PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. 02 civic auto to manual swap
  2. In need of new bumpers
  3. Will 92-00 civic belts fit into 01 civic?? Can't buy D17 belts no where but Dealer!!
  4. 2005 civic LX 4dr smell
  5. 2005 civic LX 4dr, 2 rear breaks squeek all the time
  6. A/C system
  7. 2005 civic lx 4dr automatic transmission
  8. problem light in dash windshield washer
  9. No communication with scanner
  10. Timing belt on outside edge
  11. Lock Issue, security feature?
  12. Anyone has a write of how to adjust your E-Brake?
  13. 01 civic lx auto to manual transmission
  14. koni fail
  15. Need VTEC! help
  16. Location of ecu!??
  17. Door LOCK problem
  18. Diy: Rear Motor Mount Inserts
  19. Dealer options for 04/05 2dr coupe EX? (check out switches!)
  20. How-to trouble shoot DRL/day running lights??
  21. Thinking of purchasing 2001-2005 Civic Hybrid, questions inside!
  22. No parklights/daytime running lights
  23. what is this
  24. Where to buy fiberglass/resin?
  25. 15" steelies
  26. more gauge cluster help!
  27. EM2 K20a3 swap help!!!
  28. What kind of tranny oil for stick
  29. 96-00 B18B In my 2002 Hx will it work !?
  30. 05 civic lx light problems please help
  31. Oil pan rusting- 2002 honda civic - and some maybe big problems please help
  32. Why do I need a ECU/PCM Reprogram?
  33. Engine knock - I want to repair it myself
  34. K20 Auto swap?
  35. Transmission Range Switch
  36. 2001 civic ex knock sensor?
  37. **Pix Request**
  38. h23a prelude swap into my 2002 civic Hx?
  39. bad tranny?
  40. P1705
  41. OEM foglight switch indicator light problem (need help)
  42. Civic 04 VP manual - swap insturment cluster?
  43. 2001 Civic ex SWAP
  44. K24 swapped folks
  45. 02 Si issues
  46. Sunroof leak-may be seal
  47. DANGEROUS!!!Longest lasting Timing belt?
  48. making foglight switch on steering wheel??
  49. Power Trouble!!!! SOMEONE HEEEELLLPPPPP
  50. CEL 1362 replaced twice wtf?
  51. Scoop on OEM Alloy Rims?
  52. fully bolted?
  53. ~$750 to replace LCA bushings?? DIY tips please :)
  54. transmission bearings
  55. d17 d16?
  56. Rear Lower Shock Bolt
  57. Can't get the tie rod off
  58. code P1362 (TDC sensor *no signal*)
  59. Any One Good With Headlights?
  60. S2000 Brake booster and Master cylinder swap into EM2
  61. transmission question
  62. MY CAR BURNT!!!! Due to at converter!
  63. Stock wideband (And introduction)
  64. Do I have an alternator problem?
  65. 2005 Honda Civic EX Fuel Gauge Problem
  66. cel p0420
  67. How much does the shop charge you to change your clutch?
  68. WTF man.....another axle down...
  69. 2001 Civic
  70. right front knock
  71. Valve adjustment necessary?
  72. motor compression and leakdown?
  73. Vtec1.7 in to non vtec car
  74. Quick Ecu Question
  75. HELP!!? Auto to Manual Swap 01 civic
  76. Where to find replacement engine
  77. bright bulb in regular headlight
  78. help somthing on my em2 coupe
  79. srs unit location?
  80. need help with an em2
  81. Experience with Pre-Painted bumpers?
  82. $160 for replacement catalytic: real or BS?
  83. 04-05 Civic Coupe Yellow Fog Lights
  84. 2005 Honda Civic code P1416
  85. 2001 civic power door lock fuses?
  86. 2005 civic lx lights
  87. 5lug conversion question?
  88. 2004 civic lx manual transmission installation
  89. 05 Civic VP Tranny
  90. 2001 civic ex - reseting the ecm HELP
  91. 01 Civic EX failed smog.... HELP!!!
  92. intake question
  93. Dealership says I need my ELD replaced.
  94. Manual Service Civic 2003
  95. coil pack stickers\decals
  96. CANT PASS SMOG BECAUSE OF DRIVE CYCLE?!?!
  97. Clutch Master Cylinder Replacement help
  98. Buying 01 civic, Help me hondatech
  99. 01 Civic multiple problems
  100. will k20a2 be legal in an 01 em2??/
  101. problems with the 01-05 coupes?
  102. D17Y8 intake conversion to D17A?
  103. Brake light problem
  104. civic immobilizer bypass?
  105. 2002 Civic Misfire Issue
  106. need k series help!!!
  107. 04-05 Civic blacked out headlights
  108. Window Visors
  109. 2001 Civic seat questions... halp!
  110. question about front lip for honda civic 04-05 4dr
  111. it says for 1992-00 but will it work on a 2001-05?
  112. overheating
  113. Help finding a manual transmission 04 civic
  114. die out! scares me.. help
  115. Transaxle Issue?
  116. Please Read. Transmission Problems. Honda says it's my fault.
  117. Recommendations on an Alternator
  118. dc5 5 lug swap
  119. Got a Quote for Headliner Repair
  120. Engine knock only when motor is warm up
  121. Passenger side window
  122. 01 Engine knock...
  123. 03 Civic timing belt
  124. Quick question about EM2
  125. Plastic Air Vent Is Broken
  126. head gasket
  127. thicking em2 civic tell me what you think
  128. turbo em2 videos
  129. trouble codes
  130. upgrading rear and front speakers
  131. 01-05 coupe ex test pipe
  132. calling all es1 and es2 guru's (yes i searched)
  133. Strange brake squeak
  134. Car dies after 3 seconds!!
  135. Quick question about a 03 civic coupe ex
  136. Tranny 4th gear problem.
  137. Center Console
  138. How to access my dash?
  139. 02 AT Civic Sedan Auto Cruise kept on disengaging itself, please help T_T
  140. Shaved cylinder head advice
  141. es1 tail lights
  142. ABS
  143. Do hybrid mirrors fit a es1 ????
  144. Anyone have the write up for auto to manual?
  145. NAME THAT PART (WARNING: NOOB THREAD - UGLY & RUSTED ENGINE BAY - PIC INSIDE*)
  146. Bad Oxygen Sensor Advice Wanted.
  147. need help with power window
  148. Spoiler!
  149. 04-05 oem radio quick question
  150. front drive axles
  151. installing rsx bose sub in my es2
  152. Anyone else have a HFP EM2?
  153. Honda Civic 2001 hubcaps
  154. H.I.D question
  155. Can a TSX cluster fit in a EM2?
  156. Raising idle?
  157. need help on changing engine oil 01 civic coupe
  158. EX Coupe Trunk Lip
  159. Restain Black Velour Interior
  160. My Build Thread
  161. carbon fiber mirrors with signal lites
  162. 03 Civic LX 4-dr Whistle sound?
  163. 05 Civic OEM foglight install help needed
  164. are d17a2 interference motors?
  165. My Build Thread
  166. Temp rising, low coolant..?no leaks
  167. Help me! Inside door handle???
  168. 01 civic evap canister removal question
  169. Issues That I've Resolved
  170. 2001 Honda Civic Trunk Latch
  171. 03 civic cel on, misfire codes, need help
  172. 2002 civic a/c is on when turned off
  173. shift tack n mirrors on an 02 honda civic ex
  174. k series in a em2..I need your help!
  175. Empty Oil Filter
  176. Is my clutch shot?
  177. 01 honda civic ex engine build
  178. 2004 honda civic LX door handle paint chipping
  179. D16W1 Project Crover Stage2 Camshaft install
  180. Front bumper~
  181. 05 EX SE front and rear speaker size. yes i searched.
  182. Power window relay bypass
  183. Engine swap
  184. Double filament yellow parking light 05 civic
  185. seat swap?
  186. Winks MIrror install on 01-05 Civic?
  187. Anyone else regret buying their 01?
  188. 2001 honda civic ex chips
  189. Air conditioning blowing fog intermittently?
  190. Lx to Ex exhaust conversion problem with o2 SMOG
  191. Easy D16A swap help!!
  192. i got an RSX front clip, is it worth anything?
  193. any ideas what belt this is??
  194. Hammer-like sound when braking?
  195. MUD GUARDS!!!
  196. Driver side mirror replacement
  197. Vti (Indonesia, Middle East) 2001
  198. Aftermarket steering wheel
  199. Is my door ruined?
  200. Can the 04 sedan rear lip fit on the 04 coupe
  201. Parts for Honda in Miami, mechanic
  202. Need to replace old tires, em2 03
  203. What time civic 2001 -05 1/4 mile drag, stock
  204. what oil for a em2 2003, 104k miles
  205. Driver Side Door!
  206. Dimensions of Trunk
  207. locate: front bumper/lip
  208. 2004-05 Reverb rear bumper lip fit on 2002 si coupe
  209. New Short Shifter
  210. question about radio
  211. seat bracket
  212. SRS light won't reset 01
  213. Searched: vtec crossover 01 ex
  214. Illuminated ignition switch
  215. Did I bend a valve?
  216. *Urgent* clutch lost tension
  217. My build thread
  218. Civic ex Driver side engine mount
  219. Question for the Honda parts counter people
  220. Breaking an Engine Control Module (ECM)
  221. sedan bumper on coupe
  222. cleaning the rear window
  223. 04 lx coupe overheating and just replaced t-stat
  224. Car vibration problem
  225. 7th gen special HID retrofit made easy
  226. Jack and tool storage
  227. Should I sell my car, buy a clean hatch and a bike?
  228. Can't Locate Fuel Filter
  229. August 2009: For Sale / Wanted to Buy
  230. A/C went out on my four door
  231. Over heating problems in 05 EX
  232. Steering wheel hub?
  233. brake thump on front driver side
  234. Automatic to 5 speed conversion
  235. ES1 Full Service Tune Up
  236. changed cam plug now car is missing?!?!?! please help
  237. Loss of power and gauges in my 03 civic coupe lx
  238. Buying a New Honda Civic Need help
  239. start up problem on 02 civic ex
  240. Can someone post a DIY transmission fluid change
  241. k20 in our car is legal in california????
  242. Curious about offset fitment
  243. stage 2 cams?
  244. My ac and heater doesn't work... wtf?
  245. RSX seats
  246. ECU Wiring
  247. ECM/PCM on 02 honda civic
  248. Valve Ticking !!!!! PLEASE HELP !
  249. a/c problem on 02 Honda Civic
  250. 02 civic lx starter replacement?
