Soaking wet passenger floor
I have a 2003 civic LX with 80,000 miles and the passenger floor is soaking wet, it’s water not coolant. When I google it some people say it’s the a/c drain hose but I cannot find the hose in my car. Has anyone had this issue or can give me some advice? The a/c blows cold air and the heat works perfect.
Re: Soaking wet passenger floor
If you can't find the hose then you've found your problem. On the 2003 it's still at the passenger's feet but it will be under a cover if your car still has it. I believe it comes off with some push tabs, then you pull it out. At the very back and bottom of the evaporator housing you'll at least see a fitting where a hose hooks onto. It's supposed to go through the firewall and down to drain.
If it's still there, it's likely clogged. If it's gone, go to a junkyard and find one or put some generic hose on it.
