PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Light bulb change
  2. Transmission swap
  3. 2001 civic coupe driver side window regulator?
  4. steering column interchange?
  5. jdmfreak's build thread
  6. Where do I start
  7. 01 civic ex swap questions
  8. 02 ep3 timing chain stretch?
  9. 01 civic coilover question???
  10. clanking noise
  11. 2001 Civic loosing power
  12. tire size help
  13. What makes that noise?
  14. Rough Idle
  15. 2001 Civic Ex Stock Susp.
  16. 2001-2005 civic sedan front sway bar interchangeable?
  17. 2002 Civic EX 1.7L had top dead sensor fault and low oil pressure
  18. Funky looking K20a3 piston
  19. drop springs PLZ HELP!!!
  20. 2002 Civic EX no oil pressure
  21. 01-05 ex steelies how wide?
  22. Help Me Car wont go past 4K RPM
  23. Revs dropping when stationary??
  24. p1259 vtec system malfunction
  25. my coupe! need help with lowering springs..
  26. Rear Upper Strut Bar
  27. 2001 EX Compressor
  28. What should i do? 2001 lx vs 93 cx
  29. Best way to make my 02 Civic faster?
  30. Drop in fuel economy...'05 Civic sedan
  31. 2001 Civic 2dr/4dr headlight?
  32. stuck in park
  33. 05 tail lights in my 01?!
  34. abs codes
  35. incorrect gear ratio wtf?
  36. em cluster plugs...same as rsx?
  37. P/S belt shaking at bottom of crankshaft pulley
  38. a/c clutch problem
  39. leaking oil from valve cover
  40. A/C Problems god help me!
  41. AEM Intake!!! Please help
  42. ATF spec?
  43. What would you recommend?
  44. Anyone mind helping me find some rims for my car?
  45. Sunroof Noise
  46. Wheel Question
  47. 2001 civic suspension problems
  48. 02 Civic dashboard bulb replacement
  49. D16W7
  50. 01 Civic LX 2Dr would these rims look good? (pics)
  51. seatbelt issue 02 lx
  52. motor swap question???????????????????????
  53. ac blowing hot at idle
  54. 03 Civic Si, rebuilt title. To get, or not to get?
  55. how to remove stock steering wheel?
  56. CLICKING NOISE
  57. HKS or Megan?
  58. Swapped Jdm Ls not starting..Need help
  59. 2004 honda civic ex overheating
  60. parts..... where to buy?
  61. not starting
  62. lowering spring question
  63. locking collars on coilovers
  64. What Else could be causing a P0420?
  65. 2004/2005 EL owners...
  66. Overheating Please Help
  67. Start car, cars goes to lean Wont go? Hesitation/ bogging, woes
  68. HowTo: Removing Windshield Molding
  69. Please help if you can
  70. searched but found nothing
  71. Can i drop the tranny without removing the subframe?
  72. Two spun bearings help.
  73. 03 foglight switch
  74. 01 4DR EX: Firewall ports? Seat / door removal?
  75. Whats Do I Install first?
  76. For us newbies...
  77. Who's Crashed Ep3 is this... (Socal @ GMR)
  78. Washington em2 group?
  79. blown koni?
  80. Ignition Lock Replacement? (2003 Civic)
  81. Quick Question
  82. 2002 Civic timing belt disaster
  83. Ground control coilovers stuck to top rotating disk
  84. compression?
  85. 2004 Civic EX Cpe
  86. 01 - 03 civic can fit the 04 -05 front end? plz help.
  87. KAZERA springs advice
  88. Turbo Kit or New Engine?
  89. Test Pipe Help!!!!
  90. ecu chips for more mpg
  91. Looking for advice on exhausts
  92. Suspension setup
  93. Greddy Ti-C Catback & AEM Short Ram Intake Sound
  94. Parts interchangeability
  95. rough idle and dies when put in gear... HELP
  96. Is it really necessary to use Synthetic + oil change every 3k?
  97. 2005 Honda Civic Code to reset radio
  98. Heat Shield Fell Off Today
  99. Halo foglights
  100. rsx type S spoiler
  101. Car Won't Start
  102. 02 civic Transmision help please
  103. Replacing Oil Pan
  104. HKS HI Power Axleback Exhaust
  105. Reseting lights on cluster help.
  106. D17 transmmission compatibility
  107. Another no start- flashing green key
  108. 05 CIVIC kswap or BOOST?
  109. My 05 Automatic Civic's Throttle Position Sensor Went Bad. Need Help.
  110. Have any of you guys ordered from DDM Tuning recently?
  111. What is the cheapest, functional cat I can buy?
  112. 02 civic airbag delete
  113. need to remove both exhaust sensors
  114. 04 honda civic, makes grinding noise when clutch is let out.
  115. 2002 Civic EX ATF
  116. A/T Transmission Flush?
  117. Can someone confirm if this is the correct front jacking point for 2002 civic?
  118. post your si wheels on 7th gen with tire size
  119. Code P0301 Misfire on Cylinder 1.. Help
  120. wtb 01-05 stock ex downpipe/cat
  121. Rim color!
  122. Rear PIA shoe spring!!!
  123. side markers
  124. fan on and off
  125. HSD HR coilovers VS GC/Koni Yellow setup
  126. **!Picture Request! 04-05**
  127. Light Bulb Questions
  128. 03 CIVIC HYBRID 1.3L
  129. W.T.K.: Headers & Exhaust for 2003 Civic VTi
  130. civic rear deck: you've got to be kidding
  131. Wheel Sizing Question
  132. 2001 civic loose plug and a check engine lamp
  133. Need ur guys help with annoying squeal.......
  134. Car running rough under WOT
  135. Oil Catch Can. What vacuum like to attach it to on Manifold?
  136. Manual Tranmission Issues
  137. EM2 No Start
  138. question about my 2000 honda civic LX please help!
  139. noob
  140. QUESTION!
  141. Boosted 03 Civic Si with a knock code
  142. Sagging Mid/B-pipe
  143. Measure your drop?
  144. Coolant Change Question
  145. What octane on EP3 Si wit I/H/E
  146. difference in transmissions
  147. seat bracket
  148. Front End Shake
  149. HEAD GASKET
  150. 4 rims is +15 to aggressive would it affect handling ?
  151. A/C electrical problem
  152. civic and rsx ball joints
  153. 2005 Civic- Can't rev over 4k rpm
  154. red H emblem for 2003 civic ex em
  155. Were to get progress coilovers ?
  156. '01 Civic HID Help!?
  157. Problem with lean or rich condition on wife's car.
  158. Progress Coilovers?
  159. Seat Cleaning?
  160. 38K Miles on TSI Turbo Kit =
  161. 05 Civic takes a leak
  162. 2 inch lowering questions
  163. civic 01+ oem ignition coils capability ?
  164. Dire need of Help (Headlights) - Selling my civic
  165. SPC camber kit
  166. dashboard light dont work
  167. Dome Light Honda Civic O3 need help
  168. AEM V2 intake
  169. K20 Swap
  170. JDM OEM Head Lights
  171. front End link bad?
  172. part number request
  173. subframe brace, beaks tie bar, lca combo?
  174. 2001 Civic LX Rough Idle/Vibration Problem
  175. 05 Civic cluster problem, [gauges]
  176. After market 6"x9" speakers wont fit into rear deck?
  177. rear cam seal Q?
  178. Anyone Running a VAFC2?
  179. 4 door rear window compaird to 2 door
  180. MY 2005 HONDA CIVIC 2DR COUPE Si/EX - LET ME KNOW WHAT YOU THINK :D
  181. 2005 HONDA CIVIC 2DR COUPE Si/EX HEADERS??????
  182. strut mounts
  183. tein basic coilovers problem
  184. Honda Motor Oil
  185. D17 turbo + Internals- How much boost?
  186. k24 swap questions
  187. What would you do (style opinions?)
  188. Apexi N1 OR Hks Hi Power?
  189. 01 Civic LX Immobilizer Chip Removal
  190. What is the difference between NGK PZFR6F-11 and NGK ZFR5F-11 spark plugs?
  191. cant pass 4k rpm
  192. Squeaky Top Hat
  193. Civic won't start - flickering dash and radio
  194. does anyone know a good website for rimes
  195. What should i do?
  196. Wild setups?
  197. smoked tail lights?
  198. Heater??
  199. 01 civic ex trans axle/ transmission
  200. Spacers worth it?
  201. Skatejosh's build thread
  202. Need 2005 civic lx front bumper in silver
  203. RPM Revving
  204. Weird problem
  205. 01' civic ex misfire after engine warms up
  206. D17 transmission w/boost...
  207. Might be my Throttle body?
  208. AC question
  209. need help. hard to shift into gear
  210. Mod Help??!
  211. will this overhaul kit work
  212. Is this a bad head gasket or a bad rocker cover seal
  213. 2002 Civic EX V-TEC problem... PLEASE HELP ASAP
  214. My car so far.
  215. About Taillights......
  216. Purple royal
  217. really bad toe in need help??
  218. What type/brand of Sparkplugs to use
  219. axle replacement 2001-2005 honda civic
  220. need help asap i need to replace my trannie
  221. Stray grounding wire
  222. Tie rod end replaceing
  223. need help ASAP, civic overheating problem....
  224. hood damper kit
  225. what would YOU do to my civic?
  226. em2 mud flap question
  227. Looking for a d.i.y on cruise control removal
  228. Fuel Injectors
  229. Control arm bushings
  230. Need help with a blower motor problem
  231. Will 13 inch steelies fit our model
  232. Where to buy paint?
  233. How long does it take to take you guys to change the Timing Belt?
  234. alignment question
  235. I have a 2001 honda civic sedan lx
  236. DIY on Rear Drum Adjustments
  237. Type of Grease for Window and Sunroof
  238. What is a good site to buy EM2 aftermarket Parts?
  239. Need advice from the best
  240. '05 Honda Civic - Compliance Bushing
  241. B18 swap
  242. Painting side under spoilers
  243. Removing rust
  244. Help!!!!
  245. badges
  246. B&M short shifter
  247. power steering removal
  248. Squeaky noise
  249. Keyless entry remote
  250. 2001 Civic Ex, Wheels
