PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Disabling Seat Belt Beeper
  2. Red Emblems
  3. what's wrong with this picture?
  4. Honda Civic Hybrid Stereo
  5. Spring+Shock Questions
  6. Squeeking clutch pedal
  7. Fuel Filter Location
  8. Sunroof maintenance
  9. 2002 civic ex wiring???
  10. carbon fiber mirrors
  11. em2 vtec Ecu?
  12. '01 civic (em2) gauge cluster led question
  13. Where to find 01' LX Swaybar?
  14. help with seat
  15. anyone have pics of 205/45/16 on the ride?
  16. 2002 Civic EX Hesitating from Stop when Below 1/4 Tank of Gas
  17. k20a2 in a 4 door
  18. alarm system
  19. 2004 EX Driver's Side Lower
  20. Carbon Fiber
  21. turbo timer
  22. Quick Exhaust Question
  23. Keyless Entry?
  24. oem dc2 wing?
  25. Brake rotor install question
  26. Wheels
  27. Who here has changed the type of oil they use.
  28. ? for those who has yellow fogs.
  29. Springs? Shocks? Suspension?
  30. anyone know the stock oil pressure specs?
  31. K swap in California / smog issues
  32. what can you do or buy to get rid of...
  33. Strut/sway bars - mods
  34. I NEED HELP! Please reply...
  35. Need help! Thanks! :D
  36. Painting Unmatched body parts
  37. where is this meet on sunday
  38. BRAKE HELP!!!!!
  39. D16 Manifold on a D17
  40. VTEC
  41. Vortekz Universal Vortex Generators????
  42. Turbo Kits
  43. Em2 emblems?
  44. meet this sunday
  45. complete coilovers setup...best and worst?
  46. Brakes and such
  47. flashing "main't required"
  48. I JUST SEEN A UFO AND HERE IT IS.
  49. Type r wing
  50. Keyless entry, alarm, remote start
  51. How to: DIY black out headlights
  52. Hello and a Q
  53. Is it really worth $2400?
  54. Timing belt question
  55. 2007 Si whole suspenson....??
  56. R_status
  57. Enkei Wheels
  58. Squeeling Honda Civic EX 2004
  59. DIY 7th Gen Racing Seat Install
  60. Maintance required blinking
  61. Civic EX03 Battery Light Question
  62. ROta gt3 15x7
  63. k20?
  64. Where do you buy your parts?
  65. my 98 crx w vtech jus added
  66. "Cold Air" Intake VS. AEM Air Filter Vs. OEM Air Filter?
  67. Exhaust question
  68. HID bulbs
  69. Cylinder misfire question
  70. New to the site...
  71. need a door
  72. Still a trial user but had a question...about financing a civic...
  73. em2 type R emblem (red H)
  74. WHAT SIZE SPEAKERS??
  75. 2002 Civic EX coupe mod question
  76. pic req/questions : Tanabe front strut bar
  77. hi
  78. Which mall retails ES bushings?
  79. Power/Gas Issues, Car Turns off.....
  80. k20a swap
  81. k series page
  82. mant. req. Light
  83. 03 lighting
  84. has anybody seen our sevns with white wheels and red lip
  85. manual transmission oil
  86. Dashboard Lights ????? Colour Change/MOD
  87. Front LCA Removal Problems...
  88. I NEED HELP MY CAR WILL NOT MAKE MAKE ANY POWER
  89. Need a good tuner!!
  90. 2002 Civic EX/si battery problem
  91. WeatherStripping
  92. new member exhaust manifold question
  93. Engine Swap: Reputable Shop [ reasonably close to Southern Indiana ]
  94. 01 Civic LX
  95. y8 manifold for ITB's on d17a2
  96. 2001 civic ex manual transmission prob
  97. black car and white wheels
  98. Piping size
  99. please help, big problem.
  100. PISSED OFF
  101. 2001 civic upgrade recomendations
  102. Quick!!! Is anyone familiar with this AEM cam gear????
  103. 2001 civic whining noise
  104. blew a piston
  105. A/C Compressor replacement
  106. CIVIC SPORT PERFORMANCE ENHANCEMENT
  107. SRS repair questions. [I need help]
  108. my 01 civic
  109. Rear disc conversion on an EM2
  110. Side Markers...
  111. Newbee
  112. Header Sir
  113. Lip Material
  114. so long all.
  115. Changing climate control lights Help
  116. speedometer reading off
  117. Tanabe DF210s any good?
  118. 01 civic ex engine swap
  119. where to find lip kits?
  120. Ex Only parts????
  121. Automatic transmission.
  122. Will a d16 tranny work with a d17?
  123. Cheapest OEM replacement shocks/struts
  124. 94 gsr engine in to 91 crx si.
  125. Can the Tokico Blue's handle stock springs?
  126. battery/fuse/wire problem???
  127. how much to install shocks/springs?
  128. DIY shocks/springs ?
  129. factory tuned
  130. 2002 civic lx SRS Light
  131. anyone with aero lip /side skirts ...
  132. enigne problem. rev limiter at 3900 rpm
  133. CAI/cat back exhaust installed, is it necessary to reprogram my airfuel mixture?
  134. Werid electrical(?) problem
  135. Radiator cap info needed.
  136. engine swap
  137. 05 special edition radio fit in an 03 EX
  138. How much paint do I need?
  139. CHECKING THE ECU CODES
  140. EM2s with stock K20 engines - Estimated Track Times
  141. 205/55-15 on a stock height 01 civic
  142. ***01 Civic Si EP Radio Problem**
  143. Just got an 04 si, anyone got parts?
  144. 2002 Civic Headlights not working! after removing OEM fogs??? any help
  145. Conversion -
  146. Looking to slide into a Hatchback
  147. headlight help!
  148. Will D16 parts fit the D17 parts?
  149. Quick swaybar question.
  150. clear corners
  151. tokico blues vs. koni yellows
  152. need help changing timing belt marker info?
  153. 2001 Civic Automatic Transmission Failure? Common Problem?
  154. 2002 civic ex Check Engine Light
  155. 05 si
  156. Stereo install kit that keeps the drawer at the bottom, any ideas?
  157. 1 New Pic...LOL
  158. K-series or boost
  159. car alarm help
  160. What are exact differences amongst DX, LX, and EX for 2004 Honda Civic Coupe?
  161. MRL light maitance required light how to turn off after oil change?
  162. differences between 01-02 sedan suspension?
  163. Wondering about
  164. auto cross
  165. D16Y8 MIMI ME BUILD?
  166. new to the honda group now
  167. Suspension suggestions??
  168. 2005 civic sedan
  169. 30,000 mile maintenance
  170. Weird noise/vibration
  171. Crower Satge 1, VAFC2 and Pnp Harness for D17a2 in san Diego, CA.
  172. Intake Manifold?
  173. Just bought 2001 civic lx and wana modify, HELP!
  174. DC5 parts for EM2
  175. bottom grill paint
  176. 2001 Honda Civic LX
  177. ready to buy, need help!
  178. k20 count
  179. fog light ?
  180. Web sites.
  181. Which Gen. is better?
  182. TOE HOOK help installing
  183. deteriorating idle
  184. Anyone know if the Acura EL and Civic have the same Bulb type?
  185. Which of these LED mirrors are correct??
  186. aiming headlights?
  187. shift boot
  188. FS Factory Fog lights
  189. Flasher located?
  190. DC2 Wing
  191. gsr mirrors?
  192. Fuel Mileage Thread!
  193. A new method of EMS out by AEM
  194. 2003 Honda Civic Hybrid 5MT NOx 3-way catalytic converter replacement?
  195. DIY headlights
  196. 2002 civic starting problem
  197. Automatic Transmission Flush
  198. Clay Bars
  199. Grill Install
  200. Rear passenger side tire rubbing...
  201. Ticking Noise from top of motor and vibration in gas peddle. any help apreciated. posted June/04/20
  202. New Dezod Turbo Kit
  203. Check out what I came accross this morning
  204. How long will you keep yur car?
  205. Need suggestions on performance parts
  206. side skirts ES2
  207. Side mirrors???
  208. Major Car Trouble Need HELP!
  209. k20a2 Opportunity
  210. Need some help on some performance shocks
  211. Stock wheels
  212. Changing Automatic transmission fluid
  213. Pic request on painted 04-05 ex rims
  214. black tail lights
  215. AC Problem - Compressor Cycles while Driving - Civic 03
  216. Most powerfull turbo D17 dyno sheet inside
  217. Front suspension clunking noise, struts replaced, still making noise. 01 EX
  218. ecu ?
  219. Your opinions about rims on stock height?
  220. Need a pic of some Konig Heliums
  221. Radio Error Code
  222. Anyone interested in a set of 4 lug Black Konig Helium's with a red lip?
  223. Need some body help
  224. 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG
  225. what tires are you running?
  226. K24 swap possiable?
  227. My Build Thread
  228. Best spring/shock match?
  229. The reason shocks blow. Mechanics help, interesting argument.
  230. Civic SIR headlight question?
  231. LX to EX horsepower difference?
  232. Very strange problem, please help
  233. major problems plz help
  234. Tips on Waxing
  235. Bucket Seat
  236. Newwww
  237. OEM Front Lip...
  238. Ground wires
  239. St Louis Tuners?
  240. dezod kit ?'s
  241. My Build Thread
  242. removing center console?
  243. Performance Chips, Recommended?
  244. 01 HX exhaust
  245. Turbo for 05 Lx
  246. Skunk2 Exhaust?
  247. Sorry if this has already been a topic of interest
  248. need
  249. 2001 Civic tranny question...
  250. 04-05 Ebay Fogs HELP.....Please (Pics)
