PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. 02 Civic D17A1 intake/header swap options?
  2. Looking at a 2004 Civic
  3. 02 acura 1.7el gear shift remove
  4. MT difficult to shift
  5. Idle goes up and down!
  6. How to check/test rear ABS sensor
  7. 2001 honda civic lx
  8. 02 Civic Strut Bar Options/Questions
  9. Question on replacing a trunk lid with factory spoiler
  10. Issue with shift boot
  11. Brake Trouble Light Stays On
  12. Front Oxygen sensor or Honda Civic 2005 hybrid (cheap)
  13. 04 Civic Coupe Gas Gauge Reading to High.
  14. Odd Transmission Behavior 01 Civic AT 207k Miles
  15. 2001 Honda Civic LX Misfire Question
  16. Wondering about a couple sounds, bad input shaft bearing?
  17. Hey everyone! New member here, q's about 04 Civic
  18. Where can i find these?!
  19. 2004 Honda civic ex water on drivers floor
  20. Hard race bushing
  21. Alternative Head rest for my em2?
  22. 2002 Civic EX A/C pressures
  23. 2002 Civic EX immobilizer issue (NOT USUAL ISSUES)
  24. Broke the head off of ECT sensor
  25. Car loses power only on the highway drives of 20 miles +
  26. Thinking about buying a 2005 Civic Hybrid
  27. Ride height question
  28. em2 speedometer inop
  29. Grinding noise when accelerating, very bad now
  30. P0135 after engine swap
  31. Engine dies as soon as you put it in drive
  32. Fuel Gauge
  33. Motor and Transmission Mounts?
  34. 2004 Civic EX Clunk
  35. 04 civic dx coupe swap
  36. Civic throttle question?
  37. EM2 Neuspeed front strut bar review
  38. Car floode
  39. Intake question
  40. Closed.
  41. Clutch issue.
  42. Do I have the right ecu?
  43. Error Code PO420 2003 Civic EX
  44. 03 Civic EX Help
  45. Converting manual to power locks and windows.
  46. D17a1 to d17a2 swap vtec engagement question
  47. Civic EX 2001 Keyless entry unit issue
  48. Loose Alternator Bolt and Resulting Issues
  49. 02 Civic LX Tranny died - swap or rebuild?
  50. Car makes constant sqeaking sound
  51. 03 Civic Evap Leak Detected p1457
  52. Transmission disengaging...
  53. 2002 civic ex loss of power at slow speeds
  54. D17A w/ auto trans. Need help
  55. Wiring turn signal mirrors 7th Gen civic
  56. Yet another ECU question
  57. 3200rpm limit after head gasket replacement
  58. Major valve problems!!
  59. 05-06 rsx type s neuspeed strut bar on em2?
  60. 01 Civic nonv to vtec wiring issue
  61. 03 civic lx auto trans swap
  62. Advice on 2003 civic
  63. Auto Clustor on a Manual Car
  64. Which engine will fit 04 Civic 1.7 non VTEC?
  65. Conrod and Pistons
  66. Transmission Rebuild Cost
  67. 2004 honda civic dx won't start up
  68. 20001 Civic EX - Flashing dash lights / turn signals - won't start
  69. 03 LX, replacing stock D17A1 with stock D17A1 - out the bottom?
  70. 2001 Civic AC Questions
  71. Honda Civic 2003 LX - A/C Fan not working
  72. 2003 Civic EX Manual Transmission rubbing /grinding noise.
  73. Car wont move
  74. 2001 5spd tranny issues...
  75. 2005 civic issues with no power
  76. Overheating problems
  77. '05 Civic died at when i pulled from the driveway
  78. Replacing cam sensor, rusted bolt...any tips?
  79. Starts then dies. HELP!!!
  80. My Official ES2 Build
  81. Help With 03 Civic Project Car
  82. Disassemble fuel injector connector
  83. Transmission Fluid change "will ruin tranny?" & Other Questions
  84. Metal to metal sound when turning left
  85. 2004 Honda Civic LX, questions on catalytic converter
  86. Planning turbo build. What swap to go with?
  87. 5 Lug Conversion (Yes I saw the FAQ but its closed)
  88. No horn or Cruise - 04 Honda civic
  89. Speedometer stays at 0 mph-2004 Civic LX
  90. 01 Civic EX P1457
  91. DIY 04-05 civic Black Housing Headlights
  92. 2002 Civic EX Codes P1298 & P1457
  93. 01 transmission ground
  94. D17A1 to D17A2 swap
  95. Headlight problems
  96. need help fast to resolve this missing part.
  97. Help! Replaced Alternator, Car won't start.
  98. Which model has the 22mm front sway bar?
  99. 2002 Civic alt/battery?
  100. 2003 Honda outside air even on recirculate
  101. 01 civic Boggs down at 4,000 RPMs.
  102. 03 civic ex misfire
  103. Aircon swith and knob lights abnormal behaviour
  104. Intermittent weird engine noise
  105. 2004 Civic - Water Pump & Bushings
  106. Metal clicking/tapping - front passenger side.
  107. 2003 civic hybrid
  108. 04 civic vp keyless entry install
  109. 03 civic head gasket i nfo needed
  110. 2003 Civic Air Conditioner problem
  111. Metal grinding sound in front.
  112. SI Conversión of my 2002 coupe honda civic
  113. 01 Civic Auto Tranny Problem
  114. 2001 civic 1.7 vtec p1298 p302 p304 p1491
  115. Weird Noise
  116. MCU problems
  117. Turn Signals not working
  118. K20a motor imported from Japan
  119. 2001 civic engine shuts off while driving
  120. k20 swap!
  121. Is this a burnt plastic bag? Picture attached
  122. Looking to buy ignition wires
  123. 2005 Civic EX wont rev past 4k RPM
  124. d17a1 to d17a2
  125. takata air bag recall. Now what
  126. 03 Civic EX general questions
  127. Jerking and sometimes stalling when come to stop??
  128. Old civic differential on 2001 civic
  129. strut going bad or even more
  130. Factory Anti-Theft Intermittent Alarm Issue
  131. Limp mode 4k rev
  132. 2002 EX Civic
  133. 01 civic
  134. 03' Civic DX - Ignition cylinder not turning
  135. 2001 lx 1.7 automatic
  136. Cluster smoked after wiring wrong wires
  137. Misfires
  138. Honda Civic no start
  139. Wheel hub still good to use?
  140. 2003 Honda Civic Si stalling
  141. 02' coolant problems
  142. 2002 Civic - Rear door has no electricity
  143. compressor only seems to run when cold out
  144. Funky Ride Height??
  145. Transmission Slipping in Park
  146. Boosting an em2
  147. Crunch noise when braking or turning
  148. How long does it takes to change timing belt & head gasket
  149. 2003 Civic Headlight Wiring Issues
  150. 2003 Honda Civic Hybrid MPG drop
  151. 04 civic, strange sound after oil change
  152. 2002 Ex died under acceleration, won't restart now
  153. 2001 civic ex "randomly" stalling
  154. Help Identifying A Plug!!
  155. Where can I buy a short block?
  156. Radiator and AC condenser fans not working.
  157. Engine bogging
  158. A/C not working even after some test
  159. Better than OEM shocks/struts? But fit like oem.
  160. 2005 Civic Starts, then stalls
  161. 2002 Honda Civic Battery Light/Blown ECU
  162. 02 civic Vtec Problem
  163. 2005 Honda Civic (Fold Down Rear Seats)
  164. 2001 automatic sluggish 1st gear??
  165. screeching/grinding noise when i attempt to start my car
  166. 2001 Honda Civic Engine Noise
  167. Manual to automatic conversion
  168. overheating losing coolant but no leaks.....
  169. Possible Clogged Cat...
  170. 01 Civic EX Issues
  171. SRS Replaced- Now Won't Start
  172. Looking for a OEM throw out bearing
  173. Please help! Rough idle...
  174. 2004 Honda Civic - No Start after Timing Job - HELP
  175. Intermittent dash lights, etc
  176. temp gauge goes up at idle
  177. Where to find bumper cover clips and screws?
  178. 2001 Honda Civic Cooling System Problem
  179. Replacing gauge clustor taken from an automatic car to a manual
  180. 2002 Honda civic
  181. 01 LX - vibrating in reverse - how to repair?
  182. Compression Loss After HG Replacement
  183. do i need a new engine??
  184. need help finishing installing my gauge(s) ( 2005 civic ex se )
  185. help with battery cable
  186. 01 Civic LX no start
  187. Recharged ac low side pressure zero
  188. 2001 civic temperature sensors
  189. 2002 Honda civic all windows have plastic coating on inside
  190. Slave Cylinder Civic 01
  191. 2001 Civic LX strange overheating/ loss of power
  192. New PCM. Same problems.
  193. Anyone know what wheels these are?
  194. radio code for 2004 civic
  195. CEL Dilemma
  196. Motor Mounts Questions
  197. Sheared alternator bolt,, CEL,, limp mode?
  198. Windshield Wiper Problem
  199. 2002 EX auto. RPM drop, stall, limp home mode. Video included
  200. wheels and tires
  201. Overheats and Sprays Water
  202. Tapping noise when in 1st-3rd gears
  203. Replacing voltage regulator in a 2001 Civic alternator
  204. 2003 Civic Oil leak
  205. front suspension
  206. Power steering stops working above idle
  207. Won't start. Replaced a sensor, battery. Mechanic says to replace another sensor.
  208. 02 civic ex 215k CEL P0303 cylinder 3 misfire
  209. 05 Hybrid New Radiator Still Overheats
  210. Green key light flashes AFTER I turn the ignition off
  211. Using a lot of oil
  212. 2001 civic ex won't stay in any gear
  213. 2002 Honda Civic with JDM SLXA auto tranny swap
  214. Low Idle and Misfire
  215. Hot weather=Limp Mode!! HELP!!
  216. FS/WTB Thread
  217. WTB FRONT STRUTS.
  218. Help with P0133 OBD Code
  219. Civic '01 sounds like diesel truck
  220. Why won't my car start? Plz help!!
  221. 02 Honda Civic Coupe/ Key won't turn in the ignition unless I try 10+ times.
  222. Should I go for the Civic?
  223. Eibach and h&r spring rates?
  224. '02 Civic Loses Power/Shuts off
  225. Tcc
  226. 2001 4DR Parts Wanted
  227. 2002 Civic DX Radiator/Coolant??
  228. 2002 Civic EX Parking lights won't turn off
  229. Changing rod bearings with the engine still in the vehicle - 2001 Civic HX
  230. 02 civic dx need advice/help.. lowering springs/struts/shocks
  231. CV Axle. Reman. Or stick to OE
  232. Can anyone identify this engine noise?
  233. Proper Fluid fill ?
  234. No power!
  235. Seat belt stuck
  236. Immobilizer issues.
  237. 05 Civic EX SE preventng the same thing to happen again ..
  238. needing console photo(s) of an 05 civic ex
  239. 2003 Honda Civic Crake / No Start
  240. chasing a D17A1 oil leak
  241. What is the difference 01 tranny Swap?
  242. Can the 1362/1361 codes be "wrong"?
  243. Replaced brakes, now heat + smoke
  244. 2001 Civic EX Tranny Problem?
  245. tensioner spring
  246. torque up my '01 civic ex
  247. Difficult diagnosis - overheating/misfiring but I don't think it's the head gasket
  248. 03 ex troubleshoot
  249. 2001 Honda Civic EX oil in antifreeze container
  250. Compression testing with 2x spark plugs?
