PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. New guy, transmission question
  2. 05 Civic Hybrid Vibration
  3. Door panel removal... 2003 Coupe
  4. ~03 Civic Ex~ The smell of gas?????
  5. Is it okay to swap a 2001 civic ECU ? without consequences?
  6. 2001 Civic Broken Fuel Door Latch
  7. 2005 Civic ex fog lights
  8. Did anyone use Valvoline maxlife in their auto tranny?
  9. '01 & '04-'05 Ex Coupe Taillight Compatability
  10. Motor oil for a 03 em2?
  11. K swapped em2 laggy
  12. Fuse Box Causing Engine Problems?
  13. A few questions.
  14. Factory Alarm
  15. Help No ac or heat blowing out
  16. Burning oil too quickly
  17. 2001 HONDA 1.7L D17A1 NON VTEC
  18. Lone sensor, can't figure out where it goes.
  19. Bad tranny or bad synchro
  20. Location of fuel filter on 2002 EX
  21. Shifter clicking after brake inspection on '05 Vic
  22. Disable ELD on 2004 Civic LX?
  23. Quick spark plug question ...
  24. New head gasket
  25. egr question
  26. Rear Suspension - 'knock'
  27. engine damper help?????????
  28. whats my best bet for engine swap?
  29. Antone have custom door pannels
  30. tranny problem
  31. ES1 ex Auto acting up
  32. elecrtical power cuts out when key is in IG2 position
  33. Would the sunroof of a rsx fit on my 01 civic em2 2door
  34. would rsx steering wheel fit on my 01 civic em2???
  35. 2001 civic ex coupe, revs up and down at idle, P1259 CEL, please help...
  36. 04-05 civic automatic trans fit 01 ??
  37. Gauge questions
  38. Are these spark plugs worth it?
  39. 04 Ex build / overheat issue?
  40. would rsx doors fit on my 01 civic em2???
  41. 2004 2 door civic fog lights help
  42. Do they make 4 lug to 5 lug adapters??
  43. Headlight switch help.
  44. Need help with a k20a swap
  45. Battery Light On, Alternator & Battery Replaced
  46. ► (/´Д`)/ _ FAQ request/suggestion/addition thread
  47. HELP em2 01 civic ex
  48. Popping noise when I accelerate
  49. In fear of blown headgasket
  50. 2001 honda civic
  51. Car Starts but Stalls Instantly...
  52. will this oem honda em2 cd player/ tape player work on my 01 em2?
  53. 2001 Civil LX cat manifold
  54. 2004 Civic Ex overheats/trouble starting
  55. Hybrid Folding Mirrors
  56. honda civic 2004 lxi funny sound
  57. Frontend Knocking with no visual problems
  58. 2001 Civic OBDII Scanner wont read.
  59. SRS Problem
  60. Seat Rails
  61. Rear disc w/4 lug???
  62. Stripped wheel studs
  63. worried about oil in coolant civic 2005
  64. Roof rack Question
  65. 2005 Civic Ex, Location/Replacement of Knock Sensor
  66. My mech says I need a new TPS sensor, what should I do from here?
  67. B Series tranny to a d17
  68. 2002 Honda Civic Alternator Fuse Keeps Blowing
  69. 02 Civic EX - Heat not working properly, white smoke under hood, small radiator leak
  70. Trying to tighten my throttle cable
  71. bad squeel question
  72. 2003 hybrid, washer and fan problem
  73. car died uphill
  74. 2002 honda civic si
  75. What does EM2/ES1/ES2 mean?
  76. AEM FIC for my d17
  77. Right headlight Low/Hi not working
  78. CT Engineering Short Shifter?
  79. should i put dual exhaust on my em2,
  80. 2003 Civic EX won't start
  81. my es1 build
  82. Which folding mirrors will fit 03 Coupe??
  83. '03 Civic EX coupe A/C Heater Blower Mystery
  84. 03 civic gauges cluster and dash light issue?? NEED HELP!
  85. Tranny Grind and Electrical
  86. what will be the best swap i could put on my 01 civic lx
  87. Have Engine ID need to find VIN
  88. 2005 Civic Hybrid sensors
  89. 2001 civic lx build
  90. ECU/ECM or Immobilizer Question
  91. speedometer center console light bulbs?
  92. Can I keep driving my car if the Electrical Load Detector (ELD) needs to be replaced?
  93. ECU fuse keeps blowing..
  94. oxygen (o2) sensor target voltage 14.7 afr civic 01 dx stock narrowband
  95. 2004 Civic A/C Heater Blower Motor not working
  96. Type of Engine?
  97. Clutch noise - what's likely wrong?
  98. D17A1 what to do?
  99. thermisotor calibrations--iat and clt from '01 Civic DX
  100. Any opinions on clutch kits for our year vics?
  101. rear disc brake conversion
  102. Immobilizer Tripped
  103. D17A2 dual stage vtec?
  104. Would these civic hx rims fit my car?
  105. Upper-Lower Suspension Control Arm Problems?
  106. Civic overheats, multiple mechanics, same diagnostic, NO solution
  107. AllensEM2 (slow build :p)
  108. Brake Light Issue
  109. D17A2 Head 2 Block Torque Specs??
  110. SRS light reset.
  111. Bad Through out bearing
  112. Drivers side water leak
  113. program key hoda civic 2003
  114. How to differentiate Axle shake from Transmission shake?
  115. Burning oil
  116. Rsx Seats
  117. O2 Sensor Questions(purchasing)
  118. Transmission leak question & picture
  119. Speedometer & odometer not working after o2 sensor was checked
  120. What is the best manual transmission fluid for 2002 em2?
  121. How much to ask for an 01 Civic EX with no engine
  122. '04 GX - Gutless on any slope
  123. loud klunk noise coming from right side front
  124. 04 civic exhaust
  125. did i hydrolock?
  126. That Evil SRS light won't go away D: (Please Help)
  127. Help with my New toy
  128. Radio turns itself off then on again, SRS light too
  129. tucked em2 harness
  130. Overheating 2005 Honda Civic
  131. 01 Civic Auto Drive Light Out
  132. help identify these sides.
  133. hopefully someone has some useful info?
  134. 01 civic head gasket parts
  135. won't start no spark, no codes
  136. ES1 coilover buying???
  137. Blower Motor Fuse Location?
  138. 03civic hvac
  139. 2001 civic ex valve cover gasket replacement
  140. Window switch for 2001 civic EX coupe
  141. really loud thumping noise when i turn the wheel please help
  142. ► Official EM2/ES1/ES2 Picture Thread (1.1)
  143. EM2 Auto Stage 1 Cam Dyno
  144. fender bender! :/
  145. Door Lock problems!!! HELP
  146. Fresh Tune up Problems
  147. exhast manifold 2002 civic
  148. wheel bearing replacement problem
  149. Transmission Replacement Advice
  150. Whats this engine?
  151. h22a swap in a 2001 civic?
  152. 2003 civic starts, but dies right away
  153. Where is the PCV valve on a 2005 Civic LX?
  154. Honda Civic Hybrid: Transmission Problems: Won't honour extended warranty
  155. Codes 1298 and 1457 2002 CIVIC Sedan DX
  156. 2004 Civic Power Steering Issues
  157. timing belt
  158. 01 Civic Automatic Transmission HELP
  159. 2003 civic hx front struts
  160. Power window problems...
  161. mileage correction help
  162. DOES A '95 D17 TRANNY FIT '01 D17
  163. Does a 03 civic hybird front bumper fit a 01 civic Sedan?
  164. 2005 lights on a 2001?
  165. Type R Grill
  166. Clutch not engage it make rattle. Clutch in, don't rattle
  167. $200 Civic
  168. Civic SI all in one Key and Remote
  169. 03 HCH replacing cooling fan motor -- how hard?
  170. Is it worth the drive?
  171. Civic 04 manual transmission rattling noise -- Please Help
  172. 04 Civic PCM replacement
  173. D17A1 vs D17A2
  174. stock manifold!!!!
  175. ECU pins
  176. 2003 vents
  177. First issue since new with 05 civic-grinding on throttle liftoff
  178. 04 Front Conversion Wiring
  179. Help! 2001 Civic LX Check Engine Light, Won't Accelerate, Burnt Smell from Hood
  180. BMXA problems...Advice needed
  181. Single click in first/second gear. Manual Trans.
  182. missing motor mount bracket
  183. Throttle Position Sensor or something else?
  184. 2004 Honda Civic Hybrid Oxygen Sensor Recall?
  185. 2001 Civic LX Rear Wheel Problem
  186. Humming noise, either axles or tranny.
  187. CIVIC VTI 2001 ABS LIGHT NOT GOING OFF
  188. hybrid
  189. Set TDC
  190. Removing center console
  191. EM2 J32 SWAP-POSSIBLE??????
  192. k-Pro for EM2/RSX CONVERTED TO K-PRO
  193. Power Steering Issue (Stiff/Leak)
  194. 2003 Honda Civic EX P0300, P0302, P0301, P0303
  195. 03' Honda Civic Starts and immediately stalls
  196. Gearbox oil
  197. Civic with low miles began pre-detonating!
  198. Faulty Gauge Cluster / Failure
  199. RPM
  200. 01 civic coolant overflow question
  201. F20B in a 7th Gen?
  202. 2002 Civic tranny whir/whine when cold
  203. Civic Make Humming Sound
  204. 2003 LX can't figure out at all
  205. New with DIY; advice for my maitenance?
  206. OEM alarm question/problem 2003 civic
  207. Front End Conversion ? ? ? ? ?
  208. Car won't run
  209. Hi Dear
  210. 01 civic slight sputter problem
  211. 03 Civic EX start to over heat with a/c on
  212. Thinking about potentially buying
  213. 2004 Civic DX Passenger Airbag Cluster Light Help
  214. 2001 civic Multiplex control unit question
  215. what trans can i use 2004 honda civic trans
  216. Alternator on 2001 EX
  217. Properly Diagnosing A/C Problems? 2004 EX
  218. Diagnosing VTEC- Code P1259
  219. how to change a turn signal (hazards) relay: 03 honda civic dx
  220. 05 a/c compressor locked up
  221. Replace thermal protector on AC compressor
  222. 2002 Troubleshooting issues - P codes included.
  223. out of states honda??
  224. radiator/coolant fan spin?
  225. Sluggish acceleration
  226. ep3 5 lug
  227. possible 01 front end conversion to 05?
  228. Compression Test
  229. speed limiter
  230. Disable ABS and DRL's
  231. 2004 Civic dx coupe shaking when driving problem
  232. White smoke from engine and vents. Car stalled and will not start.
  233. HVAC DTC #12
  234. Installed new oxygen sensor now reads Code 134?
  235. Need radio code for my Civic
  236. Hit major pothole and now i have a loose steering wheel
  237. Need help Identifying an AC part!
  238. Intake Question
  239. Windor visors and other accessories inquiry
  240. Head Gasket Replace
  241. cant find a type r wing anywhere
  242. 2004 Ex Random Overheat - Coolant Overflow Filling Up
  243. squeal from rear brakes.
  244. AC problem, help please?
  245. No AC -> need PCM update or new PCM?
  246. 2005 Civic Hybrid noise on passenger side seems to be under battery
  247. Another 2001 TCC engine code
  248. 2004 Honda civic ex 5 speed. wierd issue...limp mode?
  249. engine and trans removal and install
  250. 2002 civic lx problems
