PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Bumper / paint problems
  2. fuel pump relay?
  3. D17 manual tensioner, wtf? How does it tension?
  4. whats the name of these rims
  5. How to take out one of the bolt from control arm
  6. How to tell if front control arm is bad?
  7. 02 Honda civic Brake fade
  8. Honda Civic 2002 LX driver side door issues: keyless entry and window
  9. Keyless Entry Module Location
  10. Trunk replacement for 02 civic lx
  11. 2005 Civic died and wont start
  12. I need torque specs
  13. Just picked up....
  14. Car died after getting gas & puddle last night
  15. Does anyone think this is legit...coilovers for 130$??? help me out
  16. D16Z6
  17. how to do 05 front end conversion on an 01 civic???
  18. Avg top speed?
  19. serious overheating
  20. ep3 gauge cluster to 2004 civic
  21. project headlight question
  22. What is this suspension noise?
  23. Air intake...
  24. White smoke coming out of my exhaust
  25. em2
  26. ebay header and downpipe gasket
  27. Do D17 valves tick on acceleration?
  28. Engine ticking, Help me diagnose...
  29. Black Seat Belts for ES1
  30. wtf is this
  31. Am I being paranoid or this is normal!
  32. OBD2 Codes P1420 and P0134
  33. Serpentine Belt replacement
  34. Honda Meet
  35. Front suspension question
  36. What are these OEM Rims called? Anyone selling a set with tires?
  37. Anyone know how to remove the crankshaft and camshaft oil seals?
  38. what type of headers comes on the civic d17a2
  39. There she blows (headgasket failure x2)
  40. Need Help Removing My Head
  41. 02 civic unstable/unsafe to drive at 40+mph?
  42. Civic EM2 Trunk/Gas key latch
  43. potential part out questions
  44. 2001 Honda Civic Engine shake..
  45. D17a2 TURBO BUILD. HELP!!!
  46. ***Need MAJOR help on GFs civic. Car is going crazy
  47. 01-05 gauges help
  48. A/C help
  49. Short Shifter?
  50. power window on the passenger side is not working!!!
  51. 04 honda civic temp hand rises to (H) at slow speeds and driving long distance
  52. What is the weight distribution spec of an EM2?
  53. Help! car running rough and stalling.
  54. k20a2 swap - civic si 2DR 2001 ?
  55. Pic Request: Any ES1's (civic sedans) sitting on GSR Blades or Honda Fit Rims?
  56. noise at 2800 rpm on 03 civic ex 2door
  57. Wiring New Tach, Need Help, Extra Wires
  58. need some feedback on plans (new)
  59. EM2 Repair Manual?
  60. Oil pan help
  61. Only runs on low fuel pressure
  62. 2002 Civic Automatic Trans Questions
  63. 04 ex tranny swap help
  64. help sourcing parts!
  65. 2005 Honda Civic Overheats
  66. offset question
  67. Replacing lugs
  68. losing power
  69. trying to help out a friend...
  70. spark sound PROBLEM
  71. Trunk Lever stuck.
  72. what exactly is this part?
  73. EM2 Headlights
  74. Help looking for parts for 05 coupe.
  75. Compressor not turning on plz help?
  76. engine does not start easily on 1/4 tank of gas
  77. Timing Belt Kit
  78. RAZO / BROADWAY rear view mirros
  79. CIVIC 2001 gauge problems. Odometer 888888 needles just died
  80. Turn signals don't blink! HELP!
  81. Cant fix overheating problem
  82. 2001 Honda Civic Overheating Issue...
  83. 01 civic sedan DIY window regulator please...
  84. Driver's door lock problem
  85. 2001 Civic Horn Not Working
  86. Water In Cabin - Passenger Side
  87. way to test radiator fan?
  88. help fing car theives.
  89. Need some info on Honda Civic 1.7lx
  90. 01 02 03 04 05 HONDA CIVIC COILOVER SPRING BLUE 2/4 DR
  91. turn signals not working
  92. d17a1 turbocharged
  93. Shaky Start-up?
  94. misifre when cold??
  95. Replacing alternator, need help..
  96. dr 11's? wheels suggestions?
  97. Honda Civic 03 Drive Light Blinking + Transmission Range Switch
  98. $254.00 Oil Pan?!
  99. Replacing rear main seal
  100. A/C problem 2002 civic Please Help!
  101. having trouble with honda civic 2001
  102. Tranny problems? please help!
  103. dc2 seats in a Em2 ??!!
  104. d17a2 nos setup?
  105. U.S. and J.P. built trans interchangable?
  106. Passenger pwr window doesn't work...
  107. My Build Thread (2003 Civic Sedan)
  108. 01 4dr and 2dr trunk
  109. 06 Dc5 seats in my 02 lx
  110. does any one know how to bleed a break cylinder?
  111. transmission break down
  112. DO 2nd gen FIT sport rims fit 01 ES2?
  113. electrical issues (lights)
  114. MT/AT Throttle Body
  115. Hello everyone
  116. Just picked up an 03 ES1 after my 97 accord was stolen. WHAT SHOULD I DO TO THIS CAR?
  117. Overheating problems.
  118. 01-05 exhaust on 98
  119. Ac blowing Hot
  120. Cel on in 01 Civic
  121. What kind of gas do you guys use on 7th gens
  122. Different overheating problem. (screw summer heat)
  123. stereo question
  124. Help: how to replace driver's side window
  125. a/c problem
  126. manual tranny problem help...
  127. 2005 Civic EX OVERHEATING!! HELP?
  128. chipped ecu
  129. Broken belt, bent valves replaced, uses more gas than before
  130. Speaker size 04 civic ex coupe
  131. Honda Civic Choking
  132. d16z6 i/m on a d17a2
  133. New Cluster w/tach Old no tach????
  134. Need to rebore plug whole
  135. Headlamp + Taillight recommendations
  136. Mysterious Engine Noise
  137. uneven dropped problem. need help
  138. Cylinder 3/4 multiple/random misfire- freeze data inside
  139. Replacing HG, TB, & WP, Should I replace anything else?
  140. Wiper switch
  141. CHECK ENGINE LIGHT
  142. Diagnostic Code P1457
  143. Shifter linkage or synchronizers??????????????????????????
  144. Could my heater core be leaking?
  145. Anyne know how to change window REG.
  146. Tinting taillights
  147. electrical Issue(s)
  148. Brake light on and A/C stops working at the same time
  149. Is this the grille everyone is looking for?
  150. Repeating P0401 code on 04 Civic VP
  151. whats this
  152. Can't decide what wheels to have on at Import Alliance!
  153. Civic Tune-up questions
  154. Can I use KPro for my inspection?
  155. Intake question for 03 civic
  156. need some help
  157. transmission F***ing up
  158. civic sedan steering problem
  159. Will These work on my civic?
  160. Can't K-swap and auto-to-manual swap at once?
  161. iPod Installation 2003 Civic Hybrid?
  162. is awd swap possible?
  163. 05 Civic d17a2 Problems
  164. ecu reflash problem?
  165. '09 Legacy suspension fit '03 civic?
  166. 2002 Sedan: Door Interchangeability
  167. what do i do? maintenance record light?
  168. Timing belt question
  169. Really annoying cooling system problems
  170. civic hesitation
  171. P1457 - have read other post but looking for advice
  172. Gasket has enveloped the spark plug?
  173. Need Help with AC on 02 civic
  174. wheels
  175. Trying to sell a chevy! lol
  176. How To Remove Head
  177. what size bolt ???
  178. P0420 after replacing O2 sensor
  179. 2004 Honda Civic EX Overheating Issue
  180. Transmission whine????
  181. What size crank pulley bolt holder do i need?
  182. need quick help. A/C Problem.
  183. gauge light swap
  184. Trade my rims?
  185. CEL Flashing and Instrument Cluster not working
  186. Overheating help
  187. new header
  188. Have any of you purchased these rear camber kits?
  189. Cooling System Problem
  190. transmission fluid
  191. 2001 Honda Civic EX, broken timing belt
  192. el front conversion?
  193. question about kyb agx + eibach combo
  194. My Build Thread
  195. Stuck Lose Sparkplug
  196. Honda shop near Redmond WA
  197. Few quick questions regarding coolant and fans
  198. bk, have it your way! (pun intended)
  199. 2 door side skirts on a 4 door?
  200. 01 LX fob?
  201. wheel fitment
  202. What year transmission fit 01?
  203. "Rattling" noise, looking for input
  204. How To Force My Civic To "Forget" A Keyless Remote
  205. Fuel Filter Part Number?
  206. Honda Civic RS Grill question
  207. problem with resetting srs help please
  208. has anybody had any problems with there high beam switch?
  209. Drum to Disc Conversion, part list
  210. 01 civic hx no high beams?
  211. Any help here guys?
  212. VIN question, rather urgent
  213. Cluster lights stay on and dim when headlights are on?
  214. Best method to repaint SRI/CAI?
  215. Tein Basics...
  216. DIY Motor Removal ?
  217. If anyone happens to...
  218. Engine help. Please read and advise...
  219. Fake HKS
  220. 02 ex 2dr coupe
  221. ecu flash
  222. Homemade Crankshaft Pulley Holding Tool
  223. Headlight #'s Help Needed
  224. Battery/Alt light is on charging good
  225. changing gears and idle rpm drop ?
  226. How much whp does the 2004 honda civic si have?
  227. about to order new front strut but what else?
  228. Do you think a 2004 si with 78000 miles worth 10000 plus-
  229. Does the 2004 civic si's not come with a engine start button?
  230. TORQUE SPECS PLEASE!
  231. i need some technical support.. : /
  232. i need some technical support.. : /
  233. Inspection Check location....
  234. today i blew my engine need some help
  235. 2001 honda civic ex let me know what you think
  236. Question?
  237. 2002 Type R (EP3) Window regulator: Help!
  238. tie bars
  239. 02 civic AC problem
  240. Stalling when cam sensor is plugged in. Why?
  241. Trying to original engine back in a swapped car, parts questions.
  242. A/C problems too!
  243. Should I Buy This?
  244. Heater Blower Relay Melted
  245. Looking to buy new wheels.. 16 or 17?
  246. Transmission Fluid
  247. Strange noise?
  248. Strange noise?
  249. wiring diagram for power mirrors?
  250. Trunk Board?
