- Problem removing spark plugs from 2005 Civic
- 02 Civic 1.7 P1259
- Engine Sound
- 2001 civic EX drivers rear window inop
- D17A2 Unknown Sensor
- Voltage issue?
- Throttle body upgrade
- Help finding my IAC Valve - Civic Ferio 2002
- 2001 civic sputters
- time belt replacement
- 2002 honda civic sedan with 1.7 vtec engine
- 2001 Tranny decisions
- CEL coming on briefly, cylinder misfires. Need advice
- Head lights and instrument control lights flickering
- 2003 civic 1.7 goes in limp mode at 3500rpm
- carbon on piston??
- Electric power steering problems! help!
- 2001 Civic LX w/ 99 Valve Cover...WTF???
- 2003 Civic Hybrid -- Starter issue?
- Civic: 6th gen vs 7th gen
- 2002 Civic EX P0420 California CAT
- SRS LIGHT
- annoying bogging 03 civic ex
- Type A Side Skirts &&& Splash (Mud) Guards
- 2004 Honda Civic EX -- Heat/Overheating Issue
- 02 civic auto trans rebuild reverse stalls
- Is there any Sedan Owner running EP3R Suspension?
- how do I determine which tranny I have
- 2002 civic si coupe
- Electric Problem In 2004 Honda ES1
- Expert opinion/HELP on Rim size
- AT slipping on a 2001 civic
- Looking for a D17a2 Engines
- 2005 Civic CKP codes
- civic 2001 1.7 vtec
- 2002 Honda Civic ECM and Immobilzer
- Passenger side front parking lights won't come on...
- 2003 Civic HX P1457
- Creaking noise coming from front left side of car
- Strangest transmission I've ever owned...Please help!!
- Limp mode - aaaaaargh!!
- Honda Civic 2004 has no electrical power
- Tired of Driving in My Own Shadow - How Have You Dealt with 7th Gen Headlights?
- 01 civic lx crank no start please help
- tick noise
- D17A2 compression issues
- right(passenger) high beam does not work
- 2003 Acura 1.7 EL cold idle throttle problem
- Front Strut Tower Bar Fitment?
- Headlights are Dim Issue
- civic 03 plz help im stuck
- 04 civic coupe keyless entry questions
- 01 civic timing help
- 2003 Civic rear disc brake caliper compatibility
- 04 Civic Ex Vtec Problem---P2646
- 04 DX auto trans issues... help plz
- Thinking of buying a 2002 LX Auto...
- Squeaking when cold.
- WEIRD idle issue on my Civic
- Passenger Power Window Goes Down, Not Up
- Power Windows Delay
- engine control module
- Cylinder #3 firing issue
- Crossed Jumper Cables
- Hissing sound when clutch is pressed
- Dash Indicator for Turning Signals, Hazards, and Brights Not Working
- Dimmer Switch/Wiring harness question
- Honda Civic Coupe Ex Vehicle Outline
- Losing Oil
- Hide-away front license plate?
- Airbag light.
- SRS & Check Engine Light
- Wipers not working correctly
- DIY: Pass. axle seal
- AC indicator not turning on during HVAC self test
- 02 civic keyless into 01
- 2003 Honda Civic EX Sedan EVAP Code
- Having fitment issues, what would I need to do?
- 01 Civic LX auto transmission
- 2005 civic lx engine in a 2003 honda civic lx?
- 2004 Honda Civic Ex D17A2 Turbo
- Looking for hood bra for 02 em2
- 2001 civic hx transmission fluid?
- J series swap
- SRS light on all the time?
- Stock Ride Height
- Honda civic 2002 heater/ A/C not blowing hot or cold air
- oldschooling a 4 door
- 01 Civic LX gears shifting problem.
- Engine compatibility from 01-05 models
- 02 Honda Civic Ex Coupe - Smoking over 4,000 RPM
- 02 civic very weird transmission issue
- fuel pump relay?
- Fuel pressure
- 03 Civic LX automatic doesn't move in D4 or reverse
- Alignment Question
- Two questions, Fans and Overflow
- Cant find this part
- Magnaflow Headers with Catalytic Converter
- What is the better tranny to swap too?
- Over heating when A/C is on
- TRANSMISSION QUESTION
- Honda Civic 02 EX - Best Bang for my buck for service $1000 limit
- 2003 ex misfire
- Any EM2 Fitment issues for a K20A2 w/ RBC manifold?
- D15 header on d17?
- Replaced VSS and still doing the same thing!
- 05 Civic heat/cooling porblem
- Next Tranny Question...big one here
- factory alarm problem
- My Civic EX wont start
- why does hx get mpg?
- 2001 Civic power rack noise
- Internal failure of SRS power supply
- Car Won't Start, ignition won't respond, driver door won't lock
- 01 Civic DX cluster swap
- Adjustable valves on 1.7l ivtec ex?
- K Pro gains from I-E-H
- 2001 Civic - Swapped engine - Need Advice
- White Smoke from Exhaust and Overheating
- Won't start Battery is fine
- Ktuned kseries swap harness
- need help diagnosing leak 03 civic dx 5spd
- 2005 Civic Auto fuel economy issue
- Manual si tranny into a d17a2?
- 2002 Civic EX White 95K Miles - for $4200 -- good deal?
- honda 2001 ex
- new to honda
- 2001 Honda Civic Car Engine Trouble
- 2001 Civic LX Sedan Cyl 4 Misfire
- Oil + Oil Filter
- 04 civic engine noise
- fuel canister among other issues I need help with
- D17 Headers to Cat to Exhaust
- 1.7 EL engine match?
- New to this civic/tranny question
- keys
- DRL issue.
- 2003 Civic EX Died on Freeway
- 04 civic clutch replacement
- grinding noise
- Misfire
- Newbee buyer - Mechanical question
- Headlight HOUSING Problem...
- what items do i need to get? to fix my wheel problem
- 03 civic 1.7L vtec sputtering at 4000rpm
- cracked cylinder or head gasket
- 2001 civic starts but wont run. Already checked for Fuel and spark.
- First ever swap of H22 in a ES civic 2001
- Anyone ever have trouble installing LCAs?
- 2002 Civic Blower Motor problem - Or Not
- 2005 Honda EX 1.7 vtec
- Rims for 2005 lx coupe?
- 2001 Civic Blower Motor stuck on full
- hooked up a system car cranks wont start not battery
- 2002 civic electric fix
- wiring question on pin out
- Civic 01 Climate control not working
- 2002 civic ex, cranks and no start, after a few times will start
- 05 Civic EX Air/Fuel Sensor, Part # ?
- 2004 honda civic
- clutch pedal funny feel
- PLEASE HELP! 7TH gen transmission interchangeability
- Wrench for rear toe adjustment?
- Alarm problem w/ Honda Civic 2002
- 04 Civic EX Transmission noise/problems
- 2004 Civic LX Engine running rough following routine timing belt replacement...
- 05 Honda Civic dies [NEED HELP]
- Main Bearing In-Car Replacement
- a/c not working
- Crank Position Sensor Connector Needed
- 01 Honda Civic Alig Help
- Idle kill/new battery
- Non vtec to vtec neeed helps !!!!
- civic 02 EX- Manual
- intake manifold replacement
- Automatic transmission makes a tic when releasing the gas pedal..
- Heater Core/Coolant Issue(Weird One?)
- oil pan question?
- Oil leak under intake, on transmission? *PICS*
- Ideal header and exhaust setup?
- 2004 civic lx over heating leaking fluid and wont start.
- Civic 2002, rear window manual crank issue
- 2002 Civic EX won't start
- RPM Jumps after head gasket replacement
- hit the curb... hard
- no clutch pressue 2001lx
- Alternator Prob / Fried ECU? READ THIS!
- Timing, idling - related?
- Engine "knack"
- front end swap
- 2003 Honda civic dies HELP
- no brake light
- 2003 Civic EX 5-Speed AC not working.
- Spark plugs fire late?
- 2001 Civic - Engine swap, now in Limp mode
- One Headlight Dimmer
- A/C wont work.
- ECU keeps frying! Help please.
- Headlights are pulsating......
- CAM Sensor Failing
- 2003 Civic LX, AC won't come on
- Supension 2001 Civic
- H23a1 swap
- Honda Civic 2003 EX 4dr - Electrical Problems
- 01 civic charge ligh
- 2005 Honda Civic - Rhythmic Sound While Driving
- 03 Civic hesitation with in first minutes of start up
- Jdm Question
- 2005 civic LX speedo inop
- New owner, looking at engine swaps.
- Timing belt Change, car wont start
- Rack and pinion replacement/repair
- engine speed inconsistency
- Looking for some tips Much appreciated!
- Need Help in removing Spoiler
- 2004 Rear Shocks/ Struts into 2002
- DRIVE BELT AUTO TENSIONER
- Exposed wires driver side mirror replacement
- 03 civic overheat now missfire
- LCA bushing replacement botch job
- Engine Codes: 0336 and 0338
- would 01 coupe shock & spring fit on 03 sedan?
- Ebay Master Key
- 02 civic ex ticking noise (video)
- what type of pads are oem
- Does this make sense - OEM Honda motor mount cost
- Can you put 4 door seat belts into a 2 door car??
- Help SRS 5-2 code on 2005 civic lx
- Window trim removal rear door
- Interior question
- d17- with y8 q&a
- DRL
- 2001 cluster sticking?
- motor mount question
- Squeaking belt when ac is on
- AC Dilemma
- 2004 Honda Civic VP engine swap?
- did i fill up too much oil??
- Oil Pump Leak / Rebuild Question
- 2002 Cat question.
- Window motor swap?
- K20 swap or newer car?
- High Beam lights
- 2003 Civic DX - Exhaust questions
- Swapping in a new engine
- Accelerating too fast = car stutters
- what is this noise at idle (video)
- 2002 Civic Ex P1362 / P0420
