- Tire sizing and clunking noise questions
- Auto trans 02 Civic not shifting after (stock) engine swap
- Whining noise in reverse
- 2004 EX Shocks and Struts
- 01 Civic LX grinding transmission after swap
- Recaro SP3's in 2005 coupe.
- Clutch Issue...
- Check Engine Light 03 Civic SI
- Inner tie rod replacement
- Turbo charged my d17a2 and having issues help please
- Worth fixing?
- what is the stock 1/4 mile for an ex?
- 2001 civic cuts in and out at 3000rpm
- Using my Honda for Towing a Trailer?
- facelift / prefacelift
- 2001 Civic A/C Compressor making noises!!!
- is my Civic legit?
- 2003 over heating problem ( random )
- 2001 civic tie rod problems?
- Transmission Replacement
- P1361 TDC Sensor
- short shifter????
- 2003 civic front end noise
- steering wheel airbag swap
- strut assembly
- Intermittent problems P0420
- new headlight/bulb
- 2001 Civic lx (auto trans) occasionally stalls at stops
- Blower motor and AC clutch INOP
- is this all i need ?
- 2005 civic lx a/c problem not compressor
- 04 civic clunk over sharp bumps
- squeeking in rear
- 2001 lx weird issues with ac
- 04 civic over heating
- deep cycle battery or regular battery?
- 01 Civic Motor Mount
- popping sound front end
- specific question on frontend 02 to 04 conversion
- Suspension Clunk after new struts
- 2002 civic a/c compressor loosing ground
- A/C Component Diagram
- A/C weird problem
- 2003 civic issues
- Ghetto DIY Ram Air CAI for ES Civic
- How to check if dimmer switch is bad?
- a\c problems
- 01 civic engine cranks but won't start
- transmission problems
- d15b parts on d15y4
- 02 civic ex egr valve removal
- question about '00-04 accord/civic trannys
- Drain Battery
- what could be it? loss of power?
- 2005 Civic Weird noise
- civic choking out please help asap
- Can someone tell me what this is? 2001 Honda Civic LX
- 02 civic blower resistor
- Low Beams Won't Work
- transmission problem help code p0730
- compressor issues
- passanger window wont roll down
- Computers
- HELP! 01 LX new compressor, expansion valve, and dryer and not cold enough :(
- 2002 Civic EX auto, need new transmision...few questions.
- ES1 Windshield Fluid Light Always on
- Check engine light eliminator
- Transmission Range Sensor yay
- steep downward incline in park and vibrations.
- Automatic Trans Question
- 04 Civic LX Headlights on Reminder Bell?
- radiator fans in 05 civic ex wont work!
- 10w-30 oil too thick for d17's?
- Bad bearings? Rods? Ball joint?
- 2003 HCH
- 2002 Civic Lx check engine light (CEL)
- power surging
- 2001 Civic Voltage Issues
- 2003 Honda Civic AC Isuue
- A/C blows hot air
- Help! Civic Hybrid Cluster Swap
- 04 civic - crank, no start
- 2003 Civic LX AC Problem
- 01 civic hx
- If you got 15x9 pics post em!
- when to replace struts
- High RPM at idle honda civic 2004
- 02 Civic EX Base Timing Curves
- anyone knowledgable on the jdm d17a
- Prepping 2003 EX cylinder walls and mating surface for month with no head.
- recommendations on fuel injector cleaners?
- real quick would a dx ecu work on a ex? MT
- AC compressor always engaged unless relay pulled
- 02 em2 mods
- Are camber kits really necessary?
- Cleaning pistons
- Fuel Tank Pressure switch question - EVAP related
- A/C and Heater not working, no electrical response
- Honda civic Code P1457
- i have a 02 honda civic ex 2door
- recall 02 civic ex 1.7
- Oxygen Sensor Kit
- couple of questions
- Help Me Part Shopping
- Axle Shaft Seal
- 2002 honda civic manual transmission
- Front engine mount diagnosis
- 2004 Honda Civic Hybrid Tranmission issue or Flywheel?
- how to put back together a over extended axel shaft?
- Stock fuel injector size
- Civic em2 with d16w7 engine(from D17a8)
- New Blower Motor + Resistor suddenly stop working?
- 02 civic water pump
- Tail, dash, parking, license plate lights went off
- 04 Civic hood latch doesn't release
- Quality of AC components
- Which computer code reader for 2005 civic lx?
- 2005 Civic LX Oxygen sensors
- 2001 Civic Lx wont start.
- Ignition switch wiring identification
- Ac problem! Plz help!
- Odometer/Trip button
- Rear Suspension After Rear Disk Conversion
- alternator/ charging issues
- Keep or Sell my EM2
- ever notice the d17 is noisy.
- 01 civic electric issue
- 02 civic over heating
- A2 Oil Pan Swap
- Clicking sound that isn't drivetrain?
- stripped oil plug repair
- Looking at buying an 03' EX sedan, I was just looking for some tips/info.
- 05 civiv ex barometric pressure sensor
- d17a2 built head
- Em2 Fitment; 17x10's?
- electrical issues
- Need help 2001 civic EX
- Honda Limping with Check Engine Light (TDC Sensor Noise) and Battery Light
- What coilovers for my 02 civic ex?
- System Flush?
- P0420 Check Engine Light =/
- water leak HELP!!
- 2002 A/C Ice coming through vents during Summer
- What goes into disc brakes?
- 01-05 Civic ECU pins
- 2001 Honda civic Shaking at high speeds
- dashboard illumination out help
- 2005 Honda Civic EX issues
- 2005 Civic dlx speedometer issue
- Windshield Wiper Malfunctioning Issue
- weird Squeaky noise when AC is on
- auto tranny problem
- CEL not turning ON
- 2002 civic lx misfires
- 05 VP replacing head. HELP!
- 1.7 engine replacement
- Tranny oil question....
- weird light grinding/whistling sound from timing belt area after change
- monopola regolazione aria
- Good seats and tire/rims?
- The expansion valve and recvr. drier.
- Screeching sound coming from drivers side when steering wheel is turned all the way
- 6th gen Civic (Acura EL) seats in a 7th gen Civic
- Exhaust scrapes too much
- 03 civic lx start up problem
- 01 Civic LX Manifold swap?
- Civic Overheating Intermittently help!
- 2003 civic hybrid transmission range switch location
- 02 civic shift knob
- 2001 Acura 1.7 EL Overheating Issue
- This Temperature level is normal??
- Water pump thread on block broke off
- New Civic guy, dual CEL codes!
- 5 Lug Conversion
- Coil wires?
- 2002 honda civic HID kit
- Typhoon Civic
- How to make my honda faster?
- 01-03 Aero Front Lip Help!
- Probable AC issue?
- Weird situation with E Brake Light On Randomly, Brake Fluid Still Full
- electric load detector
- Temperature gauge issue (Civic LX 2004) MCU or ECU wrong?
- Rear Camber Kit Problems
- OEM Drum brakes compatible with other cars?
- HI, I'M NEW to the EM2/ES1/ES2 help
- it wont go down
- Header Questions...
- Cooling system upgrade....??
- Transmission Fluid
- d17a2 headers
- HELP!!!!!!! coilover alignment problem
- 01 LX Coupe Front Grill??
- 02 civic over heating and staling
- 05 Value Package radiator
- Ingalls End Links - Is this right?
- Rebuilding a D17- 02 Honda Civic
- squeaky noise when real easing the clutch
- 2001 honda civic ex sedan Dash lights and ac nobs arnt working
- Engine and trani swap,,,,PLEASE HELP!
- 2001 Civic codes
- 02 civic lx leaking oil
- 2002 Civic Transmission rebuild - need help
- rear lights won't turn on
- Strange Noise
- Air Outlet in Civic 2002
- more ball joint questions
- ISB life
- Squeaky belt with ac on
- 2003 Honda Civic DX
- Help Please! Honda 2002 civic check Engine light and power loss Issue
- EX Civic Stalls in Neutral
- Burning oil too fast!!! 3 quarts in 20 min
- 03 civic hybrid flywheel
- 02 civic ex with vtec runs fair up to about 3k
- flasher doesn't work on 1.7 el acura
- 2001-2005 transmissions
- 2001 Civic Smog/Transmission Problem
- Same noise different view
- what k swap mounts to use on a si subframe?
- First post, a few questions ... need your help please!!!
- 2002 civic code p1773 problem?
- Steering Noise
- 2005 civic ex p0135 code!! Light stays on!!
- AC not working. Tis the season!
- Rattling problem
- Speedo issues
- 02 Honda Civic won't start!
- Grinding From Front Driver!! 2001 Civic
- honda civicex 2002
- Rear Sway Bar
- Whats Different about Hybrid Floor Mats?
- a/c compressor problem
- 2002 civic ex won't start
- Lights pulsing....
- Drum or Disc?
- need help identifying a sensor!
- picture of 2001 honda civic hood prop
- P0134 code
- Show me your headliner
- whats this noise? (video)
- helppp! kSWAP
- replacing 2004 lx with a vtec head?
- Should my airbag have deployed?
- K- SWAP OR TSX
- vss
- 02 ex civic broken wheel stud
- 2001 honda civic 200k miles
- 2004 honda civic fuel pump relay location
- Transmission issues. Slipping after short drive.
