Passanger high beam not working.
Hey folks,
I just bought an 02 civic and the passanger high beam doesnt work. I replaced the bulbs, checked all fuses, believe I checked all relays. It's a dual beam bulb, low beam works fine, but when I turn on the high beams, only the drivers side works.
Any suggestions would be appreciated.
Thanks,
James
Thanks,
James
Re: Passanger high beam not working.
Might be break in the wire at the harness area (or anywhere along the circuit from harness to fuse box to light switch). Got a test light?
I dont have an actual test light. I used some wire and a dome light bulb to test the headlight plugs and I get power to the plug, but none when i turn the high beams on.
