Overheating
Overheating
hay guys so 05 Civic lx changed the water pump/timing belt the radiator/thermostat AND the head re dun by a Machine shop… Slapped it all together and turned on quick and hasslefree but… I still have the overheating problem tried to purge the system But either unsuccessful or did not do it long enough any advice?
Re: Overheating
Re: Overheating
Steve at Heart
Re: Overheating
Fans need to cycle twice while bleeding the cooling system. I suggest you invest in a Lisle Spill Free coolant funnel at the same time. Essentially raises the coolant point and helps contain any extra.
If the fans do not kick on check the sensors themselves with a multimeter.
Clash0901
12-11-2015 08:12 AM
