- 02-05 Honda Civic Si Needed for R&D
- DIY: OEM Fogs on with Parking & Highlights
- 01 civc coupe jdm honda badges
- '05 Civic coupe driver side mirror
- Eng mngt light displayed
- 2002 Civic Fog Light Install HELP
- bolt/screw/ thread size for License plate?
- possible tranny problem?
- Vtec Head Install
- Driver Side Door Lock Motor???
- Muffler Diameter?
- Fuel gauge not working propoerly...
- Again need help on my em2 lx for exhaust!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Removing Rear O2 Senor
- Headlights warning beep not working
- Passenger mirror for coupe (power) same for 01-05?
- I have an civic 01 lx,need exhaust pls help!!!!!!!!!!!!!!!!!!
- New used car...key won't unlock or lock doors..help!
- Need a new head on my motor. help me!!!!
- 03 civic tranny noise
- Civic Special Edition wheels
- Tranny Removal? Does the sub frame have to come out
- 01-03 mugen Rear lip
- Self-tapping screws
- K swap In Metro DC area
- Replacement Key
- Power window switch
- Plug identification help......drivers kick panel.
- Shift Linkage Issues
- car jolts back and forth
- honda idling problem? drops rpm??? need HELP!!
- can a steering gear/rack be adjusted?
- Seattle Anyone?
- 05 civic sedan fog light problem
- Just bought 2001 DX, Noise/Engine question.
- Loud ringing noise
- My Build Thread
- Looking to buy a 2001-2005 Civic....
- ECU Replacement help
- ES1 to EM2?
- Gauge Cluster Question
- HKS Hi-Power Exhaust
- consequences of a Bad ISB
- Keyless entry PROBLEM!
- Car Accident, hopes it's minor...
- can anyone help me with my o2 sensor
- anyone's ebay foglight harness melted?
- Gear Oil, 2001 dx
- Door pins have no power/no open door dashlight!
- 01 Civic fuse label
- bad vtec solenoid
- Window Help
- rear spindle nut socket size?
- jdm parts em2?
- Wing Mirror Issue HELP !
- Question about swapping engine?
- Keeping her clean during winter
- Hesitation when cold, near stalling idle.
- '01 EX Civic road noise - can this be reduced
- cluster temp guage
- key light on cluster is flashing...
- EM / EP Spring compatability
- leakin' in the cold
- High beams wont work
- Changing the Engine Cooling system??
- My car is acting up...
- Suspension question
- Seat Brackets?
- My 2002 Civic won't start
- Pulse Plugs
- Speaker fitment issues...please help.
- civic door?
- front lip help!!
- Any recommend a strong & quiet end link set
- ***D2 RS Coilover Install Help!!***
- Where can i find neuspeed race springs?
- Any OneEver Shop Here?
- how to install a push start button to our car????
- Axles nut sizes for ep3, em1, etc
- 5 speed transmission fluid?
- Civic 2002 Fog lights install manual??
- ABS Light + SRS Light = Electricals?
- windshield washer tank
- 02 Honda Civic - Trunk doesn't stay shut
- What size rims for ES1 LX?
- shift boot
- D17 turbo headers?
- 02 5spd, transmission problem in reverse
- What size speakers for ES1?
- Bridgestone RE760 A/S Sport
- em2 cf roof? might be possible
- "Check engine light" comes on when I turn on the windshield defogger
- cluster question
- Reminder for the Winter drivers
- 2002 Civic EX
- Which AEM Intake for MY 2002 LX?
- fuel pump
- Anyone in ChicagoLand Area Know Any Good Junkyards?
- Headlight dimmer
- Gas Mileage Gone
- **Strut Or Bushing?**
- EP3 shift knob question
- Help!!! car blowing freezing air!
- PeakBoost D17 prototyping
- My Car Wont Go In Gear 2 Reverse
- Damaged Sensor
- **what exhaust is this?
- neuspeed strut bar
- revvinggg..
- More comfortable seats
- 2001 Honda Civic Clutch
- Humming/Light buzzing noise
- AEM Cam Gear
- center-dash console! no-lights?!?!
- O2 sensor code P0134
- Grease leaking from CV outer boot
- speedometer sticking
- New to Honda - Looking for insight on the 2005 Civic.
- General Chat Thread
- Heated Spray Nozels
- Exhaust
- WHEEL BEARING noise Civic LX 2005 4door
- New Clutch question
- jack stand placement
- ***d2 rs full coilover questions***
- 2005 Honda Civic Front End Grinding
- 1.7el front end
- question about rims
- Garnish Light?
- installing hid...is this right? diagram
- Does the Antenna have a Relay?
- Upper Alternator bolt problem.
- Power window switch with SPAL Kit Help!
- projector lights
- Carfax unlimited?!?
- No air blowing through climate control
- So Whats Next??????
- Need tire size advice!!!
- side airbag
- Red suede door inserts.
- RSX heated seats in 01 civic si.. HELP!!!!!
- Radio lock...
- skunk2 shift knob
- leaky 05 sedan trunk..
- Problem, need help
- jdm recaro srd (red) fronts and us itr rears
- My ep3 Build Thread
- My Build Thread
- Wat kind of lips...
- Lights DIM.. When radiator fan comes on...
- which one works??
- Coilover Fitment
- Spark Plugs
- Hey guys...
- Keyless entry while cold
- vtec
- Hey everyone
- ebay jdm crystal headlights
- Key sign on dashboard
- K-swaps, Em2's, and California Smog codes?
- 2003 Civic LX Factory Code Won't work
- Alarm or factory keyless system that locks doors after you turn on the engine for 01?
- quite exhaust?
- OFFICIAL: Tanabe Medalion Concept G Exhaust for the 01-05 Civic EX Coupe!!!!!!!!
- Help!!
- will the rear ap1 rims fit in our car???
- error
- Power LOCKS NOT WORKING when Car off
- turn singnal issue
- coilover sleeves with stock shocks
- what lugs with drag 23 wheels
- What is this?
- Fuel Filter
- CTR Carpet
- my poor civic :'(
- em2 gearbox problems??
- need help
- 04 civic control arms
- Honda Civic Cold Air Intake??
- strut/spring setup
- Odometer messed up
- ebay rims.
- 4th of july Sac raceway run!!new set up
- the 6 number code for stock deck
- Exhaust Help needed
- My EM2
- 02 civic, clicking noises coming from the dashboard during startup
- clutch kit labor cost?
- ITR cluster
- i have an issue with my car..
- Help with EM2 parts
- new to civics. few questions help???
- Anyone turboing their 7th gen civic?
- dc5 steering wheel
- Lowering a EM2
- 2003 ex front suspension noise
- Question for those with Summer Tires
- Hey guys. 04 civic questions for my lil brother
- 5-speed tranny problems
- Ep3 Steering wheel vs S2000 Steering wheel
- What do you think of these reported problems
- Where to get Type R lips?
- xb rims on 02 ep3
- What is the different in from 1996/2000 to 2001/2005 year civic?
- 2001 Civic AC on all the time (not defrost thing)
- strut bar
- question on em2 and ep3
- Need help installing my Projector front light??
- EM2 FRONT GRILL
- Temperature gauge fluctuating...
- CIVIC 05 Special Edition Adapter KIT
- Hood Adjustment
- Batt or Alternator
- SMOG TESTING!
- Maintenance on 115k '01 Civic Ex
- k20a3 and k20a2 bolt ons are the same?
- just bought a civic.
- Mugen lip
- D17A2 turbo build help
- Battery Terminals
- driver side window off track
- Is the 04-05 backup bulb the same size as the 01-03 bulb?
- Random Sighting: Cupertino, CA. Girl neighbor w/ modded blue civic si
- Rims
- Louder Horn
- Armrest: I have questions
- Well got to the Dyno with the Acura EL 2.4
- suspension??
- 03 em2 creation
- 2001 1.7EL - no start, dash lights flicker
- high beams not working.
- 04 civic ex fan running at all times
- N00bie
- What about that? 2k5 RSX-S Master/Booster fitement!
- Rear clusters swap from 05 plate to 03
- Suspension
- Trans swapability??
- 92 Civic SI fan won't turn on
- Alternator, SRS, lights flickering problem...
- RSX-S steering wheel in my EM2!? Is it a good upgrade??!?
- Anyone with Honda Interactive access?
- d2 calipers what do u think
- Top din
- 205/55/15 fit stock 15 inch alloys?
- New front rotors/pads from EP3 will they fit in my '05 DX
- car moving too slow
- removing 2003 headlamps
- Is this worth getting?
- what do you think about that?!
- Car making whistling noise while on has pedal
