- 02 civic lx cranking issue
- After Market Alarm Preventing connection to immobiliser?
- Crank Shaft Seal Chipped Surface Advice
- Misfire Even after repairs
- Tuning 01-05 civic
- Usage of Liqui Moly Products
- Please Help
- Oil Pump Question
- Exhaust & Muffler help
- rims/covers
- Civic 2005 ES8 problem when starting
- 04 Honda Civic DX Squealing
- Honda Civic ex 2002 won’t start
- Jimmy's EM2 Buildup Thread
- 2004 ES1 intend swap CRV Rear Drum/Disc
- 2002 Civic: Clutch replaced, car won't move, constant slipping?? Help I'm sinking!
- What is the root to my check engine car problem?
- Car bucking
- JDM swap D17A2 with VTEC disabled
- D15B block with D17A tranny
- P1420
- 03 Honda civic hybrid limp mode
- Noise under acceleration
- Aftermarket Exhaust Manifold?
- Converter or Clutch?
- 04 civic power door locks
- Blinkers not working 04 civic ex coupe
- 2002 Civic (BMXA) no reverse after rebuild
- 02 civic trans issue
- 05 Civic LX Blend Door Replacement
- Car won't stay running
- Power Steering Pump won't bleed
- 02 civic
- 2003 UK Civic Alarm Problem
- 02 honda civis wont stay running
- Rattling Ecu
- 01 civic LX cranks for days no start, no spark
- 04 civic vp to lx conversion
- Enormous coolant leak on 04 Civic
- Ignition switch question
- Front wheel hub bearing issue
- How to: Strut Assembly Tokico D-Spec w/Tein Springs
- Pls help: Throttle body accidentally sprayed with brake cleaner & removed some gray c
- Is my starter dead?
- Stripped Battery Holder
- Rattle when clutch is out, goes away when clutch is engaged
- How to change gear shift bulb on 02 lx sedan
- Warning light reset
- Alternator newbie
- Civic overheating (detailed)
- Cruise control hot wiring help!!!!!!!
- Vtec solenoid replacement..
- Helicoil size for 2 stripped valve cover bolts?
- O2 Sensor Question - Part#
- 2001 Honda Civic Cluster swap to 2005
- 04 Civic Coupe - 05 Civic 4Dr Part Swap?
- 12.6V while driving normal?
- Check engine light
- Coil pack keeps failing
- Question about rear training arm
- Another Overheating Thread
- Gauge Cluster Problems
- 2004 civic crank no start, stuck in park brake lights come on
- Loud Ticking sound after i do a valve adjustment on a 02 civic
- 2005 Civic no communication with ECU
- 05 Honda Civic Ex removing fuel rail
- D15b with d15y3 ecu
- Cold Start issues
- 04 Civic High Pitched Noise On Start
- 02 Civic EX unable to start car, cranking, no power to ignition coils
- Replaced camshaft sensor and cat converter won’t work
- Battery tie down rod
- Immobilizer chip removal
- Timing Belt (Cam Belt) Change
- Who is OE strut supplier for 2005 Civic D17A1?
- Exhaust
- Replacing Lower timing cover
- Suspension Opinion
- 03 civic hybrid motor mount
- Alternator belt broke and ripped CPS connector wires
- 03 civic manual clutch release fork bent
- Trunk hard to close
- Oil Pan Leaks With New Gasket and Pan
- Airbag Vs Check Engine light
- P1773 help 03 civic
- Torque loss at low RPM when engine is warm
- Common oil leaks, 1.7l 2003 Gas
- RPM drop then stalls
- Missing relay??? 2004 honda civic coupe
- 2004 civic trim confusion
- Electrical noise from 2002 civic lx
- 2005 Civic 1.7 - cranks but will not turn over
- Whirring noise upon acceleration
- 01 civic ex a/c not engaging need help
- ecu 2005 civic ex issues
- 05 Civic Overheating
- Had tranny trouble replaced with a used and it slips, shifting hard from 2-3rd.
- Engine swap
- Rebuilding the D17 Block questions
- 2004 honda civic ex temp gauge and rpm not working
- What size nut is this?
- Dim Headlights, Stock Tranny Ground Location?
- D17A1 to D17A2 Swap
- 01 LX Valve cover grommets
- Rear defrost not working, new relay not engaging
- 03 Civic EX oil leak
- 2001 honda civic ex brand new engine low compression
- 2003 honda civic rough start
- 2004 civic no spark ,.
- K20 —> K24 complete Engine swap questions??
- Oil leak
- cluster gauges not working on an 05 Civic
- P1259 Haunting Me
- 2001 Civic EX Catalytic converter question
- '02 Civic LX idle problem
- High beam causes major dash failure
- Temp gauge not working, recently replaced ECT sensor.
- How Remove Pistons D17A2 Engine Block in car?
- lAURENCE
- Air Intake Broken, options?
- 02 ex misfire
- Disassemble intake resonator?
- Extend positive battery cable?
- Engine overheat fix not working
- 2005 Civic Engine overheat fix not working
- 2005 Honda Civic Won't Start No Crank
- Daytime lights and dash lights are out
- Maintenance light won’t reset after all fluid replaced
- Door trim/B-Pillar replacement - Looking for link to purchase replacement part
- First MTF Fluid Change @ 210k miles
- Car doesnt center steer only after right turns
- AC system won't engage
- Stiff Shifter?
- Help civic 01 turn off
- 2002 Civic EX Not Starting After Adding Fuel Cleaner
- Brake lights staying on
- Transmission Issues
- Long crank !!
- Turn signals won’t work, I’ve tried everything and losing it.
- no forward gears
- D17a2 swap issues ( please help )
- Timing !! Help please
- 2001 Honda Civic dx headbolt issues
- Buying good coil overs
- Help! P0303 code
- Ready to call the scrap guys
- 04 EX Alternator mount broken
- 01 civic compatibility to 04 civic, suspension parts
- Help to identify this conector civc ex 01
- Plastic Pieces in the Floorboard and Cruise Control Quits
- 02 civic no power wont rev past 3500
- 2001 Honda Civic DX coupe Problems
- 2003 Civic dx engine light and oil light
- 2002 civic won't start HELP!!!
- Idling problem
- Inner Tie Rod 53521-S5A-003 Too Long
- is there a way i can use the dash and climate control from an 05 in my 96
- 03 Honda Civic ex coupe
- 05 Honda civic crankshaft position sensor
- Compression Test Stupid(?) Questions
- Heater core removal??
- Stupid mechanics I need some insight
- D17A1 Oil Galleries
- compression test on civic
- Changing headgasket on a D17A1, any advice?
- Ebay Universal keyless entry
- '02 civic lx 4spd auto, no reverse after overhaul.
- metal coolant pipe behind thermostat
- Overheating issue
- D17A1 Oil Pressure Problems
- Honda 2002 Civic using 3 quarts of oil a week after head gasket replacement
- How much boost i can use?
- Help figuring out why the engine acting up..
- Bad head gasket
- 2002 Honda Civic Ex Coupe Auto Transmission Shifting problems
- Keep blowing 80A fuse, please help
- Did I just fry my ECM??
- Motor Swap Help?
- 04 civic coupe overheats
- 2001 Honda Civic DX/GX SRS module issues.
- Cv axle/Transmission issues
- No Start Civic
- green flashing key on dash / no start
- Manual tranny fluid 2004 Civic EX
- starter motor is the only device in the electrical system that is NOT fused
- Humming sound
- 2002 Acura EL Power Window Problem
- fuel into ?
- Overheating problem
- SHOULD I BUY (HELP PLEASE!!!) 2005 Civic
- Not starting
- Misfire Cylinder 1,2,3,&4 also random mifire
- TDC/Camshaft position sensor question
- Mystery Part Left Over After Removing D17A2 Head...
- Civic Hatchback 1.6L 2004 - Starting Issue
- Cold air intake(swap)
- Possible transmission blow and overheating
- 2001 Honda Civic gx window issue
- 7th Gen Civic Hybrid to K series swap- Wiring
- 01 Civic Ex occasional overheating and coolant smell
- quick fix for a DTC P0303 (misfire) code on a 2002 Honda Civic LX
- Clunking metallic noise when driving with clutch engaged
- 2001 civic timing belt metallic grinding
- Need to program new key to ECM....
- Misfires on 2 cylinders that aren't plug, coil or injector
- Aftermarket injectors
- Cam & Crankshaft sensor problems
- 2003 d17 non vtec
- Engine Swap (Keep Transmission)
- Heater Core Issue?
- A/C runs when switched off
- Remote trunk release
- Help! A/C not working
- Window replace causes other windows to not work
- 2001 Honda Civic Timing Belt?
- 2001 civic overheating issues
- How would you fix an apparent open between MCU and A/C pressure switch?
- Motor Oil Leak, can't figure out from where
- 2005 1.7 cdti civic - oil sensor
- Replacing push rod seal without removing master cylinder
- Loose strut/knuckle nut.
- Steering issues
- Overheated civic
- 01 Honda Civic Crank but no Start.
- 04 Civic NoClutch or Fan, Climate Control Code #8
- Can't get transmission out.
- p0740 code and no voltage at TCC
- 2005 EX Special Edition (Canada) Swapping D17A to D17A2
- Shifting issues.
- Error code P0133
- the tube attached to purge outlet on the charcoal canister
- Starting issue
- Can I use an ABS brake booster and master cylinder on a non ABS Civic?
- P0730
- Needed: 2005 civic injector harness wiring diagram
- Honda civic 2002 loss power while cold
- 01 civic ac issues
- A/C compressor relay bypassed
- stuck in park and then wont shift out of first.
- 2003 honda civic cranks but won't start
- Rack and pinion
- 04 overheating problem
- Sawing through 02 Civic Oil Pan Gaskets
- Spark plug thread stuck in head. Stripped craftsman socket
- Dies on acceleration
- 2004 Honda Civic LX Side Mirror Cabling / Connector
- Auto trans to a manuel ???
- 2002 Honda Civic Lx starting problem
- 2002 Civic gas pedal suddenly unresponsive while driving
