- Civic 2003 A/C
- belt squeek
- Can I lock the car with the engine running
- D17a1 to jdm d15b vtec wiring.
- A/C Compressor shaking when clutch engages
- Car totaled. Want to trade it in. But it’s a salvage title...
- Any ideas ?? I'm puzzled.
- Car lock turns one way only
- Replaced both clutch cylinders but can't get the system to bleed.
- Vafc2
- Hard bucking warming up
- Heres a head scratcher
- Connecting Rod
- Revving out 35000 RPM
- Headlight issue!
- d17a1 to d17a swap
- Headlights and Interior lights flickering but only at night
- 2001 CIVIC roof channel clips.
- 2001 Honda DX engine noise ?
- 01 civic LX Engine repair or swap questions.
- 2003 Honda Civic alternator installation issue
- Oil Drain Plug Leak
- 04 civic ex plan to K24 swap
- Head Gasket Replacement
- 01 Honda Civic EX 4SPD Auto Transmission
- Weird shift to 4th gear
- K swapped em2 issues!
- K20a4 strength
- Misfire has anyone seen this before
- Head gasket /trash or reuse
- Honda Civic 2005 - Oil pan leak
- Hondata needed?
- Just to confirm
- 2004 Honda Civic Lx >40mph low toned, loud growling from front end
- 03 Honda Civic
- do you have to evacuate refrigerant to remove AC compressor clutch, pulley, bearing?
- Manual gear transmission
- Alternator intermitent problem
- K24a2- leave stock head or k20 head swap.
- 03 civic turbo set up advise
- 06+ K24a swap to 03 civic ex?
- 01 Honda Civic Is
- Head gasket thickness?
- Engine Hum
- P1519 only at cold start
- 02 civic ex help please
- 2004 Honda Civic crank no start
- 2003 honda civic best hook up form car straight to laptop
- 16x6.5 Miata wheels on a '01 Civic DX 4 door - Cheap lightweight wheel upgrade
- Lower spark plug tube seal??
- My 04' manual has no tach on the stock cluster
- 04 Civic Ex 1.7l barely moves in drive
- 2005 Civic - Bad mileage
- Engine swap or turbo for d engine?
- Weird srs code
- Cooling/Heating System Still Functioning after Car is turned off?
- 2002 EX revised Timing belt Tensioner bolt part # ?
- 2001 honda civic auto to manual swap
- Changed radiator now AC isn't blowing cold air
- Headlights
- Any recommendations for suspension kit for a 04 civic
- Loss of Power
- Fuel Cut
- 01 Honda Civic / Ignition replacement HELP PLEASE
- Help please when hot car wont go past 4000 rpms
- P1505 error code
- 05 Honda Civic Lx ( ECU fuse blowing)
- Transmission help!
- Is a 5th gen front bumper conversion to a 7th gen possible
- Buzzing Noise
- 05 honda civic ex instrument issue
- Flapping noise next to egr valve
- White exhaust smoke
- 01 Honda Civic Ex Man.trans no crank no start everything is fine though?
- Solution to popping sound after installation of new struts, mounts and bearings
- Engine knocking
- TERRIBLE SHAKE/VIBRATION 30-70MPH
- P1259 Giving Me Grief
- need help!
- Gauge Cluster Not Working
- Rough idle on warm engine
- Purchased Used 05 Civic Ex Coupe
- 2003 Honda Civic no crank
- 04 civic torq convertor knock
- 2004 Honda Civic
- Rough idle
- p0336 a few hundred miles after timing belt
- Hot wire 2004 fuel pump
- VTEC Operating Parameters
- GREEN and BLUE instrument cluster connector terminal pins
- Can I swap a 02 ecu into a 04 civic for a mini me swap?
- 1 cylinder misfire | Burning Sparkplug | `05 EX
- electrical issues
- Pulsing Lights, gas mileage going down
- No power to the mode control motor
- )2 civic O2 sensor
- Dark synthetic oil ,.
- Backfires when cranked but no start
- 2004 1.7 civic rough idle ,.
- 2004 civic ex rear windows
- 2004 Honda Civic 1.7L LX hard start / P0302
- 2003 MANUAL LX AirBag Light + Parasitic Drain
- 2002 EX Moon Roof Question
- 2003 Honda civic LX coupe Keyless entry reciever
- 2003 civic ex coupe have a leak
- Possible to manually switch air mode control? (Honda Civic 2003 EX)
- Immobilizer hell
- Honda Civic Engine swap
- 2003 Honda Civic LX (CEL)
- Engine swap
- honda not starting when its cold.....
- '01 Civic LX won't pass smog
- 2002 Civic 1.4l Manual - Squeaqing noise when engaging clutch
- Losing volts from alternator.
- Valve adjustment
- 2002 Honda Civic Coupe won’t start
- Rear disc brake conversion kit
- NEED URGENT HELP W/ NOISE
- 2001 Civic Ex all cylinder misfires
- How bad are Honda's for rust?
- hazard switch
- Wheel fitment confusion
- 04 civic cam swap
- Fuel Filter/Pump Question
- Lowering springs
- HELP w/Front End Collision Repair 2005 EX
- Airbag is always off
- Help
- Cluster clicking after stereo install
- D17A ECU Part Number
- Torque Coverter Bolts Sheared
- P1361 resolved w a twist
- Post-Mount
- Searching Honda Parts OEM number
- Carplay units that are plug and play?
- 2001 Honda Civic Ex Reving itself like I've never seen before
- What have I done now. Stereo works, blinkers don't?
- Keyless entry harness in LX?
- Can not find the VVT on my 2005/06 Honda civic VP
- Changed Timing belt, Thermostat - now have an O2 sensor code P0132?
- no sound
- cylinder head plug replacement
- 2002 Civic leaking coolant at the bottom of the radiator. hose or radiator?
- Horrible knocking sound.
- Timing belt.
- factory amp
- Another cooling system thread
- Parts question
- Unsual sound
- Civic ex D17A2
- 2002 Civic overheating and not shifting
- 2005 civic si conversion
- Replaced a great running motor and now is running like garbage
- 2001 Honda Civic Ex sedan
- 2002 Civic EX D17a2 - What's the real OEM Thermostat temperature? Is it a secret?
- Rear strut bolt
- Spark Plug / Cylinder Issues
- 2003 Civic EX Low MPG and persistent All Cylinder Misfire
- 01 LX- I need help....
- 2001 Honda Civic Ex D17A2 motor and BMXA transmission
- Muffler Deletes
- 2001 Honda Civic ExTransmission wiring BMXA
- D16y8 on a 2001 civic
- No crank no start after CAM replacement.
- Start car without keys ?
- Getting shorter springs on my coilovers
- Blinkers out
- 04-05 bumper on 2002
- CV axle replacement
- 2005 Civic Si (Canada) Rear window stuck down
- Rebuilding BMXA - Need help - PM me
- Honda Civic Hybrid Chirping Noise
- Srs code
- Show ur Hi mileage 7th gen love here! (Maybe the only place?)
- Where'd the oil go??
- More issues than I thought
- 2005 civic LX cruise control gauge light issues
- Need help figuring out what's wrong with my 04 Honda Civic gx
- Transum
- Upgrading my daily
- One for the Detectives
- Driving with bad AC compressor clutch
- 04 civic dx 1.7 throwing codes P0497, P0344, p0340, p0339
- How-to advice: EGR valve removal in 2005 Honda Civic LX
- 2005 honda civic lx
- Another 2002 AC system issues...
- Civic EX special edition ECU alternator problems
- No start hot weather 01 civic
- 2004 Honda Civic si sedan 🇨🇦 Rear Sway bar link
- 2002 Civic 240k Miles what needs maintainance?
- 03 Honda Civic LX overheated and blew out coolant
- Lean Idle
- Sad news
- HONDA LX INTERCHANGEABLE PARTS
- AC has gone out, fuses blow after changing
- 2002 honda civic ex automatic coupe
- Harsh startup after replacing valve cover gasket
- 03 civic LX 1.7L 5 speed
- Civic 2001 ex transmission leak
- Pigtail hanging from rear bumper
- 01 civic
- 04 Civic Hood Not Opening
- 03 Civic A/C making noise HELP!!
- 02 Civic A/C Runs Intermittently -FIXED
- One of rear drum brakes not working properly
- 05 Civic - A/C not always cold
- 2004 civic ex over heating issie
- Leaking a/c system, may neesd to remove evaporator
- Sedan front end on coupe
- 04 civic ex camshaft sensor
- What bulbs do I ask for? (Heater controls, 3 buttons under radio)
- 2005 civic hood stuck closed won't open
- A/C not working
- Fans
- Car won't start after changing dead battery. I have Viper Alarm System Help!!
- Missing Engine Mount hardware
- Gas smell
- 01 Civic transmission issues
- 2002 Civic 3rd Gear Grind
- 04 civic trip resets when car turns off
- Engine cranks but does not turn on.
- Information about what size tires to get for my 04 Civic
- Knock knock! Take a look and tell me what you hear.
- Need help
- Money hungry honda
- D17a1 automatic to d17a2 manual swap
- New Guy
- 2003 hybrid 5mt won’t move in gear
- 2004 Honda Civic lx
- 2004 civic dx d17a1 for a vtec engine
- Suspension advice
- Loose Wheel cause?
- Wiring harness tests.
- Need ideas for wheels
- 05 Civic clutch sound
- 2005 Civil LX clicks during city driving and acts as if it's shutting down
- 03, AC checkout procedures
- if not pcv valve, then what it is?
- Baffling transmition issue
- Camber kits for EM2 ?
- 05 civic ex front brakes
- oil cap left off now car won't start
- D17a1 to D17a2 motor swap and manual conversion
- Immobilizer problem
- Excessive water spitting from exhaust, No smoke or other problems
- Whats the best mid ranged price coilovers. $600-$900 plus shipping in AUD.
- Looking for a new catback
- Transmission Question (is it a bearing or more sinister?)
- Overheating issues
- 04 Civic - Wont Start
