- Problem with lights ( HELP ASAP )
- 2002 Civic Coupe Factory Service Manual
- Front shock replacement?
- Strange noise around dash!
- Brembo Slotted Rotors
- J30 Mounts
- Red Front "H" Emblem
- In the market for a used Civic...
- motor mount problems
- coil over problem
- SRS light
- a/c fan not blowing...please help.
- my k24 build thread
- hybrid side mirrors
- Retrofitting Heated Rear View Mirrors
- Headlights not working (non-brights).
- Why is my overflow tank empty when engine is cold ? UPDATE
- anybody rockin mudflaps and skirts?
- Power window problem (electrical)
- Reving only 5K on full stop neutral.
- reset maintenance light
- Deleting the Cat
- ABS Light Is one
- Emblem question!!!!!
- Photo Request: Em2 Engine Bay with Cold air intake
- i need a new battery
- Clutch Swap
- ► May 2009: For Sale / Wanted to Buy
- Squeak at high RPM? Problem?
- Check engine light
- EP and Em2 interchangeable parts
- new thread suggestion
- Cruise Control Problem
- Turbocharge Help PLEASE!!!
- O2 sensors
- HELP!!!!!! with d17a1 02 civic
- Removing carpet in Civic Coupe
- Mud Flaps
- 02 Main Relay??
- honda civic 01
- Fuel gauge issues
- High beam/Daytime Running Light (DRL) issue
- 17" Mini Wheels On An EM2?
- Can I clear 05 sedan stock tail lights?
- Few questions about a hood change
- Strup exhaust
- skunk2 springs
- Will my em2 pull a trailer?
- Removing Antifreeze without flush
- boosting stock 01 civic ?
- 02 Civic Coupe 2dr Clutch Peddle Lag
- K&N Air Filter
- Royale Purple Vs. K&M Oil Filter
- Carbon box air intake
- 2003 civic, my car died in 5th gear today
- Gas gauge
- honda civic04 overheating problem
- Rim suggestions
- 2001 EX Rear Speaker Removal
- 2005 Hond Civic EX Overheating
- what can i do d17a2
- Piston swap from D17A7: Is it possible?
- CEL Issue
- Vac line & seafoam - d17a
- 01 dx k-swap info
- OBD 2 to OBD 1 conversion
- 01 civic oil pan replacement question
- 04 civic ex not starting
- Vtec not kickin in on 05 ex after head gasket change.
- Help from K20 Guru's?
- how much and were
- A/C thermal protector replacement: 2002 Honda Civic LX
- Online Manual and Strut Replacement
- help me em2 friends!!
- 16' or 17' rims
- camber problems...
- projector foglights..
- Transmission Leak
- can you put rdx k23a into 05 civic
- Lowering seats in a 2002 Civic EX Coupe
- Where can i find front camber kit?
- turn light question
- Trunk Shocks
- what should i do?!?!?!
- Brake Problem?
- Mysterious oil problem
- Car Alarm won't turn off, Help!
- Why is my car stalling?
- About HOnda CIvic speedy??
- IS300 projectors retro
- Reverse Light Switch
- Help! Stuck in 4th gear!
- ecu replacement question
- D17A1 vs D17A2
- wheel alignment cost
- Bumping noise coming from under 02 Civic. Any ideas?
- Rear Light Problem
- How do you change the alternator belt?
- Fuel Pressure regulator??
- request; 18" wheels on civic
- ebay brand? or name brand parts?
- D17 Potential
- 2002 wind noise
- My Build Thread
- 35 shot NX dyno
- Spark plug question... Please Advise....
- AEM V2 & "Helical" Throttle body spacer.
- ARP head studs for my D17?
- Urgent help! Mom's 2003 running hot
- Help Me Fix My Car !!!!
- 2002 honda civic trouble
- idling sensor
- Help!! Installing springs problem
- Clicking rear Sway
- Adaptor Hub Ek/Em2
- rear drum squeak
- 04-05 grill
- need help! clutch not getting pressure.
- 04 Civic Coupe Intake?
- Turbo civic swap
- Turbo swap
- progress anti-roll bar
- Please Help! SRS Light - Can't reset
- synthetic auto transmission fluid additives ????
- S2000 Steering Wheel
- My Build Thread
- Maintnance Required light is on ?
- Purchasing 02 lx 4 door anything to look out for?
- My Build Thread
- Replacing a Rotor?
- help on RPM
- question. offset? spacers
- i need a quick answer
- PUSH start on em2 help
- Aero..
- 04 Civic 4dr Side Skirkts
- Cam holder bolts torque specifications
- 03 ac issues
- Radio Cutting Out
- front lip gredy on civic 04-05 ??
- RHD Em2?
- DIY intake
- 02 Civic Sedan - Door Lock/Keyless Entry + A/C not working and brake light on.
- 17' rims on Honda civic 2004 Vibrating
- Flex Plate bust after transmission replacement
- oil burning?
- K swap exhaust
- 01-03 coupe headlights same as sedan?
- cf hood&trunk or skunk2 pro series coilovers
- HELP! Intake Knocking on Hood
- torquing lugnuts-Is a torque wrench accurate?
- front upper strut bearings ?????
- Clutch Clicks
- Headers
- SRS light on in 2001 Civic LX sedan
- red honda badge
- Rear brake conversion...
- One ?
- Should I buy it?
- car won't start
- convert automatic to manual transmission ????
- Will 05 suspension fit 01-03?
- Strange noise from engine
- 2001 Honda Civic DX automatic transmission replacement
- The EX Coupe
- transaxle issue?
- Coil springs?
- need help installing horn
- Front end swap 01 to 04
- just got 2003 civic
- 2001 honda civic stock springs?
- horn upgrade
- megan racing coilover vs skunk2 coilover
- TL Remote Key Program for 04 Civic Remote
- help car is shaking
- 4 lug disc conversion
- Is something bent possibly?
- pressure plate help needed fast!
- Jack problem
- Show off your drops(with description).
- New Catalytic Conveter
- Using OEM foglight switch
- Need help installing grill
- k20 base engine head
- OEM EM2/ES Rare & Optional Parts
- 2002 Honda Civicx EX Starter?
- Remoteless keyless entry
- EP3 Coilovers in a EM2?
- replacement Cluster
- What comes in a full tune up?
- newb here
- gc's on kyb
- Rough Gas Pedal
- Changing rear speakers
- vibration while driving
- 01 civic ex misfire issues
- Skunk 2 lower control arms.
- lowerd on Ground Controls= popping noise??
- Front right brake is humming??
- cd player with ipod connection opinions wanted
- My Build Thread
- uhmm, How much horse power???
- My Build Thread
- ► 01-05 Civic Suspension Q&A (coilovers, springs, bars, etc)
- will 04 bumper fit on 02?
- need 12v power civic coupe
- Air box assembly question
- Hit Curb - Front Passanger Wheel
- Where to buy a rear window visor?
- ingalls front camber noob help
- Removing Factory seats and other?????
- 2001 honda civic gauge cluster issue?
- 2004 civic dx vp gauge swap problem
- F1 CLUTCH vs EXEDY CLUTCH
- tranny problem, help!!!!!!
- A Good OEM Strut?
- Creaking rear suspension?
- 01 civic ex cluch replacement
- Trunk mod for spare
- Fog Light Switch
- 04 civic suspenion setup
- How to install front lip?
- cluster questions.
- cluster swap
- weird noises from car
- Help, changing bumper
- H.I.D troubleshooting 2002 SDN not working!
- Tightening hand brake for 2001 Civic LX?
- Broke the drivers side mirror
- My Build Thread
- 01-05 cat-back HELP
- Ebay Performance Chip
- Differences between Headlights...
- will these fit?
- what is the best full synthetic oil ????????????
- Was good honda Tech
- new member. 05 civic. nc
- EP3 seats into my EM2
- Is it possible to thread the shock body of Koni yellow?
- Heater blower stopped working
- LX exhaust question
- difference between Si and Type-r
- Replacing 03 Civic EX transmission and clutch
- odd problem.... need some help on this 1
- lug pattern 2002 HONDA CIVIC EX
- Looking at an 04 or newer civic..............
- Where must I start???
- 01-05 Civic Online Manual?
- Automatic Windows
- Lowering Springs vs Coilovers
