PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Reverse lights dont work...sensor?
  2. 2001 Civic Sedan brake problem
  3. How to Remove Front Bumper
  4. 2 Step ?
  5. door lock problem
  6. VIN # question
  7. Transmission problem, maybe clutch please help.
  8. What is going on under my car?
  9. Common for autolocks to stop working?
  10. k20a3 is it worth it?
  11. Engine Noise
  12. hard starting
  13. new suspension......
  14. New Honda....DIY's
  15. clicking sound while braking?
  16. SRS and ABS light flashes during driving, lose all electrical power
  17. ecu reset, car wont start after limp mode
  18. 02 Civic Install
  19. RSX exhaust fitment
  20. 2002 Acura 1.7EL: Replaced front and Rear Brakes
  21. rear wheel brakes
  22. 02 Civic EX Sedan Suspension upgrades
  23. '05 EX SE sound system problem, please advise!
  24. RSX Seats and "SRS" indicator on cluster
  25. Disabling DRL, lord help me
  26. HELP ! i need a list for rear disc Conversion 2002civicDX
  27. Help me decide EX or LX?
  28. stage 1 camshaft
  29. warranty b.s
  30. 01 civic LX vtec swap question
  31. RS Lip Kit
  32. temperature gauge fluctuating for 01 civic
  33. oil psi light! spun rod bearing
  34. Car feels like it has an oval wheel
  35. Confirmation on 2002 Acura EL / Civic Si Brake Torque Specs
  36. clutch squeeks when pushed in and let out
  37. Help: First-time installing head unit and damaged some electrical systems
  38. tokico blues
  39. HELP finding self diagnostic for trouble codes
  40. coolant flush & powersteering - how often?
  41. what am i hitting?
  42. Nav Install Question: Need Reverse & Speed signal
  43. could anybody help me out, immobilizer systerm indicator
  44. Does it matter where i get my cai?
  45. anyone know where to get an o1 civic manual online
  46. Headlights?
  47. neutral safety switch
  48. Crankshaft Position Sensor Location?
  49. cloudy headlights
  50. Ignition switch (key cylinder kit)
  51. Hid h4 wiring harness..need diagram
  52. 01 civic runng rich need help fast my only car
  53. does anyone know how to look up part numbers and find actual pics of the products
  54. Need Help 2001 civic ex running rough
  55. JDM Type R cluster
  56. lowering question
  57. Breather car on auto trannies
  58. help with kpro and o2 sensor
  59. Daytime running lamp relay install
  60. Starting Issue..
  61. CuStOm InTeRiOr....?
  62. acura el automatic climate control
  63. 2004 front end conversion
  64. 01 ex near stall/bogging
  65. DIY: Auto Console to Manual Boot Console
  66. em2 k20a2 cold air intake
  67. DIY Headlight bulb replacement please
  68. One Windshield Nozzle broke.....What other honda's could I use?
  69. 2005 Civic Hybrid o2 sensors
  70. Question about the Canadian Acura EL
  71. Looking for replacement fuel pump
  72. My Build Thread
  73. is this the RS lip?
  74. dc5 sidemarker BIG problem!!!!!!!!!!!
  75. fog light switch question
  76. Park. Brake Light On & Gauges don't work
  77. voltage stabilizers?
  78. 01 Civic DX coupe A/C Question
  79. Control arm bushings
  80. 3 inch exhaust for 01 ex coupe
  81. BEST LOOKIN REAR SWAY BAR??
  82. clutch problem
  83. Give Me Your Opinion of Skunk2 Coilover Sleeves
  84. Optima Battery, what do you think about it?
  85. coolant flush..
  86. Power Door Lock Problems
  87. WHERE IS CRANKSHAFT SENSOR on 02 Civic LX??????
  88. 2002 Honda Civic, sputters when exceleate, doesn't loose power.
  89. Upgrade to sportrims while maintaining the original wheel diameter.
  90. suspension question
  91. cabin air filter
  92. whistling problem
  93. HID for 03 civic projectors?
  94. K20 vs. K24
  95. could it really be an ex?
  96. exhaust question!! searched
  97. Civic Coupe Package Shelf Removal, Any Shortcuts?
  98. SUsupension question 2005 civic will rsx struts fit
  99. 02 Civic EX A/C question
  100. Headlights are not turning on
  101. Will EM2 Headrests Fit on 99-00 civics??
  102. Front lip hardware included when ordering from Majestic?
  103. Airbag replacement confusion
  104. headlight
  105. Gauge cluster problems
  106. new shocks/springs
  107. HONDA CIVIC 2002 AC PROBLEM
  108. exhaust tip.
  109. no door ajar/key in ignition beeping
  110. suspension problem
  111. carbon fiber lip kits
  112. camber kit install
  113. gsr head
  114. Cat Messing With Oil?
  115. Removing mirror from side mirrors??
  116. Disappearing Coolant?
  117. 01 hoda civic EX octane kit
  118. hub bore...
  119. Coilover Question? Whats The Lowest
  120. Stock Radio Head Unit Question
  121. Lowering Height of Shift Knob
  122. maintenance required?
  123. K20 swap, exhaust question
  124. squeak when i let go of the gas pedal at high rpm...
  125. k20a2 valve spring problem?
  126. Does the DC5 Mugen strut tower bar fit?
  127. header bolts fell off..
  128. i/h/e question...
  129. Car is producing white smoke after a header installation. What is the cause?
  130. 4 door, anything i can do?
  131. 2005 Honda Civic blower motor
  132. Civic hybrid lowering?
  133. is it worth it?
  134. exhaust size?
  135. After market radio help
  136. radio code???
  137. EM2 5 lug
  138. what i heard... myth or truth
  139. Post pics of your drop
  140. idle low?
  141. 15 to 14
  142. Gas mileage is horrendous on highway driving
  143. aem cold air vs. v2 intake
  144. lowering questions
  145. d17 valve adjustment?
  146. Sister looking to buy 2002 Civic DX - Anything particular to look for while buying
  147. k swap
  148. pic request/knowledge, wheel sizes
  149. possibility of swap?
  150. OEM Honda Parts for 7th Gen
  151. Post your carbon fiber front lip.... I'm debating on getting one so I wanna see pics
  152. 01 civic front end popping noise when going over bumps
  153. 2002 civic meitnens light
  154. catalytic converter, manifold, and gasket
  155. turbo build up and car build up
  156. Automatic Transmision Problems
  157. 03 Civic EX Random Stuttering
  158. Camber Question --> Searched, no such luck.
  159. Installing the shift knob
  160. cooling system problems - Aux. Fan??
  161. dust cover touching coilover
  162. A/C
  163. Is This legitimate?
  164. EM2 bad accident, bent rear tire. Looking for any help.
  165. good combo?
  166. A/C "whooping" noise?
  167. 2003 civic door handle problem
  168. temp
  169. 01 manual tranny question
  170. Foglight on with parking lights mod?
  171. Hybrid model side view mirrors Q.
  172. tach suddenly stops working
  173. 2002 Civic Ex Transmission Issues
  174. perfect shifting
  175. 2003 Civic Alarm automatically arms itself
  176. dc5 itr cluster installed
  177. Need Help with my suspension on a 2002 Civic LX Coupe
  178. *searched* mid pipe Q
  179. How do you remove the rear shroud over the speakers?
  180. Vibration in pedals, HELP!
  181. emblems
  182. Ignition timing???
  183. 02 Civic LX cranks but won't start - PLEASE HELP!!
  184. springs for the trunk? do they make them?
  185. Megan Strut Bars
  186. xbrace worth it?
  187. where can I get a euro boot
  188. headlight bulb on 2002
  189. more horsepower less cash
  190. Backfiring
  191. How low does your exhaust mid pipe hang, from the ground? Pics
  192. auxuliary audio input
  193. going to the drag strip 2morrow.
  194. 5 lug conversion?
  195. Wheel size change in mind. Would it cause problems?
  196. Torque converter + new tranny???
  197. 2005 Civic pulling to the right
  198. engine rumbling the whole car? Why?
  199. Replacement axles... where should I go?
  200. To those with Tein Basics
  201. Honda civic lx 2001
  202. Civic 2002 Electrical question
  203. quick question on H emblem
  204. i could be putting an NSX motor in Civic..
  205. what to use for tuning ?
  206. How so low?
  207. 2003 Civic Hybrid Column Shift Stuck (Automatic)
  208. tein hood damper
  209. power wire, where to go??
  210. Front driver side suspension feels like its banging/clunking.. compliance bushing?
  211. dropin a k20 in my civic
  212. suspension question??
  213. Good numbers?? what do you think?
  214. Head Gasket..
  215. 7th gen civic stock muffler fit 5th gen eg hatchback?
  216. Recycled engine installed, TDC for first start?.
  217. Type R Badge
  218. Front Brakes
  219. drum brake conversion?
  220. d17 + GT30 + 31 psi = .....
  221. Honda civic 2001 headlight fog
  222. rsx cluster swap. need pinouts
  223. What is the best year 01-05 automatic transmission?
  224. door locks
  225. bent valves
  226. Alternator/Battery light flickers when it drops to 12.4 Volts
  227. A/C problem
  228. master or slave clutch?
  229. Aiming Headlights???
  230. car not cranking or starting
  231. High flow cat.
  232. Timing Belt - When to change
  233. Tried everything, and still pops out of 5th
  234. help with my cluster
  235. Shift Boot Question
  236. Alignment Question
  237. Headlight Housing !!
  238. ?which grill fits 05 ex?
  239. ethanol
  240. RSX Type R Spoiler
  241. Very loud sqeauling/whistling sound coming from engine
  242. 01 Civic intermittent overheating
  243. Alignment issues after lowering my car.
  244. New Roof Liner
  245. Fresh Dyno and 1st time at track on upgraded boost set up!!
  246. problem with 2002 Civic Gauge Cluster... Totally Confusing...
  247. Having issues with faulty catalytic converter. Need help with a possible resolution.
  248. No Power to My Civic
  249. 2002 ex
  250. no power?
