- Front bumper..
- Battery-Charging Problem Help Me ASAP...Searched
- EGR Insufficiant air flow Code 401
- planning on buying an em2
- for those with greddy sp2, concerning hangers
- Tein basic coilovers
- Will 13in rota RB fit our civics
- Airbag system, 2005 Civic
- Need help 2001 civic ex driver side frame
- quick transmission ?
- HID'S NOT WOKRING!! PLEASE HELP!!
- SRS LIGHT!
- Tranny?
- S2K Cluster in EM?
- Tranny seems to be going out??
- 2003 Civic Sedan interior problems
- Belt Noise?
- Riddle me this? I have clutch master cylinder issues?
- Trunk/Gas release is screwed up
- D16Y8 parts in d17?
- Is there a difference between driver & passenger front struts?
- Suspension question
- Overheating at idle 02 CIVIC 1.7L SOHC
- will a s2000 or insight airbag fit into an ep3 steering wheel?
- Clutch Reccomendations
- new alternator installed...squealing...is it not tight enough?
- skunk2 pro series
- CRV 03 DTC P0166 O2 sensor no signal Bank 2 sensor 3 --what does this mean?
- k20 em2 rbc problems
- Are there any full coilovers that will allow the car to be adjusted to stock height?
- Clicking/griding noise when first accelerating?
- Lca question
- Crower stage 1 cam...results?
- oil change question
- Clutch issues
- Performance Alignment
- Spacers Question
- Idle Control System problemo
- Rolling Fenders. Not a DIY Question.
- Replacing A/C compressor...need advice/help...
- Grill Trim Under the Grill
- ABS brakes in 01-05 Civics
- Turbo Question..
- water leaking from two exhaust gaskets near muffler
- Front end pop/noise when gas/brake?
- hks hi powered exhaust question
- front control arm (searched)
- 05' Hybrid throws a rod?!?! Any insight, please help
- Should I use inverted tie rod ends on my 2002 Acura EL?
- Do 04-05 taillights fit on 01-03 coupe models?
- Need stock ac and everthing for it
- full coilover help
- Hazards
- Brake Noise
- SUSPENSION!!!!!!!!!!
- civic trim?
- 01 signal light conector
- HELP about k20a fueling system
- A/T - Coasting in 'N'
- Hard time driving manual
- Front End Vibration
- Headlight Fitment
- Are grounding systems worth it?
- Where to buy an OEM gas cap for cheap?
- 01-03 to 04-05 front end conversion
- knocking noise coming from rear left side of the car.??
- 01 civic ex won't go pass 3000rpm.
- Auto Trans Problem.....
- odd noise at 1,000 rpm
- red emblems for em2?
- springs and coilovers
- ECM/PCM Key Questions
- Car Hick-ups
- check engine light after header install
- b series swap...is it possible
- 2002 Honda Civic SI OEM Rims
- Buying a civic...things to look for or check?
- Carbon build up
- Civic 03 car doesn't start
- My car is starting to shake a little more each week
- Wierd auto tranny problem???
- VTEC Controls
- Key Conversion
- Catback Exhaust Question with LX AND EX
- motor mounts blown
- I have a hard time checking my coolant
- civic 01 is acting weird fuel/elect??
- AC doesnt blow air???
- What PSI should i use!!??
- 4x100 to 4x114.3 adapter?
- preventing blown head gasket from a turbo
- key stuck ignition
- Exhaust swap question
- Issues with AC unit on 04 hybrid
- Bearings bad in AC compressor/ need to reroute belt?
- Question about interior lights
- installing extended studs on rear drum
- Looking for mirrors
- 2005 Civic Driver door lock with key only
- 01 ex coupe looking for a mild lowering
- 2001 ex short shifter-B&M or TWM
- 1999 Honda Civic Sir, Car not starting, rapid clicking noise
- Gauge Question
- 1999 Civic Si wheels on a 2005 Civic
- Electricity problem in 2001 Civic
- question about aftermarket header and O2 sensors
- What are your thoughts on skunk2 sleeved coilovers?
- Auto to Manual Conversion
- Rear spring problem
- How Else Can I Drop It Like Itz Hot?
- Increasing torque in the d17
- suspension advice
- Brakes?
- Where to jack rear of 02 Acura EL?
- looking for a car from a magazine feature....white em2 k20 5 lug
- Tranny issues asking for help and insite?
- Anyone Know the Chasis Codes?
- 02 1.7EL Brake Issues
- Fit wheels on 02 civic
- DC5 exhaust fitment
- Horn sounds weak. Anybody agree?
- road trip tips
- dumpt / slammed setup?
- Couple questions
- bump steer?
- block questions.
- hID kit for 05 civic coupe em2
- Knocking in front Suspension
- Loud road noise
- Timing Belt Time... yay.
- Injen IS1565P
- right tire rubs on fender well over...
- Decked d17 head?
- Check engine light. HELP!
- Have you had to have your oil pan gasket replaced?
- How much do shops usually charge to change seals?
- Quick Release...EP3 Steering Wheel...
- Suspension Set Up
- progress coilovers
- couple of Q's for my Gf's 4door
- Turbo coolant help
- can u tell me the diff
- Questions about installation of EL Side Skirts
- pics request custom painted valve covers or wire covers.
- 01 vs. 02 upper mounts
- Ive been convertered.
- About to check out a 2002 EM2 EX, what should I look for?
- 01 civic air conditioner clutch doesn't spin
- upholstery in my trunk smells very strange
- battery/alternator upgrade. . .
- need help to fix my honda civci 2002 trunk cable to open the trunk?
- Turbo....
- k sport gt springs
- Considering buying this, is it fixable? 03' LX
- Hub 02 Civic
- transmission shift lock?
- Ground Control & OEM Upper Mounts?
- Interior Dash Lighting?
- used car buying guide
- I didn't read the rules, or even bother to check the FAQ's.
- Beginner lookin to fix up an EX
- VTEC crossover
- Just bought an 04 coupe, looking for some advice
- OEM SILVER MIRROR
- 2001 Civic Brake Pedal Travel
- Suspension squeek, possibly rear lca
- Door Molding/Trim Removal???
- Button Lights Doesn't Light Up
- springs
- springs poping problem (HELP)
- replaced front struts on 2002 civic sedan and now some weird noises
- front grill
- Why can't I pull my engine from the top?
- N1 Catback Exhaust. Missin Piece???!?!!
- Trailer on EM2??
- New
- My clutch makes a clicking sound
- whats with my e-manage questions getting erased
- D17 Compression PSI#'s??????
- Will Ex bolt up to Lx?
- Replace Engine Coolant
- HElp With my gauges
- recall link?
- 2003 Civic Hybrid fuel injectors
- Lost oil to half the valvetrain (2002 1.7 SOHC non-vtec)
- Exhaust Question?
- Where can I order black grills?
- What do these bolts do (suspension)?
- couple of problems after putting rims on
- exhaust headers on new head
- Steering Wheel is angled when going straight....02 Civic 4DR
- Installation Tommorow! Camber Ques.
- Rattling Noise from Hood
- Suspension or Strut problems or something totally different??? Help!!!
- manual swap =]
- ( look for pictures of B-pillar in em2 or es1 ) Delete this post when solved
- 04-05 Reverb/Aero
- car pulls right? few things I've checked but not sure
- ground control or skunk2 coilover
- quick question on coilovers
- exhaust stuff
- How to tell between coupe or sedan mirror?
- Any one heared of a k20c?
- reverse glow gauges help
- Difference between Ex/Dx
- engine code. ?
- db8 rears in 01-05 civics Q
- 01 civic front brakes (rotors)
- I'm looking for Black and Red rear seats for a Sedan
- Compliance Bushing choices - OEM or poly or solid bearing?
- '04-'05 grill on '01-'03
- gas hand
- Headers on an Automatic Civic LX 01?
- looking to buy a 2001 civic LX
- NOOB: I've began modding, what next?
- cluster
- Polyurethane Kit
- OK im a newbie to car stuff ( need some help )
- Loss Of Power
- car is stopping at 82mph
- has anyone found this piece yet?
- My Build Thread
- S tech springs fitting properly?
- headlight help please!
- EXHAUST SOUND PROBLEM!!!
- 2004 Civic Hybrid Camber Issue
- optional chrome exhaust
- My Build Thread
- 04 trunk lid fit on an 01?
- K sport Rear Camber? any good?
- Rotary air control valve problem?
- Front Wheel Bearing Problem on 2005 Civic
- 1.5" drop on 215/45/17 ? Help please!
- HELP ON A DX HEADERS!!
- will 14 inch fat five del sols fit 2002 civic.
- HFP Lip Kit 2005 Civic EX Special Edition (Where to purhase)
- a/f gauge question
- Suspension
- gears not going in?
- throttle response
- Air conditioning smells REALLY bad
- NEED HELP!!!! staling problems
- R&R Cylinder head with intake attached? 2002 1.7
- roof spoiler
- 05 front lip
- uprade/build critique
- CARB Legal turbo kit?
- WTK: Would DC5 ITR Pedals and floor carpet work on our ES?
