PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. axle snapped?
  2. Slowwww Honda Civic
  3. Cruise control button
  4. BMXA trans rebuild
  5. I need a 2002 Civic Coupe trunk cover
  6. Parts for test stand run
  7. Coolant leak
  8. 2002 Civic LX Coupe automatic transmission question(s)
  9. Engine rumbles and dies - 02 Civic DK
  10. O2 Sensor removal tool
  11. Loss of (engine)power.
  12. Difference in speedos?
  13. Honda Civic 2002 DX need help
  14. 2002 honda Civic with P1457 and P0137
  15. 01 em2 idle issue
  16. --EDIT--
  17. 2003 Honda civic 5 speed transmission problem
  18. EM2 vs RSX oem shifter difference?
  19. New Alternator not Charging New battery!
  20. red emblem clarification!
  21. coolant flush issue...!!!
  22. p0131 problem *fixed*
  23. Low Idle
  24. Coolant flush
  25. 04 Civic Air Conditioning Problem
  26. 2003 civic ex coupe. 25 or 15mm front sway bar?
  27. engine tech parts, any good?
  28. Honda Civic standard locking wheel nuts?
  29. 04 Civic Inner Fender Shields
  30. Replaced O2 sensors and now p0420
  31. strange idle.....
  32. Non standard "Maintenenace" at 217K miles?
  33. Front Clunk - When turning over bump
  34. Stick with OE Ball Joints?
  35. 2001 Honda Civic Dx ECM
  36. 01 Civic Limp Mode Issue
  37. help with headlight unit
  38. 2001 civic transmission jerk
  39. Low idle when hot
  40. Question about adding OEM Nav system
  41. A/T shift solenoid removal
  42. can i use stock valve retainers on supertech springs?
  43. Chassis code??? not sure
  44. Should I be buying this used and is it a good price????
  45. Fenders Won't Roll. Help/Advice?
  46. Car is bogged down. Getting worse
  47. crank no start
  48. Can anyone tell me what this is???
  49. Shifter Boot
  50. O2 sensor installation
  51. Cable Shifter Bushing, Help!
  52. 2002 Honda Civic EX won't start
  53. cold start problem..........!!!!!
  54. 2001 civic lx 4-door went to punch gas and everything kind of died.
  55. Brief Squeal when AC is turned ON
  56. No Start - Stalls during idle
  57. How to properly jack up a Civic?
  58. 2002 Civic dx wont stay running
  59. 02 Civic replaced ECU lost power!
  60. head gasket
  61. Troubleshooting P0171 Code...
  62. Need help
  63. 2002 honda civic ex
  64. Clutch engagement issue when hot
  65. Oil Burning, PCV Valve?
  66. Need Help Replacing O2 Sensor Bank 1
  67. Where to Buy Indicator Light Bulbs?
  68. fuel pump relay question
  69. 2002 Civic Front Hazards/Turn Signals not working
  70. Process to change and flush MTF correct?
  71. Acura 1.7EL (Honda Civic) D17A2 - very weird intermitent problem and no CEL
  72. noise coming from a/c compressor
  73. Camshaft Position Sensor Question
  74. Help! Revo Shifter Assembly V3
  75. 2002 Civic EX driver door lock problem
  76. 2001 civic lx problems
  77. 01 Civic EX Front Brake Retaining Clip?
  78. How Much Boost Can A Stock D17a2 Take
  79. Dashboard Lights and Cruise Control
  80. I changed the CMP sensor it was fine now it won't start.
  81. 2002 Civic, weird idle issues possibly related to a/c
  82. d17 manual transmission compatibility
  83. 04 civic won't turn over
  84. Trunk Vent Issue....
  85. 2001 Honda Civic Ex Oil Pan
  86. Camber Kit for 03 Civic Coupe
  87. 5 lug conversion 2005 Civic
  88. 2003 Civic LX - Dead Motor Due To Timing Belt
  89. Front brakes lock too easily
  90. Backup lamp fuse short
  91. sputters when cold for 15 seconds
  92. Need Help 2002 Honda civic 1.7l Coupe
  93. Ac problems
  94. 2001 Civic Dx just randomly turned off
  95. transmission help asap!!!!!!! plzzzzz
  96. aftermarket air intake
  97. Civic / Acura el subframe
  98. 2003 Civic LX A/C Does not work, System appears Overcharged?
  99. missfiring
  100. 02 Civic EX bucking
  101. Will 05 coupe Rear bumper cover fit on a 03 coupe?
  102. 02 Civic EX Sudden Loss of Power/MIL
  103. Transmission problems
  104. Power steering sometimes hard when turning
  105. Help Passing Smog Check
  106. Civic 04 Throttle interruptions
  107. How to Replace Fender?
  108. All frontal light wiring
  109. Temperature guage problem
  110. 2003 Civic limp mode
  111. aftermarket fog light switch
  112. 2001 Honda Civic 4D Sedan EX 5-speed
  113. 01 Canadian DX Auto - 01 EX Trans install Questions.
  114. Good Lowering springs for 02 2dr civic?
  115. No heat at Idle - Civic EX 2004
  116. Oil pressure switch necessary on non-VTEC?
  117. 04 Civic No Heat at Idle
  118. 2004 honda civic coupe instrument cluster swap
  119. new car
  120. 2003 Civic gauge cluster issue
  121. SRS Control Module
  122. Programming Autolocks on Civic '04
  123. 04 05 acura el rear trunk & tails conversion
  124. 03 Ex Civic fog light dont turn on
  125. 2002 Civic LX Cylinder 1 & 3 misfire
  126. AC problems. 2001 Civic EX 5 speed manual
  127. Disable alarm going off when unlocking with key? (Civic 2001)
  128. 05 Dx Vp Possible Limp Mode?
  129. 2002 civic engine swap d17
  130. Replacing stock rearview mirror with an autodimming aftermarket mirror?
  131. Not sure what's going on.
  132. Mugen sport pedal (#46545-XG5-K2S0) compatible with EM2?
  133. Valve Cover Leak?
  134. 2001 Honda Civic how do I bypass the vtec
  135. Starter for 01 Civic Ex MT?
  136. HELP! Wheel and tire set up
  137. SLW 5speed manual trans
  138. Blown head gasket on 2003 honda civic
  139. spark delivery
  140. Squealing belt under acceleration
  141. Automatic Trans Wiring Harness Applied to Manual Trans?
  142. 04 civic stuck on vent
  143. Parasitic draw on fuse #9 & Center Console not working
  144. Fuel pressure issue
  145. Best after market headlights
  146. Shift/ linear solenoid
  147. Hi all, Newbie here?
  148. EM2 [my bad. i didnt read the FAQ]
  149. p0740 HELP
  150. Electical Issues / Headlights and interior light pulsating
  151. 04' civic auto shift problems
  152. Is my car worth the trouble?
  153. need to change catalytic convertor - advice needed
  154. Stay away from GMB Tensioners!!
  155. To part out or not to part out.. that is the question
  156. Quick Crimping Question
  157. 03 civic AC blower not working
  158. 2004 honda civic lx stalls at a stop light
  159. Big 3 01 Civic EX Manual?
  160. Maint. Light turn off
  161. Engine Temp Needle fell off
  162. Alternate replacement motors?
  163. Simple dumb header question
  164. 05 Civic motor knock coming from valve cover.
  165. Alternator bolt
  166. 2002 Honda Civic Ex 1.7L 4-Door Electrical Issues
  167. 2002 Civic GX Transmission Behavior
  168. 01 Civic EX MT Hesitate Starting
  169. 2002 LX ECU Troubleshoot
  170. Malfunctioning Headlights and High Beams
  171. Headlight problem
  172. Rear lip and spoiler
  173. Merchant might have stripped my oil plug
  174. 2001 Honda Civic DX P0420 P0131 P0132
  175. Exaust?
  176. Using a ton of oil! Help!!
  177. My em2 isnt getting power
  178. 2005 Civic Hybrid won't crank after radio install
  179. 02 Civic HORN WORKS BUT NOTHING ELSE
  180. Where is Odometer Data stored?
  181. 2001 Civic idles rough
  182. 2001 Civic starting problem
  183. Replaced alternator and battery still dies
  184. 2002 D17A1 Manual Transmission Bad Bearing .. What Bearing?
  185. EM2 build
  186. Honda Civic Coupe 2002 - Fuel Filter Location
  187. SWAP D17A DX FOR D17A2 V-Tech EX
  188. Installed used engine has potential Detonation problem within warranty, NOW WHAT?
  189. Timing belt service soon, question about tensioner
  190. 02 civic, cranks but no start
  191. Easiest Brighter Headlights Civic 01?
  192. 2004 LX. airbags went off. Some help please.
  193. Heat only works on full hot or full cold
  194. Does any have a list of a k20a2 engine piece by piece? Want to start from scratch
  195. Can any k20a2 engine 02, 03, 04, or 05 fit in 2001 Honda civic lx?
  196. 02 civic sputtering/stalled at light but drives normally otherwise
  197. ****Tires noise or wheel bearing (with video)*********
  198. Evo 6 seats
  199. 2005 Hybrid won't release key - Help
  200. where to apply hondabond on valve cover gasket
  201. 2001 civic lx won't start
  202. Civic coupe uk member
  203. Can't program Civic with Remote Fob
  204. 04 Civic VP 5 speed to HX Trans
  205. Head lights electrical problem
  206. 2004 Honda Civic Throwing P0135 Engine Code
  207. Melted the sparkplug into the head
  208. Can I use the steel pan for my aluminum VTEC pan?
  209. Strange sloshing noise from hood/under dash '03 Civic LX Sedan
  210. d17a2 valve cover same as d17a1?
  211. Question about an oil leak on 2002 Civic Coupe Ex 125K
  212. Car Suspension?
  213. Clutch slippage - how long have i got?
  214. Skunk2 Coilover sleeve question
  215. Can't pry off the Breather Box
  216. DRL Light On
  217. 2005 ex civic cluster (no tach) to 05 civic cluster (with tach)
  218. Auto Transmission swap for 2005 Civic Coupe
  219. 2001 Civic HX MT weird noise coming from the transmission?
  220. 2003 Civic 1.7 fuel pressure
  221. 2002 Honda Civic EX Problem
  222. 2004 Honda Civic Driver Door Lock Not Turning w/ Key
  223. 2001 Honda Civic 4dr AT LX (obvious transmission problem)
  224. Need help! (crankshaft position sensor)
  225. 2003 civic multiple misfire w/no power
  226. d17a1 to d17a2 swap
  227. cylinder 4 misfire
  228. 2003 civic EX AT cluster in 2004 Civic LX
  229. engine knocking, plz help
  230. Throw out bearing or main shaft input bearing?
  231. 2003 Civic sport oil leak and SRS light problem
  232. 05 civic with rocking passenger seat?
  233. rod bearing selection help
  234. 2001 civic ex brake problems
  235. 05 civic ex - hazards and blinkers don't work
  236. driver side front axle
  237. How to disconnect fuel line
  238. Timing belt
  239. Possible ignition problem, or slipping (new) clutch
  240. Honda Civic 4 door door LX 2002 Cluster Question.
  241. Manual with photos for Swapping honda engine for same honda engine
  242. check engine light after changing fuel pump relay
  243. MECHANIC HELP? CODE p1298, p1129, p0505
  244. Part number cross reference
  245. Honda Civic 2005 SE Light Bulb
  246. Looking for Tein S-Tech or similar Lower Spring
  247. Need help!! Can I borrow a airbox for smog?
  248. 2002 Honda Civic EX Belt Question
  249. Please help to identify the OIL LEAK
  250. Push button start and kill switch
