PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. A/C & Heater Not Working, No Electrical Response
  2. 2004 Honda Civic DX-engine compatible with?
  3. 03 Civic 3sstage Vtec speedo and tach malfunction
  4. AC drain line
  5. Rebuilt Trans - Sometimes no third/fourth - No reverse
  6. Planning a Kswap
  7. An update on my 3rd to 4th flare
  8. 01 rough idle
  9. How to replace spark plug tube gasket (ring)
  10. 2003 civic p0340 error code, sensor change, sputter at 3400 rpm
  11. Not Driving Smooth
  12. ?Silicone to use on AC Thermal Protector"
  13. Civic gap in bellhousing?
  14. Clear headlights (No Ember)
  15. street value of 04 civic coupe?
  16. Question About Interior Conversion?
  17. VTEC not engaging properly?
  18. P1166 code on 2003 Civic Hybrid
  19. Turn signals weren't working. I found out why!
  20. Need help with Suspension!
  21. tranny dipstick causing leaks?
  22. Expansion Valve What is that?
  23. 01 steering wheel
  24. Help me identify ticking / sputtering! Youtube VID
  25. Blinking light on driver floorboard
  26. Engine misses and error code P1129
  27. weird happening; battery dead, accessory pwr outlet dead, etc..
  28. em2 screechine noise sounds like starter help!!
  29. New OPDS Unit Will Not Initialize
  30. Acura EL front end
  31. Engine starts for 1 sec, and automatically stops
  32. hesitation and shaking 2003 Honda Civic Hybrid
  33. Just locked my keys in my EM2
  34. 2001 Civic DX tranny problem
  35. Radio Antenna hook-up in rear window???
  36. How do I replace my TPS on 04 Civic LX?
  37. transmission shift
  38. 01 civic lx to 04/05 front end conversion
  39. headlights flicker while driving
  40. replaced slave and clutch cylinders no leaks what so ever
  41. Door Trim Molding Removal
  42. Disconnecting freon lines
  43. A/C troubles and a hello!
  44. 2003 Civic lx engine won't stay running
  45. Civic 2001 giving sound from front when giving gas..
  46. CV axle popped out
  47. 2001 Civic auto P301 Cylinder 1 Misfire --> HELP!!
  48. 2001 civic exhaust manifold gasket
  49. what lip?
  50. Hey! Is this a decent price for a 01 Civic?
  51. hey, new member here with an em2! k20
  52. Help! 02 Civic Master Key question.......
  53. Tail Lights won't turn off
  54. Ignition Coils
  55. 2004 Civic P0420
  56. Problems With My 01 EX
  57. 2003 civic wont shift from 1st
  58. Cylinder 1, 2, 3 misfire & random misfiring
  59. 2003 Civic EX coupe- Check Engine Light codes and likely fixes
  60. Spare tire question....
  61. Before I go to a mechanic.....HELP!!!
  62. compressor, cooling fan
  63. Need engine spec for canadian 05 Civic SE
  64. Cable Reel vs OPDS Unit
  65. '01 civic EX - recomendations on manual trans rebuild or buy remanufactured?
  66. Intake Manifold
  67. 2001 Civic LX shaking.
  68. K-swap front sway bars
  69. Knocking Sound
  70. Brake light doesn't work.
  71. Blown Head Gasket
  72. 2003 civic lx a/c problem!!!
  73. 04 Civic Overheating - Or so the gauge says so?
  74. 2002 d17a1 to d17a2 swap
  75. Problem after Engine replacement... P0715
  76. car wont start
  77. 7th gen stock crank pulley weight?
  78. Is this a Tranny Problem
  79. FlashPro?
  80. Smoke coming out of hood
  81. Good Mechanic Challenge for those with experience Cooling System
  82. 2001 Civic with P1361
  83. Idle/Starting Issues
  84. AC condenser fan
  85. Parts Compatability Question
  86. Car stuck in park
  87. need help
  88. 2003 civic blower motor inoperative...
  89. Air Conditioning problem
  90. 05 4dr rear window trouble HELP!
  91. Rough idle and bad shifts into second gear!
  92. Few Questions
  93. o2 sensor
  94. AC Compressor not working
  95. Poll - 2001-2005 Civics Head Gasket Failure
  96. 2002 Civic EX Head Gasket
  97. 2002 Civic A/C Problems
  98. 2003 Honda Civic LX Help?
  99. Battery light on. Alternator keeps blowing fuses?
  100. Ran great then 4 hrs later wouldn't start ECU?
  101. 02 honda civic helpppp ac problem
  102. Cooling fan replacement steps
  103. 2004 Civic just Died! Need HELP!!!
  104. 05 Civic EX SE alarm system disable
  105. 2002 honda civic cooling fan doesn't work
  106. 2003 Civic AC problem
  107. Harness Bar
  108. 2003 Honda Civic EX Emissions/Fuel Problem
  109. Rad empty, over flow filled to cap. . . Not over heating ??
  110. honda civic ex 02 ac compressor
  111. 2001 Civic Auto Trans
  112. 01 Coupe Door lock Problems
  113. 2005 LX-G rattle/chirp front end
  114. em2 help dc5 5lug conversion
  115. 2005 Honda Civic wont start plz help
  116. 2002 civic EX headlight removal/instalation
  117. civic EX remote question
  118. 001 civic speedo, odometer, gas gauge only works sometimes
  119. Transmission tuning.
  120. Really need some help!
  121. Repair manual question
  122. Did I just break my alternator - Broken Alternator Bolt
  123. 2001 Civic HX Clutch
  124. what is this for ?
  125. No electrical power to the car
  126. Possible jumped timing, procedure to get to TDC without (further) damage?
  127. 2003 civic ex headlights quit working completely
  128. Input Shaft Bearing - Replace or Rebuild?
  129. Rattle under acceleration
  130. Timing belt failed (tensioner, actually)
  131. fob not working
  132. Progress Anti-Sway bar problem
  133. 120K Maintenance List
  134. 2002 civic power windows
  135. 2001 burnt auto trans ?
  136. Oil in air filter
  137. Replace Steering Rack 2002 Honda Civic DX
  138. Idle increases when radiator fans kick in
  139. 2006 auto trans on a 2001???
  140. 2002 EX Timing belt questions
  141. Help w/ 12v acc jack -Civic Sedan 2004
  142. Code PO300, 301, 302
  143. 2001 Civic EX fuse box
  144. Transmission Issue
  145. Pulling through sludge
  146. HELP! Weird problem with car
  147. 2002 Civic EX timing belt?
  148. CV axle too long?
  149. Did the 03 civics have the leather option?
  150. Honda civic 2003 buzzzing sound from the glove box???
  151. 01 Civic EX burnt up ignition coil- rubber at end burnt off
  152. 01 civic transmission & check engine light
  153. help with crankshaft situation.
  154. More AC Problems....
  155. 2002 civic side skirts?
  156. key stuck in ignition cylinder. Wtf!?
  157. Wiring in Overhead Map Light. Jumper from Dome?
  158. 01 Honda Civic Stall when Hot outside
  159. oem 02 Acura El parts online?
  160. 2004 Honda Civic Ex engine swap?
  161. A/C Problems! 2002 Honda Civic
  162. Did I blow another head gasket?
  163. 05 Civic Hybrid A/C not working when hot out
  164. What might cause a rattling noise from the wheel well?
  165. 02 civic map sensor question
  166. I'm stumpified on bubbles and coolant push to reservior
  167. Outer Tie Rod removal
  168. 03 civic hybrid AC compressor
  169. Question about coolant system pressure check
  170. Heavier harmonic balancer = bad gas mileage?
  171. Brake Calipers
  172. 01 civic ex a/t trans filter?
  173. a/c blows warm 04 civic, bad ground?
  174. 01-05 DX come with power steering?
  175. the ac on my honda civic 2002 will not work
  176. Cooling system pressure?
  177. What's wrong with my Civic?
  178. d17 turbo parts?
  179. New Here + Questions about D17
  180. automatic door lock question
  181. Car Electronics Help! and Reflash/Remap Questions
  182. A/C pump clutch very loose
  183. Help. video inside showing the events.
  184. Better performance out of 05 civic LX
  185. Engine Swap, No plug for EGR, (SEARCHED)
  186. Replacing Engine & A/C lines (Searched)
  187. Brake Light (Stop Lights) Not Working? Confused??
  188. 01 civic commuter axle clunk noise? HELP!
  189. popping clutch sound
  190. 02 ex with lx trans
  191. cooling system HELP!!!!
  192. 01 honda civic ex turns off when you press the gas.
  193. Ac compressor wire
  194. Troubleshooting a P1361 code...
  195. 03 Civic EX Vibration at 60 and Above
  196. Wheel Stud Replacement
  197. d17a2 oil draing plug tap
  198. d17a1 block w/a2 head commperssion ratio
  199. HELP! Need to know these parts
  200. Another (quick?) oil pan question.
  201. TPS Problem.
  202. CYLINDER IDENTIFICATION???
  203. all cylinders misfire?
  204. Air Bag Light on Dash - How to Turn Off
  205. Civic 2001 LX Retrofit headlights?
  206. copying key with chip
  207. 2004 Honda Civic Si Coupe - Brake Issues?
  208. Imagine that.2001 civic auto tranny trouble
  209. 2001 civic dx sudden loss of power, not going over 30km
  210. wheelbase measurement please
  211. 01 civic dx
  212. Video: Slip or is this normal? 04 Auto Trans
  213. P0134 Primary HO2S ... fuse?
  214. a/c clutch not engaging
  215. all parts needed for k20a swap in 04 civic ex
  216. Tips for exhaust manifold work...
  217. 01 Civic Shift Solenoid Gasket
  218. A/C question
  219. Blown A/C Lines???
  220. 01 Civic Automatic Transmission Drain and Fill Guide?
  221. 2002 Civic Automatic Trans issue
  222. 01 Civic Dash lights Not Working
  223. Honda Civic 2002 lx 1.7L Torque Spec
  224. Why is there play with my windshield wipers?
  225. 02 Civic dash lights and lights-on chime won't work after new stereo install
  226. Lost on a problem/noise/CEL...
  227. Camber kit, alignment and stuff
  228. Put wrong tranny fluid in
  229. 01' Civic EX, fuel injector cleaner added, now engine light on/engine stuttering
  230. help me troubleshoot my starting issue.
  231. 01 ex A/t issues
  232. CEL = Bad News for my EM2
  233. Strange noise.
  234. no tach light and just realized no rear lights either
  235. 2001 civic ex lost transponder key
  236. D17A2 MAIN BEARING CLEARANCE
  237. catalytic converter
  238. i need help plz w sway bar em2 k20a2
  239. Vtec 03 civic ex
  240. What are all the different factory seatbelt colors?
  241. 2001 DX: Low beams Doesn't work, only High
  242. Odd driving problem
  243. Rod Bearings
  244. Replaced O2 sensor / now new codes and horrible mileage
  245. Purple Honda Badge?
  246. How to Transmission Rebuild Guide?
  247. leaking ac compressor
  248. 2002 Civic EX A/C problems
  249. 2002 Honda civic transmission replacement. NEED INFO!
  250. power door lock
