PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Overheating problem
  2. Motor mount troubles.. what to do what to do
  3. My Build Thread
  4. OBD II Codes
  5. Em2 and rsx
  6. Runs well except when warming up? 03 Civic
  7. side airbag light
  8. Need help identifying rear ABS plug
  9. 2001 Civic Airbag Recall - Must Read!!
  10. 02 ex,having issues
  11. DC5 and EP3/EM/ES Brake Line Compatability
  12. CEL help!
  13. Hard clicking noise?
  14. blinking Maintenance required?
  15. 47 offset rims will fit on our car?
  16. Decreased fuel consumption
  17. Civic 2001 AC problem
  18. Loud power steering pump
  19. Brake Fluid Flush
  20. Benen Front Tow Hook
  21. Gas pedal loosen??
  22. my srs light is on *HELP*
  23. Stalling civic.
  24. Intake Manifold for em2
  25. Throttle Body Clean up Honda Civic 2001 EX
  26. Lighting / Turn signal problem
  27. 01-02 bad transmissions and reliability?
  28. Driver side motor mount replacement
  29. Engine Codes
  30. Spark plugs question
  31. Removing Compliance Bushing/Other
  32. Why was the vtec x-over on my d16 more noticebale than my d17 or even the Si's?
  33. 03 civic dome light
  34. Projector Headlight w/dual halo rings
  35. Civic 2005 D17A1 turbo
  36. LCA installation help
  37. HELP! Tail Light side marker...thingy..
  38. auto trans specs?
  39. Function7 Rear brace and lower control arms.
  40. apexi vtec controller wireing
  41. HID Kit
  42. Spark Plug Recommendations
  43. 01 civic ex help
  44. Looking at a 01' Civic LX, but SRS light is on
  45. 2002 Honda Civic LX MultiPlex Control Unit
  46. Oil Filters...
  47. Overheating problems on an es1
  48. Do I need Antilock Brakes?
  49. power steering - bubbly fluid
  50. Bigger discs & calipers on a 1.7 EM2 Coupe
  51. Maintenance before selling
  52. 05 fog lights
  53. K20 or K24 Trannys
  54. Vibration
  55. Advantages of the 7th gen chassis?
  56. Type R cluster into EM2
  57. very bumpy ride
  58. help with purchasing intake!
  59. 02 civic A/C HELP
  60. headlight help
  61. ► July 2009: For Sale / Wanted to Buy
  62. Catalytic Converter replacement under warranty, dealer charging $731 for O2 sensors
  63. Need help with the Seibon CF Lip
  64. Picking up an 01-05 Civic for my girl, anything to pay attention to?
  65. Timing Belt, etc.....
  66. Questions about replacing Rotors and Pads for 2003 Civic EX Coupe
  67. Engine and Possible Clutch Issue - Could Use Help
  68. 2002 civic coupe overheats once in a wile
  69. Engine problem
  70. How to replace/repair a 03 civic hybird
  71. 03 Civic Hybird Check Light Engine
  72. Keyless entry module
  73. 01 Civic EX Catback/Headers
  74. Why does my clutch make a tweeting noise (yes, like a bird)?
  75. 2005 honda civic issues w running properly
  76. Type EM2
  77. Projector housing with HID setup
  78. tuning options k24/k20??
  79. I need help guys.. sell my EX and buy back my first car?
  80. 01 lx sedan wheel off set
  81. Extra headlight?
  82. Automatic Transmission Filter for 2001 Civic LX
  83. 02 civic headlight
  84. Gas Tank Capacity
  85. handling issues
  86. Door Panel Removal.
  87. Socal/Norcal Beach Meet Pics 6/27/2009(56k no way)
  88. stupid question (where does this go lol)
  89. Radio/Keyless Entry Question
  90. New motor/Build Thread w/ pics D17.
  91. Help! Need height template for 01-03 oem side skirts.
  92. do white coupes not come with black interior
  93. What rpm do you guys shift at on a normal basis?
  94. Fog lights for my 01 lx Sedan
  95. turboing a auto what do you think
  96. flywheel nut size? + clutch
  97. Need help on 03 civic hybird
  98. Does the 2005 EX Special Edition instrument cluster die easily?
  99. Racing seats in an em2? help!
  100. engine modification
  101. troubleshooting ECU
  102. 01 civic engine swap with a 05 engine
  103. Help!! water in fog light
  104. 2002 honda civic lx
  105. front lip help
  106. Where was my car made?
  107. Type-r / Mugen side skirts for 01-05??
  108. optima or duralast?
  109. car keeps shutting itself off then right back on
  110. Ex or Si which do YOU like?
  111. Power steering whine and foaming fluid fix
  112. Installing CAI on my 01 Civic EX?
  113. Are These Bushing Bad?
  114. what kind of fluid to put in my d17 trans?
  115. Transmission Bell Housing Removal
  116. Help!! Cant get my trans to split/get out!!
  117. WHO Has a 2001 Civic Auto. about install
  118. Aftermarket Radio Removal DIY
  119. NEED HELP ASAP
  120. OEM/Aftermarket Front Grille for 04-05
  121. 03 civic hybrid need help with my radio code.
  122. Do I have to drop my subframe for a clutch job?
  123. 2003 Honda Civic Hybrid - blown gas engine - A coupe of ???
  124. New headlamps and HID kit, need assistence in choosing
  125. obd codes
  126. hey im new
  127. Driver Door Lock
  128. transmission oill change.
  129. 17" rims too big for em2?
  130. Rate These Parts
  131. Axles
  132. engine dies momentarily
  133. what control arms
  134. Changing engine mounts on 02 LX
  135. Jack Points
  136. A/C working Intermittently! Some days hot! Some days cold! Searched!
  137. Crank shaft position sensor..
  138. 01 LX Battery and Fluid Dash Light Problems!
  139. 2005 civic coolant concern
  140. Timing Belt - Mileage or Years
  141. Anyone know where I can by a new A/C vent?
  142. Want to tint headlights and tail lights.. need input
  143. BORPOWER
  144. '99 Honda Civic D16y8 transmission on a 2001 EX?
  145. Will 09 HONDA Fit 16'' rims fit 03 civic coupe?
  146. Type-s Cluster In 2002
  147. em2 grille
  148. flywheel
  149. would an 04 coupe grille fit on my 02 sedan ?
  150. help on trunk spring
  151. 01 Overheating again... i drive it for a living need HELP?!
  152. Interested in buying an 01, but heard of transmission problems
  153. windshield & cowl ?
  154. Need help with hub/axle asap!!!
  155. How can you tell if your wheel bearings are going out
  156. Are short shifters worth it on our ex's?
  157. removal of bearing for wheel studs?
  158. Shifter Issue
  159. problems with tranny
  160. shifting issues
  161. Rear Engine Mount
  162. is VTEC really engaged?
  163. 05 Civic Blower Resistor
  164. offset on wheels?
  165. es1 side skirts
  166. Spilled Coolant from overflow? why?
  167. 2002 civic cassette removal?? help?
  168. Which rotors are my options?
  169. Official 7thgen destruction/carnage thread!!!
  170. supplemental restraint system indicator
  171. ► Official EM2/ES1/ES2 Picture Thread
  172. Product Review: Skunk2 Shift Knob
  173. Can I swap tranny internals to fix my woes?
  174. OBD2 port location
  175. how can i get my civic to throw a cel?
  176. D17 Intake manifold...
  177. would a 2000 civic bodykit fit on my 02 civic
  178. installing ebay fogs and check engine light turns on
  179. My Build Thread
  180. Oil pan gasket?
  181. Replacing stripped oil pan
  182. It's time for a change...
  183. VTEC System Causing Transmission Issues??!?
  184. Car Wont Start
  185. P0401 EGR low flow code
  186. ► June 2009: For Sale / Wanted to Buy
  187. B series motor?
  188. Squeaky sound coming from engine
  189. 2002 sedan overheating +picts
  190. lx to el?
  191. How do I pull SRS codes?
  192. Fugita Cold Air Intake on K-swapped EM2
  193. M/T shift knob choices...what fits, what doesnt?
  194. Where to find 01+ civic part out's or transmissions
  195. Air Intake Question
  196. Pulling SRS codes?
  197. reset engine code 03 civic
  198. Redfox2012 Build Thread
  199. 02 Honda Civic Engine Knock while speed maintained
  200. 2001 sedan swap ideas
  201. Bad Alignment?
  202. My hvac doesn't work.. dash was removed.. help!
  203. k24 swap best place to buy
  204. Will a 2008 Civic Si 6spd fit my 2005 EX 5spd?
  205. Removing the rear brake drums on a 2001 Honda Civic EX 4-Door
  206. Dealers Cost
  207. Fly wheel catches
  208. Almost dies near redline
  209. A/C ISSUES
  210. How to remove 03 sedan tail light?
  211. Power Window Help
  212. help! get spark plug seals out!
  213. 2005 Civic Fuel Pump Broken? Stranded Memorial Day Weekend
  214. red H badges
  215. 01-05 civic 4-1 header İnstall
  216. clutch kits
  217. automatic transmission problems
  218. installed KMS intake manifold
  219. D17 intake manifold question
  220. Stuck on removing upper timing belt cover.
  221. The Night I cleaned my Car...
  222. Can i Remove power steering?
  223. Whats the best way to get away with the Governor ECU
  224. using a tow dolly
  225. Power locks work when running, but...
  226. 2001 Auto transmission problem
  227. bulb size for hid's?
  228. engine noise?
  229. '03 Civic engine swap
  230. transmission and steering
  231. can i replace my door lock with aftermarket?
  232. My Build Thread
  233. Starter issues..
  234. intermittent/blinking battery light
  235. Sudden shut down
  236. Replacing brake pads
  237. Dash electric issues, please review!
  238. 2002civicrider's Build Thread
  239. 07+ Civic Si
  240. Steel Braided Brake Lines
  241. taking out rotor problem
  242. overheating problems?
  243. lip kits
  244. Civic Supercharger question
  245. k20 swap in 02 lx
  246. Looking to buy a new honda
  247. symptoms of a bad computer???
  248. 2001 civic coupe RS grill
  249. engine problem
  250. Knocking Noise......
