PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Tryna make my car faster
  2. 2001 D17A2 to K series Help!
  3. 01 civic a/c not working
  4. 2001 EL Canister Purge Leak questions
  5. Troubleshooting 2004 Civic LX Auto Trans Linear Solenoids
  6. Problem with Automatic gearbox in CIVIC 2004
  7. Best Budget Clutch for 2002 Honda civic coupe
  8. Problem with Automatic Transmission in CIVIC 2004
  9. Slick 50 or MotorKote
  10. 99 civic vtec head to a 2002 civic ex with a d17a2 block
  11. 2002 Civic LX - Rear click noise
  12. Lost
  13. Honda civic DX 2005 oil that should use
  14. IMA battery
  15. 2005 Civic EX A/C On and Off when hot and fast
  16. 2005 Civic LX overheats in traffic. Changing thermoswitch. Anything else I should do?
  17. Rough idle, nearly stalling, when AC is on
  18. AC doesn't work in hot weather
  19. 04 Civic Door Wiring Pinout?
  20. grinding sound in the front???
  21. Retiring my 98 Civic looking at an 05 ex
  22. Small coolant leak
  23. Has anyone used the Blaster ignition coils?
  24. Blown 80 amp battery fuse idle battery voltage 11.8
  25. rear license plate light
  26. Manual Transmission wont engage
  27. Vibrant Muffler (Universal)
  28. 2001 Civic A/C problems
  29. Just a General Question
  30. 2005 Honda Civic revving up slow and has no power
  31. 2004 civic dx/vp shift kno
  32. modified K20Z3 injectors to 500cc on D17A2
  33. How do I rewire the horn after installing quick release steering wheel?
  34. Install inline filter AT 2001 civic
  35. Parts to buy for timing belt Civic 01
  36. Fog light issue
  37. 01 civic ex 1.7L vtec. Compression issues!!!!
  38. 2004 Civic EX swap with JDM, ok?
  39. CEL P0128, replaced thermostat, replaced ECT sensor, car cranks longer at start now
  40. Sagging driver's door
  41. JDM motor swap
  42. y8 maniswap to d17a2 dyno test?
  43. Throw Out Bearing Bad?
  44. Power Steering Pump Replacement
  45. 05' Civic EX Code P0497
  46. 2002 Honda Civic AC issue
  47. a/c clutch wont engage / radiator fan wont come on
  48. Doesn't seem like a typical scenario
  49. Power Steering Pump or Steering Rack?
  50. Trying to get my 04 Lx with a jdm D17A running
  51. Coolant problem with 2002 civic ex
  52. Random overheating???
  53. Question about ECUs and VTEC in a D17A1
  54. Grinding/growling noise
  55. 2002 civic coolant issue
  56. D17A2 Vtech valve adjustment
  57. Civic resonator mod
  58. Hybrid IMA/Check engine light and CA smog check
  59. 2003 Honda Civic EX 4 Door AT Instrument Cluster
  60. Your advice would be most kind, thank you!!
  61. Brake Rotors-5th Set
  62. Can caliper keep a car from moving?
  63. 01 civic wont start hot
  64. Need Help Reprogramming / Flashing ES2 D17A2 ECU
  65. no output to transaxles
  66. 2001 civic won't Rev pass 3500 rpm
  67. 2001 Civic LX Keyless entry
  68. Test pipe
  69. P0344 and Dry Bearing Type Squeal
  70. d17a2/d17a
  71. p1562 & p1600? anyone seen these?
  72. Gdd help me fix my car
  73. Low Power, Low Idle, & Near Shut Off
  74. Brand new radiator, new thermostat, overheated after trying to run heat.
  75. 05 Civic LX, rubbing sound front-end of vehicle
  76. 2001 civic transaxel engaged but not moving wheels
  77. 2001 civic ex...dies in warm weather.
  78. ECU compatibility
  79. 2002 Honda Civic suddenly not starting (with clicking noises)
  80. 2005 motor swap questions
  81. What abs sensors can I use with ep3/dc5 5lug swap?
  82. New battery & starter, no start, no crank, no dash/headlights
  83. 2002 Civic coolant not circulating?
  84. Weak Acceleration, Engine Not As Powerful
  85. So whats the deal with EMs/ESs?
  86. 2005 fuel pump
  87. 2005 civic si long cranking when low on fuel?
  88. Honda Civic 2001 Ex Sedan
  89. Exhaust!
  90. 2003 civic ex ecm
  91. 2001 civic ex coupe
  92. D17 oil light
  93. 04 Civic Battery Light
  94. 2001 Civic intermittent start issue
  95. EM2/DC5
  96. My Emissions Light Went On - I am 9 hours away from my mechanic!
  97. Gsr swap
  98. Positive battery cable
  99. P2646 after head gasket
  100. No power past 45mph
  101. knocking issue 02 dx manual
  102. inner tie rod removal
  103. 2005 Honda Civic Hybrid Major Issue-PCM
  104. Installing new head gasket and need help!!
  105. D17 td04 build help.
  106. SLEEVE COILOVER INSTALL DIY request
  107. Starting/stalling issue
  108. Throttle Body Torque Specs
  109. Key not working in ignition lock.
  110. 2001 Honda civic ex 1.7 auto can you do a swap and
  111. HELP!
  112. What is My Car's Optimum Engine Temperature
  113. Idle Issues
  114. HELP!
  115. DRL troubleshooting
  116. Compliance Bushings
  117. Trunk compatibility
  118. 04 Civic EX gas needle on going opposite way on gauge..
  119. Cooling issues and fuse blowing 01 Civic Lx
  120. d17 short
  121. Tanabe Exhaust System 03 EX
  122. 04 civic lx persistent p0135 circuit test good new ho2
  123. Loose top radiator support
  124. D17a2 vteck
  125. Best way to get that pesky adjusting wingnut off?
  126. Closed.
  127. 04 Civic overheat/overpressure in cooling system. NEED HELP!!!! PLEASE read!!!
  128. Need two people to open fuel door!
  129. 04 civic d17 valves adjustment
  130. 2004 civic dx vp temp gauge pegged past hot
  131. P/S Pulley Gone, Belt Gone, Wicked metal grinding noises
  132. Transmission trouble!
  133. Gear shift not smooth - 2004 CIVIC ES8 EXI (1.5cc)
  134. Purchase Parts
  135. Relocated battery to trunk and having issues starting
  136. Possibly bad wheel bearing.
  137. Car only wants to go in reverse...
  138. 04 CIVIC SHIFT LEVER PROBLEM
  139. Dumb heat is blowing cold and I need help!
  140. 2001 honda civic ex coup manual D17a2 Engine
  141. 04 Honda Civic DX VP Bank 1 Sensor 1
  142. 03 EX D17A2 Over heating
  143. cluster help
  144. Need help with this (suspension repair)
  145. 04 Civic Oil Pump O-Ring
  146. Airbag recall?
  147. Will ES2 rear bumper fit ES1?
  148. Car shakes in revrse.
  149. Front conversion???
  150. bike rack
  151. 01 civic cluster swap issue
  152. 04-05 Civic hood on an 01?
  153. USA 2005 civic slxa to jdm slxa
  154. Need Some Answers
  155. problems with engine revolutions
  156. New downpipe and headers throw P0420 CEL
  157. Help!! My 2001 Honda Civic EX Coupe, swap engine D17A and overheating!!
  158. Bizarre Flasher Problem 02 Civic EX
  159. Squealing noise when turning the wheel
  160. Key fob won't unlock doors
  161. Heat won't work and today it's -10 degrees!!
  162. Clutch hydraulics issues
  163. Crank, no start..
  164. help headlights wont go off - relay already replaced
  165. HELP - 2004 Honda Civic Lx !!
  166. ECU for D17A1
  167. Timing Belt replacment Now p0420 code
  168. 01 civic d17a2 driving me crazy
  169. Hubcentric or Non Hubcentric Wheel Spacers?
  170. 1999 - 2003 Acura EL opinions?
  171. Header
  172. Power steering loss
  173. Rear brakes squeak upon disengage
  174. exhaust inormations
  175. Blown head gasket again. Need advice.
  176. 2001 Honda Civic lx bad ac compressor
  177. 2002 Civic Ex problems
  178. Av condenser noise
  179. 2003 Civic LX fuel gauge messed up!!! Help!!
  180. Constant headlight condensation help..
  181. 2001 Honda Civic Low GAS BAD
  182. 01' LX vs EX Wiring Harness
  183. Tire size help
  184. 03 civic lx manual engine swap
  185. MaintNance light
  186. d16y7 bottom d17a1 top
  187. 2001 Civic D17A1 Erratic idle, hard start
  188. Headgasket issue at 235k miles
  189. ECU Replacement question
  190. 2003 Honda Civic noise problems
  191. Swapping ecu??
  192. 2004 Honda Civic making a high pitched whining noise
  193. Heat not working while idleing temp gauge creeping while idle
  194. Radiator replacement and hood release cable
  195. Auto vs Manual Radiator Difference
  196. 04 EL instrument cluster dead: options?
  197. Wheels and tires question
  198. Help!!!2005 Civic clunking noise
  199. 2005 LX special edition
  200. 02 civic downstream o2 sensor location
  201. 04 civic misfire codes
  202. Windshield Leak Fix?
  203. 2003 Civic EX Cold Weather Won't Start
  204. 01 Civic lowering questions!
  205. 2002 Honda Stream - Civic-based 7-seater - instrument cluster compatible with Civic?
  206. Gauges, DLC, Immobilizer Not Functioning - PLEASE HELP!
  207. Head bolts/bad gasket
  208. Engine Temp In Cold Weather
  209. 2005 downshifts in cold weather
  210. Cam shaft HELP!!
  211. 02 Civic Sedan Part Fitment
  212. 2002 Civic LX Questions
  213. Fluid leak at front conner, passenger side 2004 Honda Civic Ex
  214. 02 d17a1 manual lost power temp gauge dropped.
  215. Mysterious Blower Heater/ Rear Defrost Relay Issue
  216. Civic 2004 brake pads
  217. Civic oil leak. Head gasket or vtec solenoid
  218. Help on torque specs!
  219. New to the Civic world, and have problems
  220. Where to get headlight socket? Also, Hello!
  221. How much are you guys paying for a timing belt and water pump change?
  222. Lock car alarm comfirmation from "chirp" to loud horn.-05 Honda Civic Ex
  223. Cleaning oil from coil pack
  224. 03 civic lx manual engine swap
  225. Hazard/Blinkers not working
  226. Thermostat Replacement
  227. Honda Civic 2004 A/c Turns heat when A/cit is Off.
  228. loud pop during wot car shut off
  229. my civic em2 k-series 4wd swap russia)
  230. 02 civic lx grinding noise in my auto tranmission
  231. Car won"t start
  232. 03 Japanese auto trans swap modifications?
  233. Thud noise 2001 Honda Civic (with audio)
  234. Gears wont move
  235. Help - 04 civic water pump connecting inlet pipe replacement
  236. P0340 - 2003 Honda Civic DX
  237. Help please.. Ball joints
  238. 2005 Honda Civic EX 1.7 L VTEC automatic
  239. Valve cover thread stripped.
  240. Clutch Master Cylinder Compatibility question
  241. Where to order Input shaft bearing?
  242. Loud squealing when car is cold, what should I look for?
  243. Need help diagnosing suspension noise!
  244. 02 civic with automatic trany problem
  245. 04 Civic Engine Removal ?
  246. Intermittent Start Problem
  247. Excessive body roll on 2005 Honda Civic DX 4dr
  248. Can't Open Trunk on Civic 2005
  249. Immobilizer failure--Need Override code
  250. 2001 Civic LX Stalling
