- "Help!!!"I need a D.i.y on how to swap rsx cluster in my 02 civc ex sedan
- 05 Civic Hybrid P1433 Help...
- Should the LCA move up & down on compliance bushing?
- What ES1 lip are these? are they stock?
- idle and rev issues
- drum brakes
- RSX rear seats in em2??? need help
- Steering feels too heavy.
- intake help 2!!
- EM2 Apexi Neo Help
- starting problem..
- MANUAL CONV HELP
- 04 sedan Horn quest.
- Wheel hop and LCA Q's
- Ebay motor mounts
- My Civic Stranded Me!!
- 01 civic trans problem help!
- Ingalls suspension parts
- Had my car serviced today. Few questions.
- Coilover 2001,2004
- Screeching Noise!!!
- Stock Wing!
- Where can I find a dash kit for an em2?
- 1.7L SOHC 16 vlv with oil in intake
- Reverse (Backup) Lights Not Working
- Need help figuring out Kswap cost!
- 2004 Honda Civic LX
- HELP! aftermarket projectors...
- Side skirt help
- 2005 Civic Hybrid folding mirrors fit on 2002 sedan?
- valve adjustment 2001 civic
- 2002 Civic 4door ? Hearing Gas Tank?
- Member (Pekpekilla) Ripped me off!
- 2004 sedan tweeter pods
- *** DRL PROBLEM 2003 HONDA CIVIC ***
- 01 Sedan Tail lights in a 04 Sedan (Searched)
- Anyone have a DIY on rear wheel bearings?
- Transmission stutter after timing belt replacement
- 01 manual trans problem
- Spongy Brake Pedal Fixed!
- Need Stock intake for '05 Civic - 1.7L
- 01 Civic LX check engine low voltage
- Trans OR torque converter? please look.
- car overheating with heater on... help!!!
- header problems
- 2002 civic slug acceleration
- Maint' Req'
- Steering wheel emblem
- Yeah, yeah... more eBay fog light questions
- Trip OD, Maintenance Req. light
- Trunk interior
- 2002 Civic EX Transmission Problems.
- LCA and Lower Tie Bar (help)
- Where to get standard connecting rods for D17A2 engine
- replacement headgasket
- Power Steering Issues
- Headlight beeper not working.
- drissn's es1 build
- How to change Manual transmission gear oil for 05 Civic hybrid.
- Help on my 02 civic
- Broken Engine Please Help!!! (01 civic LX)
- 05 Civic LX- Stereo deck swap
- Going to change the timing belt soon.
- '05 Civic w/1.7L engine - Help with oil pan removal
- Connecting rod cap torque for '05 Civic EX (SE pkg)
- ecu problem?
- "03 Civic Lacks Power
- gauge cluster light issue
- Instrument cluster keeps blanking out
- Has Anyone Here Used Ebay Front Control Arms?
- do they need to be replaced
- Skunk2 519-05-1570 - WHERE?
- Handbrake cover
- cel
- d16 header on d17?
- headers
- Red H emblem - HELP PLS?!
- Lower control arm question.
- is it true i can reuse my stock head studs one more time?
- hard start and running stall...
- what tq should the head stud be?
- 03 civic ex trany help!!!
- Best place to buy tokico blues, in pricey wise
- 01 LX 2nd Gear Tranny Problem
- 2004 Civic LX replacement key
- STAGE 1 cams????
- 5 lug conversion
- New honda civic owner
- Car overheat when AC or Heater is on
- 01 civic ex a/c comp. clutch flew off! quick question.
- what action should i take (if any)
- PO139 WTF
- kpro question
- hi quick noob question
- what should the cam gear look like tdc?
- AC question
- Stock Radio Reception
- D17A1 /D17A2 exhaust manifold
- New owner Q - bumper molding?
- 2002 civic - driver door does not lock/unlock with key fob
- ac compressor question
- terminal replacement???????
- 03 em2 cluster conversion
- Replaced stereo, now Civic stalls at stop lights. IACV problem?
- Engine problems and srs
- How Much Can I Sell $$ My EM2 for?
- Ugh, i have pretty much lost reverse, what's it gonna cost me?
- tsi injector interface block install
- OEM Foglights + HFP Lip?
- vtec codes
- P0136, P0113, P1298, P0135, P0141, P0128 codes that I have on my 01 civic dx
- 01 Civic LX starting to get a sluggish/bogged down start
- whats the socket size for oil pressure switch d17a2?
- k swap
- 2004 Civic ES8 - Suspension problem
- Just bought a EMII!!!
- Electrical disaster update!! Please help!!!
- Need help asap
- Help Please!
- Squealing sound when ac is turned on at low rpms (01 Civic LX)
- My A/C is brutal
- 04 EX Electrical problems! Please Take a Look!
- 01 LX Civic
- My em2 build progress
- rpm working erraticaly
- Having Trouble Mounting Sideskirts
- exhaust help.
- 2003 Hybrid overheating. Cannot find reason.
- Em2/ dual din in dash mounting
- Energy Suspension Motor mount inserts(help)
- valve adjustment specs
- How to reset Maintenance light with broken cluster?
- 2002 Civic Brake Job
- Side view mirror(help)
- overheating solved?
- Car Issues (whining noise)
- help me identify these coolant hose
- my 2001 civic is overheating after long drives
- civic over heating sometimes
- dc5/ep3 bars and braces
- drop question??
- V6?
- little more power for my everyday car
- 2005 es2 70K Service Price quotes
- sohc turbo engine durability
- Koni Customer Service?
- 01-05 Honda Civic Transmission questions
- whats the deal with em2s?
- Do I Need To Change My Transmission? What's Wrong With My Car???
- Disaster Electrical
- Never seen this when changing my oil
- What is this spoiler called?
- 2004 Civic - D15Y3 - idle problem
- Trasmission Bad
- What is the easiest way to change low beam on 2004 Civic Sedan
- Weird noise when idling and revving...
- 01 honda civic transmission swap cost
- Honda LX 2001 coolant reservoir tank over the limit...
- Any tips to reduce spring noise on a lowered car
- No blinkers? Fuses all good...
- d17 auto trans slipping
- Do your brake pads wear evenly?
- ecu pin outs for the 04 dx?
- 2005 Coupe Grille Alternative for 2001-03 Coupe?
- 01 Civic overheating-need suggestion please
- P0341 Camshaft Position Center, em2
- My Build Thread
- Keyless Entry
- Complete loss of power
- 2001 civic ex bat light on still.
- em2 auto to manual swap wont get spark at coils
- Trans Noise
- em2 tail lights
- Civic mud flaps
- 01 civic ex cooling fan not working
- 05 civic burning oil
- 2001 civic ex 2dr/4dr fuse box the same?
- I missed the OPDS exyended warranty by 6k miles
- stuck under 3800 RPMs
- Choosing a Trim Level for my next car purchase
- is the stock exhaust manifold for a 5 speed the same as an automatic?
- 2001 civic ex engine misfire?
- Burning smell coming from passenger side window HELP!
- Can someone PLEASE tell me whats wrong with my Civic???
- 03 civic dx cluster help
- airbag light on dash.
- Number of bearings for front upper strut bearing assembly
- Acceleration problem
- A/C Compressor replacement or reseal
- Stock airbox resonator thingy??
- 03 civic starts then dies
- D17A2 A/C delete
- how to install rear 2001 honda civic speakers
- so yah, i better not spend anymore money on this VIC
- A/C working intermittantly
- Center wheels dimensions ??
- Transmission issue? Please help...
- Rear Wing LED light strip..
- Installing Power windows
- 2001 honda civic stereo code
- Water in '03 driver side footwell
- 02 to 05 conversion!
- Multiple problems 2001 civic vtec ex?
- 2001 civic axle help please
- Would you trade?
- Gauge set
- my list of items for a full tune up. anything else am i missing?
- Manual Transmission Question
- Mobil1 0W-20 / Mobil1 5W-20
- Need help 2004 civic harness wires
- Lowering
- Engine shaking at RPM 5
- Radiator Replacement
- headlight?
- Will any other Honda alternator fit into a 7th gen?
- car problem!
- help: symptom missfire in cylinders
- Stock Height?
- 02 Civic EX service manual in PDF format?
- steering gear gaiter
- Headlight Wiring Diagram?
- Stock to halo's
- Help me figure out where this wire goes.
- ELD issues? Stumbling while accelerating... Replaced but no fix!
- ANOTHER bmxa transmission thing.....
- HELP! Driver Side Mount!
- Question ?? throttle cable
- need help
- Hand Me Down Project
- 2003 Civic LX Horrible Gas Mileage
- GETTING HOT WHILE IDLING
- HELP! I need a DIY for 01-03Fog light installation
- Radio locked after battery change.
- Cold air intake insulate
- So, I have some extra parts (door lock cylinder related)
- Used motor question
- Em2 d17 intake help
- Upgrades/acceleration
- Official EM2/ES1/ES2 Slammed thread
- Strange and concerning fuel-related issue with '01 Honda Civic. Please help!
- 01 Civic EX overheating
- dx and lx engines
- Help with Alternator problem
- 2001 civic stumbles, wont accel above 20, then boggs out
- Civic GX engine and trans question.
- K&N Intake on 02 Civic Caused Hood Damage
- WHich after market control arm is good?
- Spark Plugs
- Multiplex Control Unit
- My 01 Coupe (manual) is making a strange noise.
