PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65
  1. group buy for exhaust
  2. how much do 2000 SI wheels weigh?
  3. I need ur help please.
  4. ecu swap question
  5. SRS airbag light always ON
  6. tien s-tech springs for my es1
  7. K20A3 WITH K20A2 CAMS NEED HELP!
  8. Tranmission problem? Studders from 1st to 2nd
  9. does the civic ex really accelerate this quickly?
  10. Ksport Coilovers installed PICS !!!
  11. just curoius...
  12. my new car.
  13. Anyone ever heard of Azul wheels?
  14. what's best with eibach sportlines...
  15. JDM DC5 rear sway bar - 22mm - fit fine on a 04 sedan?
  16. need help on replacing my suspension. opinions please.
  17. brake problems
  18. 2003 civic DBW?
  19. Cant load cd's on Special edition radio
  20. Radio "BUSY" when loading cd
  21. 01 Civic Transmission Problems - is that common?
  22. Where to buy Veloz Sideskirts?
  23. My Build Thread
  24. Brown Interior To Black Interior
  25. will this sway bar fit our cars?
  26. New car: general maintanence questions???
  27. I think I just made a bad decision
  28. NEEDED: OEM JDM passenger side kick panel
  29. head lights
  30. Problems in Brandon
  31. Squeaky Driver Seat
  32. new problem with clutch
  33. vantage+toyomatt=...
  34. what to do first
  35. what products to buy to lower a '03 civic sedan?
  36. Just getting started
  37. MSD in my 03 Civic?
  38. Euro Tail light
  39. Radio error "3errE"
  40. how to change a shift knob
  41. Reliable and cheap place to buy a K24A4?
  42. My Build Thread
  43. 02 EX... convert rear drums to disk.
  44. Radio error
  45. oem vs csf radiator
  46. Nitrous ?
  47. Anyone know the specs on this drop?
  48. cluster
  49. i'm getting ready to change my pads
  50. check out my k20 swap
  51. 2001 Honda Civic Headlight Problem
  52. Civic Si 2002 - 2005, Civic CTR EP3
  53. My seat is broke
  54. Noise from Suspension
  55. Best place to buy Honda Parts (Brembo rotors/ceramic pads/Steel braided lines) online?
  56. has anyone tried that "detailed d17 build for 305 whp" FAQ
  57. My Build Thread
  58. Nex Coilovers Quality or Crap?
  59. Need help on resetting srs light
  60. sooo, who have you raced lately
  61. Any other good EM2 boards?
  62. Repair Manuals????
  63. Pics and vids of my 1 of a kind EM2
  64. \civic hubcaps fit 14in or 15in steelies?
  65. Civic Wanted for SoCal Photoshoot
  66. h22 in 01-05 civic?.
  67. turbo question?.
  68. auto vs manual in the em2
  69. Lame headlight question
  70. b-series swap in 02 civic??
  71. good everyday tires
  72. HID
  73. 05 ex engine noise
  74. fill in the blanks (idiot lights)
  75. EM2 with swap and EP3 in the 1/4 mile
  76. em2....
  77. I have a very important question
  78. My Build Thread
  79. sparco shift knob
  80. this sucks
  81. FINALLY!
  82. How to remove rear drums?
  83. handbrake question
  84. what all possibly could go wrong in a 5 mph crash
  85. mufflers that dont sound like rice
  86. Looking at 1995 HONDA CIVIC EX (V-TECH)
  87. good low boost blow off valve
  88. Picking up my first EM2 tomorrow.
  89. whats a good tire size to upgrade to?
  90. Where is the horn located?
  91. quick question
  92. -Lip fitment question?
  93. Engine Front Mount Cracked
  94. squeeking after rotor/brake pad replacement
  95. is it me or are my headlights very dim?
  96. part question.
  97. 2005 HX wiring question
  98. My Build Thread
  99. 01-02 cluster in 05 civic
  100. Alarm 4040a karr system???????
  101. retrive?
  102. tuneup help!
  103. how to pull out 2003 civic 2 dr stock radio..HELP!!
  104. radio not working on my 2005 civic si
  105. over heating problem
  106. throttlebody positioning sensor
  107. Take a look at my Knob
  108. Help this guy out
  109. clutch went out
  110. 2002 honda civic si door lock problem
  111. amazing stunt!! civic driver survives after dropping from great wall of china!
  112. Removal of shift knob
  113. brake pads and rotors...were these a good choice?
  114. baseball card in bicycle spoke sound when accelerating?
  115. Unexpected error
  116. Ksports just came in
  117. Safe lowering level
  118. neuspeed strut bar
  119. loose steering...how is this adjusted?
  120. Did honda change the suspension in 05?
  121. It's a boy!!!!!
  122. Coilovers
  123. lowering spring suggestions
  124. I need a CARFAX for this car please
  125. D17a frankenstein swap?
  126. 01 Civic EX secondary O2 sensor rewire PLEASE HELP!!!!!
  127. KYB struts?
  128. anyone have trouble finding a cd player kit for the spec edition ex?
  129. shop manual???
  130. What Kind Of ECU???
  131. Guide To Remove OEM Radio?
  132. Strut Bars
  133. My Build Thread
  134. omg. im an idiot.
  135. How many inches deep is the trunk?
  136. I need Just the Break Caliper. Where to Buy?
  137. quick question on saftey airbags
  138. Oem Stereo Question
  139. 5 lug swap
  140. Lowering Kits for ES Civic's
  141. - Header question?
  142. k20 or bust.
  143. different lip kits...
  144. Stereo install..
  145. vacum line?
  146. Found this clip, funny as hell I thought I share
  147. 2001 transmission fluid
  148. Anyone running on 215/40R18 ? What offset? Any rubbing?
  149. Suspension of the 03-05 hybrids?
  150. OT: SLK 55 AMG test drive.
  151. 01 sedan FOG LIGHT INSTALL
  152. What do you guys do (about Oil changing)?
  153. em2's, are they stolen very much...
  154. mass air flow sensor
  155. Need some info on 2001 Civic
  156. 16x7 40 offset
  157. need help with ep3 seats
  158. need help please!!!
  159. Dezod Suspension packages?
  160. dynomax exhaust
  161. '04 Civic Hybrid pavement noise reduction?
  162. What else should i do?
  163. Radio Code
  164. problem with em2
  165. pic request!!!
  166. HELP EM2 wont start!
  167. Replacing the cabin filter (or A/C fileter)
  168. dc5 recaros... will they fit?
  169. ebay springs?
  170. k20 swap wiring
  171. what intake should i get for my 2005 civic si
  172. New VIS cf trunk
  173. Shocks and Struts, What brand/kind for a Commuter?
  174. I just got a TSB bulletin
  175. 04 Honda Civic EX
  176. civic 2005 starting problems
  177. Maintenance Required Light
  178. noise while turning
  179. Tranny Noise!
  180. What springs do you guys think?
  181. tach install for 04 dx
  182. Hellow and online retailer suggestion
  183. someone please run my 1&6 radio code.....
  184. What do you think of my em2?
  185. Budget K Swap?
  186. shifter question
  187. option racing intake
  188. 18 inch brand new tres for CHeap!!!!
  189. 1992 JDM H22 Motor Question
  190. k20 swap 2001
  191. center console
  192. what did you get?
  193. Progress Suspension!!!
  194. Merry Xmas all
  195. possible to put dc5 front end on em2?
  196. anyone else having transmision problems in their '02 civic
  197. aem v2 cai from 92-00 civics fit on 05 model
  198. I wrecked
  199. em2 badge
  200. newb question
  201. 05 Accord headlights dim for split second
  202. can it be done??
  203. Returnless fuel system
  204. Just Lookin for opinions.
  205. 01 Civic won't start in cold weather
  206. honda civic radio code err3
  207. Whats the yellowish glue use on the inside of the door panels?
  208. EM noob questions - i.e suspension, interior, interchangeable parts from other honda?
  209. Model identity crisis
  210. ABS Squealing, ABS light is on.
  211. Low beam lights don't work!
  212. DRL repair walkthrough
  213. 2003 civic ecu ?
  214. EP3 K-SPORT COILOVERS
  215. leak by drivers seat
  216. Engine cuts out
  217. megan front upper strut bar
  218. Gas Gauge
  219. help with sun roof
  220. Finally, I might get my rear sway kit...
  221. What engine oil for...
  222. Fender Well Question ('04 DX)
  223. Acura 1.7 EL BLACK LEATHERS
  224. heater core.
  225. how do I reset Maint Req'd light - new member
  226. Spoiler ?
  227. 2001 Civic Running Over Deer
  228. Lip and Body Kits
  229. My EM2 Tell Me what you think
  230. ANSWER ASAP Blown Shock?
  231. Just got an 2002 Civic, Newbee Parts Question
  232. Need Service Manual for Civic
  233. hr springs help 2002 civic 4dr
  234. airbag question
  235. What kinda exhuast do you have on?
  236. How do you remove the interior door panel?
  237. Rsx type-s front sway bar/Progress rear sway bar
  238. Power locks question..
  239. trying to sell car
  240. New Honda owner!
  241. RSX Cluster In '04 Civic
  242. Color Coordination
  243. k20/24???
  244. for those ppl.....
  245. windshield fluid light help!
  246. Headers Help...URGENT
  247. How friendly is K20 swap into your chasis?
  248. Problem, heater blower just quit
  249. 2001 civic headlight adjustment
  250. Got an LSD for my D17
