  161. 2005 Honda Civic turns over but wont start
  162. Mechanic "lost" my OEM key and remote and gave me a copy of the key
  163. 2002 Honda Civic automatic transmission revs high before shifting
  164. over heating
  165. Fuel pump, Kautex or Yachiyo?
  166. 02 Civic Engine light
  167. Is there coolant in the small rubber line on the idle control valve?
  168. Slight rough idle
  169. Keyless entry
  170. Honda Civic 1.4 - 2002
  171. Car stalled, only start with gas pressed, rough idle.
  172. AT ECU in a MT car
  173. Wat website can i get my oxygen sensor p1166 scan code
  174. Concerned
  175. Stubborn Maintenance Required light won't reset
  176. Coolant Drain
  177. Civic 2003 EX - Which catalytic converter to buy?
  178. Engine running hot & A/C problems
  179. AC Clutch Replacement Success (I hope)
  180. 2003 Honda Civic EX with overheating issues...
  181. 2005 civic rough idle and is cutting out.
  182. Cold air not coming
  183. 2003 honda civic 1.7
  184. 2002 Civic EX Sedan Rear Bearing Assembly
  185. 03 Hybrid swap
  186. Need help please!
  187. Misfire on all 4 cylinders, exhaust out of manifold join
  188. 05 Civic DX - Replace Passenger Panel, trunk
  189. Evaporator Temperature Sensor
  190. P0135 Comes Right Back after O2 Sensor Replacement
  191. 05 Civic Water Leak
  192. 2005 civic clutch problem
  193. Should I be able to rotate my AC compressor shaft by hand?
  194. Ticking in acceleration? Help!
  195. Any LED Headlight Bulbs that are plug and play?
  196. 2004 Honda Civic No Start No Crank
  197. Hot hood, temperature gauge is normal
  198. 05 civic special edition
  199. 01 civic ex rear drum brake conversion/brake problem
  200. 2003 Civic only starts when cold
  201. Clutch master cylinder.
  202. How much does a stripped car weigh?
  203. Headlight Question
  204. JDM swap into 2004 civic LX
  205. Defrost issue
  206. 2004 Honda Civic Hybrid transission issue! Please helop
  207. How much can I tow?
  208. Civic 2001 - Primary O2 Sensor Heater issue
  209. 04 civic metal rattling noise
  210. Tranny slipping
  211. K24 Swap in Em2
  212. Transmission
  213. Car starts but engine sputters on driver side
  214. RPM drops from 800 to 250-200 when A/C turns on
  215. 05 civic lx changed transmission P light blinks no tourque converter lockup
  216. power steering belt tensioner
  217. 2005 civic rear driver side door
  218. no egr on my 03 civic d17a1
  219. Rusty intake manifold
  220. blower motor out 04 civic hybrid
  221. spare part number
  222. D17A2 nitrous 100 shot.
  223. What to look for on a possible cracked block or cylinder head?
  224. 2001 Honda Civic What is this loose wire in engine?
  225. Noisy front wheel bearing...
  226. Normal operating range? (temp)
  227. Misfire Mystery Driving me cRaZy!
  228. Please i want a manual for honda civic 2004 sedan engine D15Y3 THANKS in advance
  229. Brake lights out, car stuck in park, horn out
  230. Body Questions 05 Civic coupe
  231. D15B Vtec Swap Big trouble(Help Plz)
  232. Please help me choose a muffler
  233. Yet another starting issue
  234. Replacing the AC Clutch on a 2001 Civic?
  235. Taking the cylinder head off, how to fully unbolt the intake mani?
  236. CRANK NO START DUE TO NO SPARK HELPP
  237. Battery not charging
  238. Transmission fluid
  239. When i take off slowly it sounds like a card in bicycle spokes
  240. New clutch, peeled out, now I can't get into second gear.
  241. Just got given a 01 civic ex heres what its doing please help!
  242. Installing Wheel bearing
  243. 2001 Civic Air Filter trouble
  244. 2002 Honda Civic P1457 Code
  245. 2002 honda civic cranks but wont start
  246. 2005 civic hybrid manual
  247. Civic 2004 forced induction, help needed
  248. DIY Key Programming
  249. Headlight indicator (green light) not working
  250. 01 Honda Civic driver autoliv airbag, still useful? Any good? Non recall?
