- 2001 Civic EX Maintenance Question
- RPM problem - Tach or distributor
- Engine differences A1 to A6
- Need help figuring out why cluster re wire not working
- Coolant - Drain the Block?
- k20 swap question ( subframe )
- Switched fuel filter now civic won't start.
- Driver Side Pillar Clip
- Seat Swap?
- A/C Function
- Replace D17A1 Auto Tranny with D17A2 Auto Tranny
- Temp. gauge issue
- 2003 ex
- Wire Harness plug identification.
- LX ECU SWAP for an EX ECU 04-05 EM2
- ignition failure
- Car won't start
- 2001 Civic Wiring Harness Change
- 2001 Honda Brake Problem...PLZ HELP
- 2002 Civic LX - Transmission slipping, Car stalling- before and After Rebuild
- Looking For Tranny
- ho2s problem civic 2004
- Need help! 2002 Honda Civic Instrument Cluster Problem
- honda civic 2001 key fob problem
- Pulley will not spin, serpentine belt
- New PCV valve rattling
- Dimming or Flickering headlights
- Get more speed
- 2002 Acura 1.7EL (CAN - just like Civic) window lift assembly: 6-pin vs 4-pin
- Shakey at 40mph
- 2002 Honda Civic EX Engine Shake Problem
- How to see timing marks on harmonic balancer
- Car running poorly Need Help!
- Head gasket just replaced now losing oil internally. Please help
- 2002 Honda Civic dashboard lights won't turn off
- Power steering leak soaking the floorboard
- '02 civic excessive oil consumption
- 04 civic ex squealing pulley and transmission fluid change
- ducktale
- B20 01-05 civic
- 05 honda civic ex coupe srs light frustration
- EM2 Odd Idle issue (Trust me I've searched already)
- Electrical problem on full lock
- D17A2 swap to D17A
- Possible Electrical Problem? '02 Civic
- New to forum exhaust question
- Air-Con problems and etc.
- help please o2 sensor
- Help Help Help plz P0344
- No tach/temp/relay click/no scanner connection problem
- electrical problem....what do you think it is?
- Oil and Tranny Fluid leaks
- Thread pitch size help please
- 2004 Honda Civic EX HID Retrofit
- Driver Side Rear Window Inoperable
- D17A2 Head and timing belt help
- 2002 Civic EX help
- I have no idea what the mechanic is talking about!!
- Water collecting in my trunk. Need help!
- 2003 Honda Civic LX - Transimssion Fluid, Serpentine Belt & Other Questions
- TPS Related Issue
- OK, Here's a Challenge, 02 Honda Civic
- P0300, P0302 and P0304
- 04 Civic Coupe Hood Release Knob Broken
- 2004 Civic loses all power while driving
- Headlight Adjustment help
- Another AC not working thread
- 2001 Civic LX, dash and corner lights flash when ignition is turned on.
- car surges
- Electronics between Aif filter and air intake
- valve stem seals
- Need help with our a/c
- 01-05 Civic JDM automatic transmission compatible with 01-05 USDM Civic
- TDC Sensor R/R WITH ABS Module in the Way
- need help bad
- DTC P1457
- 02 civic lx trans question
- EXEDY KHC08 OEM Replacement Clutch Kit
- Died while driving will not start
- LX (d17a1) in an EX (d17a2) HELP!!!!
- Exhaust System Suggestions
- 2004 EM2 key wont turn in ignition
- 05 turn signal lever problem
- Civic Hybrid IMA Light - Unique scenario!
- New to Civic, Need Advice.
- Brake Line Flare Type
- power steering pump or rack?
- interchangeable with 03 civic coupe
- 05 civic vp cranks but won't start
- 01 civic ex starts and dies need help
- No crank unless push started then cranks thereafter
- Idle and acceleration problems
- EVAP Error But Canister Shut Valve Seems Fine
- Clutch bleeding problem
- Golden K-series Turbo Project civic ES
- P0335 CKP sensor issue
- Fog light problem
- How Much is My D17a2 Worth?
- Shift knob won't thread on?
- 01 Civic Backfires & Shuts Off
- Rear drivers door actuator not responding to button but works on the bench.
- 04 auto trans problem!!!
- 2001 honda civic ex clutch replacement including hydraulics
- driver side window popping off of track
- Passenger Rear window issue
- Civic feels like its in neutral.
- 2004 Civic A/C Not Working
- 01 Civic - hard starting problem
- Bypassing air bag
- D17a swap into 2002 Civic EX Help
- EX transmission question
- 2004 Civic cluster plug, lights on speedometer out
- 04 civic ex keyless entry prob...
- A/C Compressor oil volume?
- 2002 Civic - A/C only cold while driving
- 2004 Honda Civic Gages
- Replacing 01 Civic Head Gasket. Easy as EK's?!?
- Pic Request - Heater core Hoses
- Civic 2004 stop running when driving
- 2005 Civic - P1457
- manual vtec Engagement ?
- Low Beams Don't Work
- JDM engine and transmission replacement
- d17a2 swap need help
- 2002 Civic - rough idle
- Car broken into; need replacements
- Exhaust for an 04 Civic Ex
- Civic Hybrid battery difference b/w of 2002 and 2005 models
- Car won't run
- Blue Devil in Radiator
- D17A2 Vtec swap to JDM D17A Vtec
- p0135 Code
- two obd2 scanners do not fit Civic (or Accord)
- 2001 Civic - Maintenance issues to address
- 2003 Civic TDC issue when replacing timing belt
- CEL from O2 Sensor
- A 2005 Trunk Lid and Rear Bumper Cover WILL Fit a 2001
- Honda Civic @005 Lx wont' start
- 2003 Civic DX Charging System Light
- lugnuts/hub?
- muffler tailpipe moved over
- Civic Interchangeable parts question
- Serious engine problem with my 02 Civic Sedan LX, advice please?
- 03 non vtec stick
- Stereo says code
- Would 2000 civic lowering springs fit a em2 sedan?
- 01 honda civix popping sound center front of car
- Hesitates during acceleration
- weird poping and clunking noise
- Removing front bumper
- AC Takes Forever to Cool Down
- Compression test results / misfire codes 03 civic lx
- D17 Stock Header Removal - Stuck.
- Stock rear suspension bouncy?
- 02 civic transmission question
- Strange AC Issue
- Looking for A/C system diagram or help identifying this hose
- Random Miss when warming up
- d17a1 engine with pmr head
- Fitment with 17x9 20et on em2 ?
- Key Stuck in ignition, Stuck in Park, No park light in dash
- Please Help - 03 Civic Hybrid CAT o2 Problems....
- speedometer issue
- Three codes for the Emission system - needs help
- Gotta hate that grinding sound *bad taste*
- Gauge assembly issue? - 2003 Honda Civic
- 2005 Civic neutral safety switch
- Narrowing down cause of power window fault
- 02 Civic ex wobbles/shakes at speeds 55+ and worse when braking
- Switch on driver's door Can open but can't close the rear window at driver side
- Power to ac, defrost, or heat working.
- P1129 MAP Sensor Issue
- A/C automatically on.
- 04 civic horn beeps when turn lights on
- Brake light is stuck on
- Valve adjustment
- 05 Civic Rotors & Calipers
- 03 civic a/t transmission slip
- 2002 Honda Civic EX - CEL
- 2002 Civic Ex Fuel Pump
- New Tachometer
- 04 civic total electro loss
- P2646 Tested and tested still nothing
- Apexi N1 Exhaust for Honda Civic 2003 Ex fit on 2003 Dx?
- Where will the heater core leak ??
- srs ? does it shut off you motor
- canadian_em2's build thread
- More Cruise Control Issues
- can a v-tec engine be installed in my 2002 civic lx non-v-tec
- AC condenser fan fuse keeps blowing
- S2000 em2
- Vtec
- Help please!!!!!!
- power wire hook up on fuse box
- Engine misfire and CEL
- Brakes, Struts, finally found the squeak
- 02 civic lx transmisson
- Mileage Odometer Correction
- 2002 civic ex: check eng, flashing 'D' after engine swap
- 2004 honda civic Please Help!!!
- d17a2 intake swap
- lx exhaust with ex trans?
- 2004 honda civic
- SRS airbag light
- Service Manual 01-05 civic ????
- struts for em2
- 01 DX Cluster Swap
- car is running rough
- oil pressure light
- Code P1457
- engine swap! what should I do while I'm in there?
- 2002 Honda Civic EX starts but does not keep running
- 2004 Civic 1.6VTEC A/T
- Honda Civic 2002 EX Vibration/Shaking
- My internal blower won't turn off and my A/C is not working
- 03 Civic P1457 Code Transmission issues
- The Retrofit Source Writeup!
- Stock Headlights vs. Aftermarket
- 03 EX - P1259 Code - Auto Trans
- 2002 civic ex dead-please help
- Es1 k20a3 swap
- Broken trunk latch 2005
- 01 civic tranny
- 2004 Civic RPM hangs when load on engine
- Another Stripped engine intake manifold Q -01 LX
- Help with Engine Codes
- RSX sway bar
- 02 civic DX A/T
- Rear passenger window down, but not up
- Civic em2 01-05
- Not sure if this is normal or not but...(gas mileage)
- CEL code
- 2002 Civic EX Intermittent misfire
- timing belt tensioner bolt came lose
- Misfire with codes
- 200 hp out of a d17a2
- labor times 2005 civic 1.7 v-tec
- 2001 Civic Crank No Start, Then Runs Fine
- Navigation in Civic
- want to buy ( 01-05 ) honda civic ex
- 2003 Honda Civic LX A/T not starting after car died while driving
- 01 Civic Lx Transmission Problem
- Need tips for drive side axle removal
- 02 lx electric problems. plz help
- What engine matches the D17A1??
- 04 Civic EX Coupe Water Leak
- 2004 Civic idle hangs when fans run
- What needs replaced with head gasket?
- 03 Civic EX still smoking....
- How to make gauge cluster lights come on with car
