PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Thanks to the Moderators
  2. 2002 Civic Ex Front End Shimmy
  3. 2001 civic ex Sitting for 5 years
  4. How do I know if I have keyless entry?
  5. 02 Civic Tachometer problem.. help
  6. Clicking noise??
  7. Where oh where is my coolant going?
  8. Can bad alternator cause no battery light?
  9. 2002 civic wont start
  10. Possible fried ECM?!?
  11. need help on rear visor for em2
  12. D17A2 P2W CLEARANCE SPECS?
  13. Bought my first civic!
  14. Oil bypassing filter
  15. Over heating/blowing cold air/fan not turning on
  16. 2003 Civic Coupe After market exhaust sensor fix
  17. 2001 Civic Dx Oil Leak- automatic
  18. Clunking sound in front.
  19. Mudflap question...
  20. Electrical problem after car is serviced
  21. D Series Cyl. Head Swap
  22. p1505 and p0505, need some help.
  23. Help! Fog lights
  24. Messed up engine
  25. 2001 civic ex 5sp will not stop revving on its own.
  26. Only Starts with Scan Tool Connected
  27. URGENT HELP!
  28. 2 or 3 core radiator in 03 civic lx sedan with auto tranny?
  29. Question on parts
  30. 05 civic healight bulb doesnt work even after replacement
  31. 2001 Civic - Front wheel noise?
  32. Loud Rattle on Start up
  33. Honda Civic 05' Key won't turn.
  34. Hood deflector for 2005 civic, where to find online?
  35. civic em2 with rsx-s front brake problem
  36. Window Problems
  37. Is this 2002 Civic a good deal?
  38. 05 Ex Thermostat Housing Gasket
  39. trouble codes
  40. Weird sound when Shutting off my car?
  41. 02 Civic EX Coupe Transmission issue
  42. Inner Fender Plastics
  43. Tell me this isn't a headgasket...
  44. How reliable is the automatic transmission?
  45. Buying an 05 Civic, need help!
  46. 2001 Honda Civic Intermittent Starting Issues
  47. The SUPER budget build!
  48. Bad fuel mileage 02 Civic cpe EX auto
  49. 05 civic keeps pulling p0134.
  50. overflow hose keeps popping off
  51. 3 codes at once
  52. 2004 Civic - Engine issue
  53. 2002 civic ex coupe will not go over 3000 rpm
  54. ECU help...
  55. 02 and 05 part fitment?
  56. Flywheels: EXEDY / FIDANZA / BISIMOTO
  57. auto transmission issues 01 ex em2
  58. 2001 Civic EX unexplainable oil leak
  59. 2002 EX Keeps back firing
  60. Need any experience with 2003 Civic Hybrids!
  61. 02 sedan slow build
  62. 02 Civic EX - Picking up tomorrow
  63. motor sped up on it's own
  64. 2005 honda civic dx no egr valve?
  65. Blown vtec, install a base 1.7 instead?
  66. K20a swap Power Steering fitment Issue
  67. Humming sound... timing belt/tens?
  68. civic ex, car starts, then shuts down
  69. Odometer resets on its own
  70. 2002 civic, engine replacment, cranks wont fire.
  71. Parts list for 05 civic ex rear brake conversion
  72. trunk springs weak -- normal? LX 2001
  73. DX making a funny nose in idle
  74. 01 Air filter replacement help with screws!!
  75. HELP PLEASE: Intermittent flickering lights- video inside
  76. does temp spike have anything to do w/ head gasket?
  77. 01 Civic EX Wont Start... Electrical Issues I beleive... Need HELP!!!
  78. floor mats
  79. H-swaps
  80. Oil pan gasket
  81. 2002 civic ex ecu help
  82. Time Belt + Water Pump?
  83. Funky No Start: Injectors Not Firing?
  84. Will 01 Civic EX auto trans work on 03 LX?
  85. Lift Kit for 2001 Civic DX?
  86. Piston movement in block normal?
  87. How Can I Get 'Key In Ignition' Sound for UK EM2?
  88. 2002 Civic EX, Required work according to Honda dealer.
  89. Multiplex MCU Issue - no mode 2
  90. replacing a ecu
  91. Engine swap
  92. Oil leak 2004 Civic
  93. civic coupe 2001 big problem, need help
  94. price for head gasket repair?
  95. california cat converter issue
  96. 04 non vtec in an 01 LX - searched
  97. 2002 Honda Civic - Emisson Light Question
  98. 160 km/h
  99. Need an 02 EM2 EX Cat convereter. WHERE?
  100. Exhaust Manifold Gasket on Downpipe
  101. front end noise
  102. How can I make my 05 Civic EX go faster?
  103. 01-05 Honda Civic Manual Trans Noise
  104. BUY A EM2 WITH A KSWAP?
  105. So long em2 :(
  106. 2004 Civic battery draining
  107. Honda civic 2002 1.5 lt automatic engine shut down on highway
  108. 2003 Civic LX Parasitic Draw
  109. Windshield Wiper Issues
  110. Code p0118.. HELP!!!
  111. 01 civic ex. ecu reset now wont stay running.
  112. speedometer and odometer not working
  113. Question about bolt identification
  114. 2001 Civic door lock issues
  115. suggestions on alternator?
  116. Civic 2002 Radio Code PLEASE!
  117. 2002 Civic radio code please,....
  118. Anybody riding on Tokico D Specs?
  119. Buying a New Transmission 03 EX M5sp
  120. Automatic engine into a Manual car?
  121. Help:Trunk Locked
  122. 2002 Civc EX 2-dr Lowered 2 inches should I buy it?
  123. How to get Brake Booster Line off -
  124. Hose leaking
  125. Build Thread (01 EX Coupe)
  126. Help Car won't start!! Immobilzer issues?
  127. 03-05 Civic Lx, EX (Distributor)?
  128. Engine replacement: EX D17A2 to replace HX D17A6 - different camshafts?
  129. Real world cost for K swap?
  130. ignition coils
  131. 05 Lx speedo cluster fit 02 dx?
  132. Problems with my door lock?
  133. 01 Lower control arm bushings
  134. 2003 rebuilt transmission wont go into gear
  135. Pulling
  136. D17A6 header compatability?
  137. need help on obd 2 code problem on my 02 civic coupe
  138. 01 civic ex stick
  139. Ecu ?
  140. 2001 Civic Sedan Power window
  141. 2005 power window troubles
  142. 2004 Honda Civic EX Coupe with ~ 125,000 miles safe to drive on original timing belt?
  143. 2002 civic control arm bolt problem??
  144. 2005 Honda Civic DX Clutch engaging issues
  145. *Help please* found out today electrical issues arent my forte
  146. new here, hello.
  147. ecu removal
  148. Will manual transmission from 02 SIR work on an 01 EX?
  149. Engine bearing damage, anyone have this? (See video)
  150. Need help with adjusting clutch freeplay, please help :)
  151. shifter problems?
  152. 2004 civic automatic, tachometer spining in circles.
  153. Got a gremlin please help
  154. finally got it
  155. 05' Hybrid Antena R&R?
  156. BatteryInstallation Conundrum
  157. Manual Transmission Fluid Change
  158. diy oil pan gasket change
  159. "Total Loss" on Carfax?
  160. OEM Honda Coolant and Manual tranny fluid question.
  161. p01457 01 civic lx what's it mean?
  162. Power mirror conversion 2005 Civic 4dr SE
  163. ABS light always on, on my Civic 2005
  164. awkward transmission troubles
  165. One Tiny O-Ring in Head Gasket Kit?
  166. Body Kit
  167. help with cel light
  168. '03 Civic electrical fault mid-run/now wont start
  169. 2001 Civic Steering shakes when going over bumps
  170. How common are head gasket issues on these engines?
  171. resonator chamber
  172. Honda civic struggling to start
  173. type s brakes on em2
  174. TSX Seats in EM2
  175. Door Panel Removal 03 Civic Ex 2dr
  176. P0705/blinking d light despite changing transmission range switch
  177. 2004 Honda Civic Engine shutting down
  178. Cheapo radiator
  179. In the market for an '04-'05 Civic. Fair deal?
  180. Strut Noise
  181. 02 Honda Civic P0420 code
  182. Window won't roll up WTF?!?
  183. annoyed beyond annoyed with the knocking sound.
  184. Blower motor won't work
  185. 01 sedan EX Engine Lag cut out bog when cold???
  186. Good source for gaskets?
  187. Looking for Valve adjustment instructions 2003 Civic
  188. 01 civic lx with bad tranny,
  189. Quick vibration in front end and slight hesitation feeling
  190. 2004-2005 Civic CF Hood
  191. 2005 Fog Light - Minor Issue
  192. Squeaky bushing front right side?
  193. Brake pad wear issue
  194. em2 to ep3 brake swap
  195. replaced alternator but a fuse keeps blowing out can anyone help
  196. How safe is it to run an engine without coolant
  197. em2 problems pleasee help
  198. 2002 Honda Civic EX weight
  199. Heater blowing cold air >.<
  200. Just sayin' hello
  201. 02 civic lx immobilizer problem
  202. window replacement
  203. Battery light still on, new battery, new alternator plus new issues
  204. compatability questions 01 thru 05
  205. d16y8 auto tranny onto d17a1? will it work?
  206. car Shutting off randomly
  207. Bad brake booster?
  208. Help cleaning engine compartment - 2003 Honda Civic LX
  209. HO2S S1 Heater failure
  210. Short throw shifter
  211. '03 Honda Civic Camshaft Position Censer
  212. Build question
  213. 2001 Honda Civic - Stalls after 30 seconds
  214. replacement seats
  215. 2001 civic ex transmission issues
  216. bypass the anti theft is there anyway
  217. A few questions after transmission rebuild
  218. Tranny Swap on 02 Civic
  219. cat hanging low
  220. 03 civic ex
  221. Help Code P0335 after timing belt change
  222. Help: identified this light on speedometer
  223. Door panel speakers
  224. Total power loss on freeway - 2003 Civic EX
  225. 2001 Civic (Acura EL) manual transmission problems
  226. 02 Honda Civic P0420 code
  227. Any ideas?
  228. Em2 k20
  229. Help with legit O2 sensor x-ref parts? Will it work?
  230. D17A1 vs D17A7 in a GX & power issues...
  231. Manual Transmission Trouble
  232. Help me ID this part?
  233. EM2 BROKE DOWN AGAIN IM ??? WAT IT COULD BE
  234. Civic trans
  235. 03 civic LX is burning lot of oil
  236. is there a difference between coupes and sedans on ride height?
  237. what do i have to put on my engine to put a intercooler
  238. 100,000 miles just came around.... what is needed?
  239. 2001 Civic sounds like a Helicoptor during acceleration
  240. Driver side door locks- 01 Civic
  241. 02 civic coupe keyless entry problems...
  242. Honda civic 2003 ex wont start
  243. Honda Civic 2003 gauges not working
  244. 2003 honda civic ex cold air intake
  245. HELP - REMOVE REAR SEAT - DASH AS WELL
  246. Air bag q's
  247. Thumping coming from under driver side
  248. 2002 honda civic 5 sp manual
  249. Scrapping Sound from front wheel
  250. 2001 Civic Sedan Rear Speaker Replacement
