- trouble with my oil change and need answers please
- green 'key' light comes on; won't shut off even while driving
- how do I R and R my front rotors
- What is the shift knob thread pitch?
- water on windows...
- dx intake fit an ex
- NEED HELP!!! weird noise
- 01 LX vs 02,03 civic hatchback service manual
- Hid Problem.........
- Camber Question... Don't worry, I'm not gonna ask if I need a kit...:)
- clearance issues with lip kits?
- SRS LIGHT ON
- Misfire with lots of codes, please help
- New Struts 2002 Civic LX
- turbo setups for k20 engine sway for em2's
- clutch??!?!?!?!?!?!?!
- knocking or rumbling
- Aftermarket Fuel pressure regulator
- dash lights not working
- tie rod and drive axle problem
- ANY TAKERS?
- idle ramping idles at 1000rpm and jumps to 1500 up and down
- what spray paint shud i use? (HELP)
- Hi! Long time reader but first time poster! (now with spelling errors!)
- rsx strut on 02 civic
- jackson racing charger on my EM2 need sum BRAINS here
- DX 01' tranny question...
- Compression testing.
- Show Off Your Exhaust
- K-series into EM2 wiring harness question.
- Removing power steering?
- rsx shift knob
- Exterior Windsheld or "Garnish" Molding
- rear disk breaks?
- Skunk2 60mm Cat-back + DC Full race header
- drag videos
- battery light question.
- Flickering Lights
- Timing belt tensioner went out, head is dead
- question concerning my ball joints
- Headers?
- 03 Civic Ex - Keyless remote problem
- Intermittent hard steering problem
- Problems with Coilovers?
- rsx sway bar question
- window visors for 01-03 fit 04-05?
- Installing a 2001 Honda Civic LX Cassette Radio?
- Auto A/C in Civic?
- Civic Sedan Jacking Point
- The D17
- God i hate honda y r they so different..any1 done rod/main bearings on a 02 civic
- 2001 Honda Civic LX engine "Tick"
- OEM hood problem
- Cleaning the engine bay
- Rep your engine bay thread.
- si wing
- Rust under hood, at the shock tower.
- How to: DIY black out 04-05 civic headlights
- switching from auto to manual
- AFTER MARKET SHOCKS WITH OEM SPRINGS??
- temp gauge stuck???
- Getting new rims
- NI fluid in radiater make car jump???? 02 civic ex true??
- headlight bulb size
- k20 swap + turbo video
- Master clutch cylinder removal
- tail lights
- D17 turbo writeups?
- How To: 01-05 Civic stealth alarm install
- Car Alarm
- Nitrous???
- What is this for?
- 2005 Lx issues?
- 2002 cruise control goes in/out
- idle jumpin when driving to like 4000rpm then to 1000??? 02 civic ex
- how about some help with blacking out headlights on an 04 civic 2dr
- were these strut bars installed correctly
- 04-05 rear bumper!(HELP)
- HELP!!!! Maintenance REQUESTED
- I/C + Piping
- Over heating problem
- ignition switch problem
- wtf:another tranny problem!!
- Need to replace my ABS wheel sensor on my 02 civic....
- Stumped: Clicking noise while turning, not CV Joint
- Will this bumper fit the LX 01 sedan
- any em2 civics on gsr blades?
- Limited slip
- Need Help please?! 01 honda civic ex 4dr automatic?
- plug and play HID
- AUTO TRANS PROBLEM
- CUSTOME D16 MANIFOLD ON D17A2???????????
- dancing temp gauge needle
- Pulling engine codes?
- Can someone help with installing a techometer in a 2004 civic?
- Traction Bars for EM/ES?
- '01 Civic LX PO325 Engine light (Knock Sensor)
- HELP driver side window wont go down.
- How do you remove this?:
- Does anyone have any experience with Megan Racing Exhaust?
- Who's got tow hooks?
- HELP! 04-05 Tail light removal!
- Problem with the Alternator
- side mirrors
- 04 EX Double Din Install
- alarm
- jdmcarboy
- 20" rims???
- What body kit is this?
- Strut Dilemma!
- 2003 Sedan Ex, Speed limited
- when did your D series engine die and why
- toyomatt84
- HFP lip kit (aero-package)
- Other than a K
- quick ac question
- Will this fit???
- Stollen car.....9-4-07...
- Exhaust or Cold Air Intake for 2001 CIVIC LX f--- which first...what kind? 200$ TO SPEND
- Would 04-05 Tail light fit 02
- automatic door locks aren't working
- Problem with 02 Civic headlight bulbs
- Trading in??? What do you think?
- exhaust HELP!
- In the headlight housing on the 01-03's...
- Just wondering how much this Costs??
- noob question
- ecu
- battery relocating opinions
- how to remove pine sap.
- Is modifying an Automatic LX Sedan worth it?
- power making on a d17
- em2 ecu
- How to take off the shirft boot off of my civic 01'?
- help with squeeking noise (audio included)
- help 16" steelies 4x100
- 2001 civic wont fire please help
- Help with carbon fiber trunk
- car stereo installation, now stuff not working
- My 05 civic . . Tein SS now on ! 2" drop
- KMS or JDM Fabtech intake manifold
- I can't get my Transmission out?????
- HID
- Dust cover on tein basics
- lets see some s tech coupes
- emanage ultimate
- srt-4 injectors
- Do RSX-Type S injectors work well with D17A engines?
- Driver's seat had some "play" in it, (feels loose)
- em2
- finally building motor
- help need to install a vacuum gauge
- were can i find this lip kit?HELP!
- Grille Install
- READ ME: "End-all" 7th Generation Civic Suspension FAQ's
- $10,000 In A Dream
- alignment
- got the wheels back- what do you think?
- VTECH Engine Parts Upgrade Questions
- air dam to cool rotor
- good flowing exhaust
- Fog Light to Parking Light
- can any one tell me what body kit this is??? plz
- trouble with transmission
- Strange "steamy" smell coming from the car
- Is it wurth it?
- Input Shaft Bearings & Throwout bearing
- Dezod's Intake Manifold
- k20 intake
- Unfamiliar tuning programer
- Custom Trunk Jobs
- Which seat?
- Install Power Windows and Locks in 05 Civic?
- No More Broken Fogs
- Tein Rear upper strut bar RSX will fit 01 civic ???
- jdm fog lights
- SWAP HELP!
- Question????
- red jdm emblem on black
- K20 question
- red steering wheel emblem
- disable autolamp!
- V-TEC Help!!!!!
- 01 and 03 shocks/struts
- Ebay fogs
- somebody's em2 from 7thgencivic.com
- coilover diffrence 01-03 to 04-05?
- power door locks
- I BROKE MY CAR AND NEED HELP!?!?!?!?
- HT to the rescue!!! Please help. Window Regulator....very confused.
- mirrors?
- Will this catback fit my car???
- rsx seats on 01 civic
- Where can i buy 2004 civic lx hub caps?>
- How much is a 2004 Civic LX coupe worth?
- 2006 si seats, will they fit
- ebay headlights?
- whos going to the honda tech meet in Toronto?
- AC Trouble
- $5000 to spend on engine em2
- tornado in illinois
- For Sale 2003 Honda Civic SI w 85k near Charlottesville, VA
- will em2 5spd work with k20a3?
- Auto-Transmission Failure
- What do you guys think?
- headers for civic lx
- HIN
- 1/4 mile times: turbo and non turbo
- HEADERS QUESTION??????????????
- I need wheels!
- hi new member here and i have a job
- Proud new (kinda) Honda Owner - 2003 LX
- from D17 to K20
- How to get spray paint off?
- taking off air ride suspension
- looking for a DIY for rolling fenders
- what are the lowest to highest performance for brake pads
- Odd sound coming from engine
- 2001 Honda Civic Intake air temperture assembly
- Noise from driver's rear tire area - 2004 LX
- Replacing rear wheel stud?
- Loss of Power on 2001 Civic LX 5 Speed
- check out what i did today!!=)
- overheating car... ( had honda figure whats wrong with it )
- Are there Upgrades for spark plugs?
- rsx injectors in em2
- t66 turbo in 2001 civic?
- How long have you bee on stock struts?
- eyelids or eybrows
- audio code (audio problem)
- carpet and coardboard in trunk (above spare tire)
- Inside crome covered door handles?? please help
- selling 2002 si cluster
- Tanabe Sustec Under Brace
- Rattling Engine
- 8/18/07 Photoshoot
- EM2 Based Atom-like Homebuilt Project
- F22C1 swap into '02 Civic Si
- Key broken in trunk keyhole need some help
- what kind of bulbs can I use?
- 01 to 05 civic reliability
- changing my tranny fluid and im wiggin out
- 01 Civic Power Windows
- 2004 Civic Stereo removal
- Water Leak
- vtec effects the brakes?
- Pictures of a recent goodies added to my car
- I think my EM2 is about to break down
- Tires for stock wheels
- EM2 Emblem
