PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. 2002 Civix LX AC not working
  2. I need a front axle CV boot
  3. Flickering headlights and speedometer
  4. 30 LX ECU into a 03 EX... Temporary... will it hurt the car, ECU or throw codes
  5. EP2 Unusual Distributor Question
  6. delete/bypass 05 honda civic ex ecu variable timing solenoid - 1.7l engine
  7. CEL not coming on at all
  8. 6th gen AT on a 7th gen?
  9. Help please! Drive circuit problem/ temp gauge not working-03 civic ex A/T
  10. 2002 civic over heating/no interior heat mystery
  11. Owner
  12. 1.7 cam seal ring
  13. Check Engine Light Help
  14. 05 EP3 - Xenon lamp recommendation
  15. Civic 2005 rpm idle problem drive light goes off and on
  16. Transmission won't engage any gears once warm
  17. New to me 2002 Civic Coupe, some questions
  18. cant find where the oil is coming from
  19. Aftermarket oxygen sensors for 2002 Civic SI
  20. Bumper swap 05 civic coupe
  21. 2003 Honda Civic Hybrid Headgasket question
  22. Anyone know where to get entirely clear tails for a pre-facelift EM2?
  23. Tapping/Rattle after acceleration and into Idle...Then it stops
  24. Cooling Issues, with a new feature!
  25. S2000 AP1 cluster swap on em2
  26. ECU Question
  27. P0118 and P1298 what to check next?
  28. 02 Civic OBDII not reading, immobilizer key flashing, no start.
  29. 2003 Honda Civic, Fluctuating temp gauge
  30. Engine codes
  31. 01 Civic misfire and cooling fans always on
  32. Tool Needed to Write VINs to ECUs
  33. Radio code
  34. What to watch out for with a 2005 DX Sedan
  35. Starter relay issues
  36. I scooted my wheels outwards 1 cm
  37. Fitted skunk 2 manifold
  38. Alternator Charging Issue
  39. O2 sensor wiring help!!
  40. 05 civic lx green key flashing on dash help??
  41. Replacing Struts
  42. Fuse good, but no taillights or "small lights" interior, dome, map etc...
  43. 2005 civic k20z3 swap
  44. Clutch Knock or Rod Knock
  45. Overheating/No cabin heat
  46. Door panel swap?
  47. Purpose of Plastic Plug above Hood Latch Cable?
  48. 2001 honda civic lx crank no start
  49. New headlights - any way to avoid removing bumper cover?
  50. plz help
  51. Honda civic 2005 ECU pin out for manual transmission
  52. AfterMarket Fan thermostat sencor switch
  53. Honda coolant type 1 and 2
  54. Coolant
  55. Ignition Swap problems
  56. Where can I buy an audio 14-pin harness?
  57. Passenger side leak
  58. convert to inline fuel filter from in fuel tank filter
  59. 2004 honda civic ex battery drain problems that cause car to die while driving
  60. 2005 honda civic high beam stays on even when switch is off.
  61. Correctly adjusting timing gear.
  62. 2001 Honda civic LX is hard to start only when motor is cold
  63. 01 Civic Keyless Entry
  64. remove foam near passenger footwell
  65. Ignition key and switch won't turn on
  66. 2001 Honda civic LX starts hard when cold
  67. Key works for ignition but none of the doors (2004 civic DX)
  68. Alternater not charging on 2001 honda civic LX
  69. 2004 Honda Civic EX engine overheats when I turn on heating or AC
  70. 2005 Civic LX rough idle and misfire when accelerating
  71. Honda Civic 2004 Ex
  72. 2005 civic ex Ecm help
  73. em2 d17a2 thoughts on making it tuner-capable
  74. 2003 Honda Civic LX in Avon, Colorado
  75. Loosing coolant
  76. 2003 Honda Civic cylinder misfiring question
  77. 2005 Civic VP Immobilizer Purgatory
  78. EX Vtec Head to LX Issues
  79. Need Help Identifying Wire
  80. Front Boot Axle
  81. Power Steering advice, wont stop leaking
  82. 2004 Honda civic si clutch pedal not smooth (sticky)
  83. 2004 Civic Shifting issues
  84. 05 Civic D17A2 Won’t Rev Past 3K RPM
  85. Anyone Know what this weird orange cable is?
  86. 2004 civic EX ECU swap?
  87. D16v1 random power loss/hesitation + extra
  88. what would you do
  89. Help!!! Blowing coolant out !!!
  90. Does the shift boot from a 94-01 Integra fit a 7th gen civic?
  91. 2003 Civic Factory radio need to replace speakers
  92. Weird Issue With Cooling System
  93. fluttering
  94. clutch help needed
  95. Replace 2003 Honda Civic ex OEM radio/cd used
  96. Intermintent & Inconsistant Charging
  97. New Radiator and overheating issues
  98. please help 01 civic 1.7 225xxx crank no start (low fuel)
  99. D17A1 mystery o ring
  100. Coil keep getting burnt up
  101. 2001 Civic ex gas smell from rear.
  102. new to this model, short throw shifter
  103. Complete Vehicle Inspection
  104. bent valves?
  105. Transmission issue AGAIN!
  106. 7 th Gen models
  107. 2001 civic ex 1.7 bxma
  108. Oversized Oil Filter
  109. Need some expert advice
  110. Faulty immobiliser Honda civic 2002.
  111. No clutch pedal pressure
  112. D17 trans bearing replaced now car stalls in neutral
  113. Help with more power
  114. 2004 Civic Rear Splash Guards
  115. Headlights go out when brights turned off
  116. Bulb specs for headlight housing
  117. Motor Vibration in drive and with AC on. Also a code for slight fuel emissions vacuum
  118. Civic 2004 oil lamp display
  119. Honda Civic 04, Do i have PGM-FI?
  120. Code 15-2
  121. 02 Civic transmission went stupid HELP!
  122. Civic 2004 1.6i shaking issue
  123. Tuning Questions
  124. Dont know where to start..
  125. Goin a bit batty over grills
  126. Code P0336 crankshaft sensor A circuit range/ performance
  127. Are EG coupes and EK coupes roof the same?
  128. What to use for repainting door window trim?
  129. Wiring Help 2005 Hybrid K-Swap
  130. Low oil pressure indicator 2005 Civic
  131. Eu1 keyless entry issue
  132. D17a1 transmission swap
  133. 2004 honda civic dx coupe 1.7l sohc
  134. Car dies all of a sudden while driving
  135. cost of an engine swap?
  136. Crank no start - STUMPED
  137. Crank no start - REALLY GETTING TIRED OF TYPING OUT THESE POST.
  138. 2002 Civic A/C troubleshooting
  139. 2003 Civic LX 126K miles. Shaking ONLY during cold startup ( Cold weather only )
  140. Intermittent crank/no start. NO CEL
  141. Intermittent crank/no start.
  142. Will 95 civic clutch pressure plate and throw out bearing interchange with 05 civic?
  143. 2002 honda civic lx manual transmission 1.7 litre
  144. Ep3 SI Tuning
  145. Honda 2005 LX alarm/quiet beeping noise
  146. Head Gasket, Water Pump, Timing belt
  147. Transmission/axle issue?
  148. 2005 Civic whistling sound after cleaning evaporator
  149. 2005 CNG Civic V-Tec swap
  150. Knocking / ticking noise around timing cover
  151. Does anyone have fuel pump relay wiring shamanic.
  152. '05 HCH headlight moisture
  153. Help in hooking up Power Steering pressure switch to ecu
  154. Manual clutch bleeding 2003 civic ex
  155. Honda civic d16v1 sport 2005 manual 5 speed
  156. 2004 Honda Civic Ex Coupe 1.7L Overheating and Shooting Coolant out of Reservoir
  157. Coolant - Mixing the blue with the green
  158. Hellllp
  159. 1996-2000 HX Wheels on 02 Civic?
  160. Exhaust manifold gasket replacement
  161. 03 Honda Civic Lx
  162. Anyone have experience replacing a lock assembly?
  163. 2002 civic exhaust manifold
  164. Compressor fan won't turn off
  165. Transmission/axle issue?
  166. Delete the cat converter
  167. P0497 and no cat
  168. Fuel economy improvements
  169. 2005 Civic rattling/vibrations from cabin
  170. 2003 Honda Civic Engine SWAP
  171. CAT/ 02 PO132 PO420
  172. New Exhaust Manifold Glowing Red
  173. (advice needed) 2003 HONDA CIVIC EX how to check engine swap??
  174. Muffler suggestions 02 honda
  175. E10 petrol
  176. 2005 civic stripped mountaing stud
  177. 2002 no crank - Trans range switch? Troubleshooting help needed
  178. Manual transmission question.
  179. Can’t shift into reverse
  180. Car is being weird
  181. What the hell is this part? Found under hood (2004)
  182. Car is being super weird
  183. New here. What's up gang? Need some help, please
  184. 2004 civic ex 4dr ac problems
  185. 2002 Honda Civic D17a1 ex Manual blown engine swap to a D17a2
  186. Help with beginning upgrades
  187. 01 Honda Civic Clunking/knocking noise from front end
  188. Loud buzzing sound
  189. Issues with srs light in eu model civic
  190. oxygen sensor questions
  191. Scraping noise only sometimes when I accelerate and check engine light issues
  192. Vertical cylinder scratches, and color changing head gasket
  193. Engine struggles to accelerate.
  194. Undercarriage LEAKING WATER?!?
  195. atf for 03 civic
  196. No CEL random misfire
  197. 2003 Civic LX Oil Pan
  198. Cruise Control Not Working
  199. D17A1 ring end gap question?
  200. 2004 Civic vs Accord
  201. Power lock actuator, left side
  202. Civic ep3 airconditioning problem
  203. Ideas for a 2003 honda civci si
  204. CKP Sensor.
  205. Auto transmission RPM drop
  206. Car start right up but when I put it in first gear it just roll back
  207. 04 Honda Civic EX coupe stalling
  208. 2000 honda civic lx D16y7 non-vtec Car wont rev past 3500 rpm engine code p0335
  209. 2002 Civic SI hatchback: AC compressor replacement, receiver-dryer replacement
  210. Anti theft I think!?
  211. Weird electrical issue with under hood relays
  212. Sputter After Letting go of Gas Pedal
  213. Low and high pressure switch location
  214. axle
  215. Transmission Filter
  216. P0502, 04 civic ex coupe
  217. Engine won’t turn over but keeps making a sound like it’s trying
  218. 2002 civic with k20z1 swap issues, plz help
  219. 03 Honda Civic LX, Sounds awful...
  220. VTEC Solenoid or something else?
  221. Is this coolant reading normal?
  222. Can I swap the guts of a EBay remote into the OEM remote
  223. PRA ECU Pinouts
  224. crack on manifold near A/F ratio sensor. 2004 honda civic LX
  225. TÜV approved headlight assemblies?
  226. 03 Honda Civic cylinder head issue
  227. Power fault to ground in reverse lights
  228. Upgrades for d16a1 on an 03 civic lx
  229. Intermittent rough idle and driving bog.... happened after rain.
  230. Issue with Honda Civic Ex 1.7 Vtech
  231. Wiring diagram
  232. 03 Civic 1.7 5 speed. Help?? Thinking leaked seal or cam issues
  233. coupe trunk lid fit sedan?
  234. Bottom End D17 issues
  235. D2 lowering springs 7th gen ex
  236. Crooked rear wheel
  237. Steering column swap help !!
  238. Difference in models?
  239. New clutch not engaging
  240. Rear windows dont work
  241. 03 civic lx, cooling fan/head gasket issue
  242. Walmart vacuum oil change??
  243. Crank no start?
  244. 04 Civic won't crank
  245. Strut replacement, should I also replace inner tie-rod?
  246. Engine Swap(s)
  247. 2002 Civic LX brake line flare
  248. Should I change the fuel pump since the pump/filter is one assembly?
  249. Intro/ battery not charging
  250. Cam pully bolt torque
