PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. 2002 civic ex P1298 & P0420
  2. oil in my coolant reservoir
  3. 4 door, rear door handle removal
  4. Do People Steal the Really Low-End Civics?
  5. Civic buying help
  6. Is My 2002 Vtec Non Interference?
  7. Voltage regulator/alternator
  8. Ebay Intakes/exhaust
  9. Head gasket check
  10. ECU Fried? How to test it?
  11. 02 civic auto to manual car wont start
  12. My Build Thread- Turboed EM2
  13. car hitting rev limiter at 4k?
  14. Meet your door checker (easy diy repair)
  15. D17A2 Head gasket job - Revised specs?
  16. More Catalytic Convert Questions
  17. EM2 Build Thread
  18. SRS Light on
  19. could a mod delete this?
  20. Swapping Struts and Stuck...
  21. '03 A/C Compressor
  22. Blower fan doesnt start until car warms up?
  23. 2001 civic ex will start but won't stay running
  24. How Does The Stock Alarm Work?
  25. Change your power steering fluid!
  26. ATF Dip Stick is Loose...WTF?
  27. CHP INSPECTION
  28. 01 civic new radio installation, rogue wire?
  29. RSX cluster swap problem
  30. 5 lug axle - 4 lug hybrid axle ?
  31. Rear drum brake replacement?
  32. Coolant Change
  33. airbox with intake elbow
  34. 4wd ES1???
  35. 2001 Civic Auto Transmission
  36. '03 Civic LX Autotranny slips when cold??
  37. Honda Civic Leaks Water in Rain!!!
  38. will a eg/ek d series tranny fit a 01 civic ex?
  39. Warning lights flashing like mad. Over charging/high voltage problem?
  40. VTEC pressure switch
  41. Fuel Door!!!
  42. Buying a High Mileage 01+ Civic
  43. Performance chip
  44. Question
  45. cam gears settings
  46. rear disc swap?
  47. 01-03 Civic CD Player Code...need help please!!
  48. Haywire Hybrid...
  49. '03 Hybrid - Auto stop beeping
  50. Those that had an overheating problem and had to change the head gasket...
  51. hey you guys can you help me out?
  52. will rsx rear seats fits in our cars?????
  53. 03 Civic LX Crazy Electrical Problem. Relay? ECM? Please Help
  54. Oil Change Intervals
  55. Help needed!
  56. overheating civic. heater core?
  57. Cylinder 4 Misfire P0304 Issue
  58. want more power!!!!!
  59. water temperature gauge install quick question
  60. Weird Whining Noise
  61. chicago em2's stand up
  62. driverside water leak in a 01 civic
  63. Brake line blew today, *brake problem*
  64. not a typical motor swap ? i need some help with...
  65. 03 Honda civic EX Help
  66. 01 civic shift boot removal
  67. Need head stud torque Specs asap 04 civic ex EM2 please
  68. CEL FOR 2001 CIVIC???
  69. how-to fix honda 02 rear defroster lines?
  70. Cost for Compliance Bushings
  71. Lip 03 coupe to copue 05
  72. Loud noise from right front shock area
  73. 2001 Civic DX 97,000 mi automatic
  74. looking for help on a 2004 civic si motor change
  75. New...
  76. Please post wheel blitz type 01 to enter in your civic.
  77. fuel issuse with 02 civic.
  78. Thefts of year 2001+ Civics.
  79. HELP!! NEED CODE FOR FACTORY RADIO 05 civic
  80. can this fit my 01 civic
  81. 02 auto tranny questions
  82. Help, No power to fuel pump.
  83. Honda Civic 2005 losing power while driving
  84. new battery and alternator
  85. How many pople have ATF dipstick untied? fluid out the hole
  86. 2004 Honda Civic Gas Guzzler?
  87. third brake light removal
  88. maint required light, how do it turn it off
  89. 01-05 Civic Auto to Manual DIY?
  90. front left wheel noise...
  91. 2001 civic AT problem/question... please help!!!
  92. hub and quick release set up for EM2
  93. Security light stays on dash?
  94. a/c light on and tranny trouble?
  95. K24a2 or K20z1
  96. Help w/cooling system plz.
  97. Is there a trick to take out vacume line from brakebooster?
  98. swap to K24A2
  99. DIY Aftermarket steering wheel and hub install
  100. Which is the EM2/ES1/ES2 is the one with the sunroof?
  101. Insurance Evaluation Questions!!!!!!!!!
  102. hfp wheels
  103. Gauges not working
  104. intermittent problem with radio (2001 Sedan)
  105. My car over heats
  106. Code 10 - IAT Sensor short
  107. cigarette lighter outlet not working. help please
  108. power steering pump - shaft pitch thread?
  109. Heat in Driver's Footwell
  110. Need Fog Light Template for 2001 EX sedan
  111. abs not working?
  112. 16's or 17's???
  113. My brother in law's civic? Are they screwin him?
  114. 2004 Civic LX with multiple problems
  115. oil pan for 2004 Honda Civic
  116. ABS light
  117. DIY: Removing lower control arm
  118. tranny help
  119. '01 Civic EX won't start
  120. Tire Size VS Tread Width (some alarming numbers)
  121. Valve adjustment question..
  122. 2001 civic lx transmission
  123. EM2 front lip/ Splitter
  124. where to get a custom front emblem?
  125. Is it just my car or do em2's have spongy brakes?
  126. I didn't bother to search "overheating"
  127. How many Honda owners to change headlights?
  128. Two problems, 2002 civic lx-g, searched.
  129. Where is the IAT sensor located on a 2001 honda civic ex??
  130. Maintenance Req'd Light wont reset
  131. problems with Honda Civic 1.7 CTDi 2004
  132. oil change w/o lifting
  133. Parts needed for an auto to manual swap??
  134. car won't start. HELP PLEASE!
  135. Air from defroster vents in floor position
  136. d17a2 crower valve train.
  137. jdm 04-05 rs grill
  138. A/C service valve question
  139. 04-05 sideskirt on 01-03
  140. 01 CIVIC EX OBD II 1457 and 1298
  141. P1259 vtec problem
  142. 2001 civic replacing engine
  143. Need aftermarket steering wheel install info
  144. How get to radiator drain 2002 Civic EX? What to remove to see it?
  145. Thermostat replaced, now leaking coolant from housing
  146. tranny help
  147. leather seats
  148. 4dr automatic wants more speed turbo or swap?
  149. 2000 hond civic seats to 2001 honda civic
  150. installing driveshaft
  151. kumosport shifter bushings
  152. o2 civic ex check engine light.
  153. Help with problem CEL light P1456
  154. what do you think about the wheels
  155. Steering Vibration when braking at highway speeds
  156. Front end Vibration
  157. 03 Civic
  158. auto to manual swap
  159. "bogged" down acceleration/wont rev past 4500rpm
  160. 2003 civic questions
  161. 01 swap, what more powerful engine will fit?
  162. Accord intake on a civic?
  163. PA System
  164. '05 Civic power window problems
  165. Honda Civic 2002 Engine light turning on after consecutive repairs
  166. 2001 civic timing belt
  167. can someone tell me what grill this is?
  168. 05 Civic Build Finished !!!
  169. dash swap
  170. cluster question, all comments welcome
  171. gauge cluster
  172. stuburn battery light 2002 civic sl 1.7
  173. 05 Civic EX Drivers side bulb is out
  174. Help with quote for fixing rear bumper - Civic 2005 ex
  175. My Build Thread
  176. crank sensor questions?
  177. reverse lights DIY
  178. oem side skirts for 01-03
  179. Front Stabilizer end links torque spec
  180. 2002 Civic climate fault code 9
  181. rear seat removal
  182. 03 lx rear wheel stud removal trouble
  183. Auto Trans Fail
  184. My Build Thread
  185. SRS Light On
  186. 01 Civic Auto Transmission
  187. haynes manual
  188. Diagnostic Trouble Code P1457
  189. Numbers on front windshield
  190. ES1 EPS PROBLEM, HELP!!!!!!!
  191. Opinions Needed (01 Civic LX Auto)
  192. My Build Thread
  193. D17A2 Ecu wiring diagram
  194. badges?
  195. should i buy this civic?
  196. o2 after cat help please!
  197. Door lock HELP!!!
  198. Help can't solve CEL in 2002 civic
  199. 2003 honda civic hybrid 1.3l please help
  200. Why did Honda Remove Intermittent wipers............
  201. Guage cluster question: auto cluster into manual car???
  202. Header install today.. what tools are needed?
  203. Need help with k swap into em2
  204. How many plugs on 2002 LX PCM?
  205. 03 Honda Civic Hybrid Transmission Problem.
  206. pillar strut bar
  207. VTEC Controller questions.. hElP.!
  208. Buddy Club Short Shifter
  209. j series swap ?
  210. exedy oem replacement clutch kit
  211. got the code "P0420" someone help !
  212. Front windshield Wiper part needed to be identified?
  213. 01-03 front conversion
  214. Transmission Issues
  215. Weird mechanical issue on a 03 civic, the dealer can't even figure it out.
  216. (EX) Automatic vs Manul transmission?
  217. 03 Civic Driver Window issue
  218. b series in em2
  219. need help!! heat not working!!
  220. Buying 2003 civic LX what to look out for?
  221. door panels
  222. 05 Civic LE hard to get reverse
  223. Rear Brakes "clunking" sound
  224. Why are the 01-05 civic so cheap and expensive with low and high mileage?
  225. check engine light after header swap
  226. Weird noise from the rear. Help!
  227. Itermitten starting problems
  228. reset digital mileage
  229. idoling problems . ( check engine light ) !!!
  230. Which OEM Rims are these
  231. Is a 2002 worth $10000 with 72,470 miles?
  232. Intermittent SRS Indicator Light
  233. need help start but it die
  234. es1 auto tranny went out..HELP!!
  235. Brake lock up
  236. duralast tie rod end
  237. 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
  238. Bumper protection
  239. 2004 CIVIC LX (electrical issue) needing help troubleshooting!!
  240. need some good brakes
  241. 2nd fired computer. Please Help!
  242. My Build Thread
  243. What's your MPG do you make on your 7th gen?
  244. wheel spacers
  245. 01 Civic dx-g headlight issues HELP
  246. alright so i need some help
  247. Need Motor Mount Torque Spec for D17A6
  248. My Slow ES1 daily driver build
  249. d17a1 trouble
  250. D17A2 into NON-VTEC model swap problem.
