PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. My Build Thread
  2. turn signal lights
  3. Car Bucks Forward
  4. body side molding for 4dr sedan?
  5. Rear main seal
  6. rsx subframe
  7. My Build Thread
  8. wheels butterflyin!!
  9. type s 5 lug and AWDB conversion
  10. Diagnosis please, 2001 honda civic ex
  11. Helppp!!!
  12. best header
  13. which k-seris would be betteR?
  14. polyurethane bushing problem
  15. help!! need help with removing factory cd player
  16. DC5 parts swap
  17. Euroboot
  18. Removing Rear Speakers
  19. k20 automatic swap
  20. Key light in cluster remains on..
  21. 2001 honda civic trouble please help!!!!!!!
  22. 01 to 04-05 front end swap
  23. Honda civic 4dr lx modds
  24. 2001 civic ex automatic transmission
  25. Steering Wheel Question
  26. anyone have this problem?
  27. making a funny sound
  28. 01 Civic Coupe And Sedan Headlights Interchangeable?
  29. SCANGAUGE 2 CUSTOM INSTALL
  30. Compustar System
  31. rear chamber kit
  32. Alignment question....
  33. popping noise coming from front suspension
  34. 1.7 EL Seats In An EM2
  35. HEY GUYS, I NEED YOUR OPINION PLZ HELP!!
  36. OEM lip kits
  37. Need help!! TDC for CAMBELT CHANGE
  38. Auto Window Down Switch
  39. Replacing the Steering Colum Cover
  40. 2001 Honda Civic 4dr LX
  41. 01 civic door panel
  42. '03 HCH engine redlines after O2 sensor change
  43. transmission problem!
  44. em2 window Visor
  45. HID Lights On A Projector
  46. Dimming lights.
  47. k20 ecu
  48. k series axles
  49. Intake Manifolds
  50. big problem that i cnt figure.. need help
  51. 53 plate civic braking noise
  52. 2004 Civic 4 cyl will not start
  53. rims boot
  54. lip kit
  55. front grill
  56. Car drives like a dream now.
  57. Brake shims
  58. dei 530t
  59. JDM Style Fog Lights
  60. $950 Dollars(Suspension)
  61. Can these coilover fit my car? need answer ASAP!
  62. quick question about kyb
  63. auto to manual swap??
  64. Good exhaust system for a 2005 honda civic lx / 4dr?
  65. Ordering a OEM front lip 01 civic sedan
  66. Stripped air bag bolt
  67. black housing with amber blinkers
  68. ebay black out headlights
  69. rear roof visors
  70. oil change!!!
  71. Unable to build up boost
  72. FAQ: Maintenance Schedules
  73. 02 front end conversion
  74. Want info about hyrbid k-series
  75. 1993 civic intake fit in a 2002?
  76. 2004 civic wiring harness swap..
  77. Driver Side Front Window off track
  78. 2002 4 door LX intermittent dash lighting problem.
  79. DIY: DC5 Cluster Conversion
  80. Questions
  81. reset maintenance req d light
  82. Slider pin mistake? Spongy breaks now.
  83. type-s suspension on a 2001 civic
  84. will these fit?
  85. Brake Kits
  86. Suspension question
  87. Help...Top strut bolt seized...what can I do to loosen it
  88. Springs or Struts or Coilovers
  89. 03 Civic 556h and viper 5900
  90. Picked up an 01 civic LX sedan..couple questions
  91. A few questions.
  92. Thinking about a Stabilizer Bar for 03 civic
  93. My Build Thread
  94. which springs should i get???
  95. CEL throws out code P2227
  96. seatcovers for 02 LX
  97. Malfunction indicator light
  98. Windshield washer light
  99. 02 Civic Service Check connector?
  100. recommended oil to use for a oil change?
  101. any one dropped on tein s-tech? i need pics?
  102. Key won't turn in door lockhttp://images.honda-tech.com/icon/1/ques.gif
  103. resetting trip meter in 01 civic ex
  104. Front bumper
  105. HELP!!! My 01 civic ex coupe seems like it has no power
  106. Thinking about putting a AIR INTAKE in a 03 coupe
  107. hid question
  108. Some questions about Hybrid Parts
  109. Temperature Indicator
  110. Car Alarm
  111. MT Oil
  112. how long should a average honda clutch last?
  113. want to know if the civic 01 can hold street slick
  114. 2002 LX Check engine light on and reads a P1298........
  115. Engine Light on dash
  116. gauges
  117. 04 EX Maint. Required Light Blinking on startup
  118. Engine oil
  119. Where is the fuse?
  120. weak performance, bad gas mileage, "chug" sound when accelerating
  121. What kind of lip is this?
  122. Rotor retaining screws not there
  123. AC will not turn off
  124. Reving problem
  125. Misfire DTC codes
  126. gc n kon problem
  127. Great! Another weird noise...
  128. Idle Adjustment screw
  129. interior
  130. Keyless Entry Location
  131. loud knock.
  132. coolant spraying out of the reserval. what can be wrong? pls help!
  133. 2002 Civic - OEM head unit accept something to play iPod ?
  134. 01 civic ex coupe power lock problem
  135. Are there LED replacement bulbs for stock taillights?
  136. Clicking/clunking noise?
  137. Radiator fan not comming on? coolant sounds like its bubbling? helppp
  138. 02-05 Civic Si Grille
  139. LED tails swap
  140. HIDs!!!
  141. Engine Swap 2003 Honda Civic Lx
  142. Buying an 01 Civic EX... need some modding help!!
  143. Splash Guards Contact w/ Fenders = Rust...
  144. dash has the picture of an engine lite
  145. Maint Required Light Blinking???
  146. need help....where should i get my EM2 dropped 1.5"?
  147. 2003 civic center caps
  148. o sigh..my new 2001 honda civc ex
  149. projector headlights for 01 civic
  150. noob question: what is a civic RS?
  151. Type R lip Fitment
  152. 4-1 Dc sports Header
  153. Exhaust Backfires??
  154. 2002 Chip
  155. 2005 Honda Civic gas cap
  156. Airbag Light
  157. might be buying an 05 lx and i was wondering...
  158. Trying to convert tachometer signal.
  159. Driver Side Tail Light Replacement
  160. AEM FIC VS GREDDY EMANAGE....
  161. rear toe adjustment?
  162. EXAUST SCRATCHING NOISE
  163. clutch is shot
  164. Dead 2002 Civic EX, Jump Starts Fine. New battery, alternator checks out.
  165. 2001 to 2005 Hotness
  166. what clutch should i use for my k20 turbo
  167. Header for D17A2 MT
  168. 2005 Civic A/C question - Help?
  169. Rim Fitment? calling em2's with wide 17' inch setups
  170. Does Royal Purple Make MT Fluids?
  171. help identifying this sound
  172. Trunk release problem
  173. 2002 Trunk Lid
  174. Speedometer problem, 2001 civic dx, 2 door
  175. does a CEL for the VSS affect engine performance/effenciency??
  176. Usefull DYI
  177. Custom Door Panels
  178. d17a2 oil press sensor wire
  179. Fully Synthetic Oil?
  180. Question about my 01 ex trany
  181. Screw Covers
  182. What is supposed to plug into this?
  183. 3rd gear pops out of gear.
  184. car cover
  185. Picture Request - Slanted Exhaust
  186. Boost'd 04 ex Help!!!
  187. I screwed up my oem headlight wiring. need help
  188. Problem with Eibach Pro Steet S Coilover/Spring
  189. S2000 steering wheel
  190. adjusting tie rod ends
  191. steering wheel off-center after strut install
  192. why is my car overheating when it was fine this morning all of a sudden?!
  193. Need help on a couple things 04 boost'd ex
  194. bucket seats
  195. '01 Civic Vtec (1.7L) coolant overflowing...
  196. d17a ecu
  197. Noise in back suspension
  198. RS front lip
  199. 04 front end conversion
  200. need help for radio installation
  201. Question About Stock Lip
  202. Lower tie bar for 2004 boost'd civic
  203. Removal of carpet / rear seats?
  204. Do they make pedals for our car?
  205. I screwed up my oem headlight wiring. need help
  206. ebay lowering springs
  207. Gauge set conversion
  208. compliance bushing diy help
  209. anyone proped up their hood?
  210. d16 intake manifold on a d17?
  211. Intercooler piping route
  212. amp power cable question
  213. what kind of intake is this ?
  214. tail light problem
  215. how much hrp can you get out of a d17?
  216. Need Good Headlights Replacements
  217. 2001 honda horn
  218. can a type-s ecu fit 01 civic
  219. car pulls to the left need some help ASAP!!!!!!
  220. Electrical Problem?
  221. Tac for my 04 civic vp
  222. Noobie quest about civic 2001-2005
  223. Em2 still blowing air even when the a/c switch is turned off
  224. Stereo gets FM, just static for AM.
  225. please help me 01 turbo civic is running to rich
  226. clutch bleeding issues
  227. S2K cluster in EM2...can it be done!?!?!?!?!
  228. LCA / Compliance Bushings SHOT
  229. Double din navigation in 03 honda civic
  230. Eibach Sportline lowering springs 01-05 Civic...also need help on struts
  231. OverHeating issue
  232. I want to lower my EM
  233. grills
  234. DC race header
  235. How Easy is to Change a front Fender
  236. clean car?
  237. Need info for rear shocks please!
  238. Our 2001 Civic Airbag explodes steering column during accident, Bag ripped from steering wheel?? Pos
  239. Looks like my subframe is missing bolts??? Pics
  240. Help with emblems
  241. How to remove alarm from my car?
  242. Lowing a 2004 civic ex
  243. 2004 Civic EX problems when its warm out.
  244. Pic request: wheel options for satin silver cars
  245. clicking sound when turning right??
  246. 04 rear bumper to 01 civic
  247. RSX-S front sway bar
  248. Throttle Position Sensor
  249. Is it an EX?
  250. Questions about civic... please help a noob out
