PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. clicking noise right under the valve cover
  2. Question about lowering springs help!
  3. Heated seats for 05
  4. this 01 cluster will fit my 04 civic right?(both are from sedans)
  5. 2001 DX Transmission Question
  6. 03 EX A/T Rattle noise in reverse (HELP)
  7. bump steer?
  8. Help! Annoying defroster problem. 2001 civic LX
  9. My Build Thread
  10. 02 civic gx coil resistance specs??
  11. My 2001 Civic EX is driving me nuts, help me please!
  12. Cleaning Engine Bay
  13. New to the forum, one quick ?
  14. Clutch Issue..
  15. 2001 Honda Civic Overheating
  16. Someone hit my Civic!
  17. Finally dynoed it again. Check out the results.
  18. Electrical overhaul needed.
  19. em2 fog light
  20. what color TOW HOOK for a SSM?
  21. 02 Civic A/C Mode Selections Problems
  22. 04 bumper onto 02 em2
  23. EDM Rear Foglight Placement
  24. rsx type s seats in 2005 civic
  25. Clunky Suspension
  26. Maitenance Required light, curious
  27. Check engine light came on!
  28. Wheel bearing and ball joint removal and replacement
  29. Online stores
  30. Aem short ram intake ITA trouble
  31. 2002 Civic EGR Valve
  32. I Need A New Cat, Where To Buy
  33. First Post... Couple Questions...Need Help
  34. need a little help with these coilovers
  35. em2 on GROUND CONTROLS
  36. Civic Instrument Cluster Replacement
  37. Quick question, lowering springs..
  38. 2005 Honda Civic Ex blown headgasket
  39. Speedometer problem
  40. Shifter cable issue (help)
  41. whats your rim size?
  42. Rear camber kit problem HELP!!!
  43. EP3 type R cluster
  44. Wiring Issues
  45. First Honda, have a question about possible engine problems
  46. hood spacer
  47. Brake Caliper..
  48. greddy e-management
  49. Interferance problems with an 02?
  50. ~~~~Clutch Replacement cost? mileage?
  51. Question about fidanza flywheel....
  52. Door side panel replacement/repair?
  53. Any idea's how much a brand new oem RS lip goes for?
  54. 04-05 civic fog light problem
  55. question on head gasket set brand
  56. intake "box"?
  57. Rim question
  58. Headlights
  59. DIY question
  60. Civic washer nozzles question
  61. 2001 Civic EX stalling Occasionally at stops
  62. 06 RSX Type-S Rear Sway Bar fit an 05 EX Sedan?
  63. Cleaning the Carpet
  64. Sexy lip
  65. Base RSX supension
  66. 2005 Honda Civic Overheating Saga
  67. -rsx seat conversion-
  68. Shift interlock mechanism problem when in Park honda civic ex 2002 auto trans?
  69. em2 dropped on stock shocks and coilover sleeves??? help
  70. 02 Civic DX front end vibrating/wobbling
  71. exhaust help
  72. Engine Went Bad
  73. yellow highbeam bulb question
  74. Help! 02 Civic Key Replacement?
  75. Itek hid's
  76. honda wheel center caps
  77. Civic audi HID conversion
  78. Fogs for 05
  79. 2001 civic 100k worth $5500?
  80. ignition question
  81. how to take off door handle?
  82. where do u ground your foglights
  83. Brake Recommendations for replacement
  84. how to swap tailights from 04-05 to 01-03 civic coupe
  85. strut bars
  86. '03 tranny problem...any ideas?
  87. 15" Rims and Tire Size??
  88. Ok i need help on my coilovers
  89. Third Brake Light Problem
  90. Do they sell fake progress coilovers?
  91. nrg quick release
  92. Removin Rad support
  93. DO i need a camber plate, or kit?
  94. Engine knocking possibly?
  95. coils from rsx to em2?
  96. does this mod really work: Throttle-Body Heater Bypass
  97. auto to manual tranny swap parts
  98. New Brakes doing clap,clap,clap sound
  99. My Build Thread
  100. Strange vibration front right side
  101. Exhaust for Sedan Fitment Question??
  102. Alignment...Should I wait or do it right away?
  103. air ride help
  104. 04-05 rear bumper on a 01-03 civic 4 door?
  105. 2002 civic ex - all at once stopped working
  106. 2004 Civic EX, 18.7mpg !!!
  107. d series questions! need helps plz
  108. oil/oil filter question
  109. IAT Messed Up?- Why fuel gets cut off.
  110. 04 civic tail lights
  111. spoiler install on es2?
  112. 01 civic over heated
  113. 01 Clutch Adjustment
  114. Buddy selling me his civic
  115. Does eg brake pads fit on em2?
  116. Coilover Owners..Chimein..
  117. has anyone swapped a V6 into an EM?
  118. interior light problem
  119. Need help on rims
  120. my retrofit project
  121. Suspension/Engine Question
  122. cam gear question
  123. where is the VIN number located on a d17a2
  124. question bout fogs on my es1
  125. ATF dipstick untied? fluid out the hole. 05 LX
  126. Suspension noise?
  127. Relay Chatter
  128. HID Problem
  129. My build thread
  130. wheel and tire size, just wana make sure
  131. value package A/T header?
  132. looking for a factory spoiler LED brake light
  133. Front end shaking
  134. short shifter
  135. what rims are these?
  136. FK steering wheel into em2 face lift! how to do?
  137. 2002 civic tail lights
  138. did know where to ask this at :)
  139. OEM Factory Spoiler Removal
  140. 2005 civic lx 4 door
  141. Tail light and gauge cluster problems.
  142. tranny problems
  143. ep3 wheels with quick release
  144. Good prices on OEM body/eletrical parts....
  145. civic won't start
  146. Error code relating to bad ECM and Catalytic Converter
  147. problem in the steering wheel
  148. 5 lug conversion
  149. faulty gas tank sensor
  150. Broken hood latch bracket
  151. Diameter of the MT shaft?
  152. can i run a stock muffler on my k20 turbo????
  153. Rough vibrations during shifting
  154. Steering component question?
  155. What are the differences in 2001-05 EX Sedan?
  156. Belts
  157. air bag light came on after motor replacement (help plz)
  158. cat converter is shot
  159. code p0453 fuek tank pressure sensor?
  160. Fog Lights Install
  161. Windshield Molding
  162. Going K-ing
  163. type r seats?
  164. Ah, Complience bushings
  165. 01 Civic p0171 and odd fuel problem
  166. help removing 01 4 door panels
  167. Buying 2005 Civic
  168. New Battery...now car dies?
  169. airbag light is on after i remove the seat.
  170. HID's in Fog Lights
  171. will the stock full exhaust from rsx fit our car??????
  172. HP racing headers
  173. 225/45/17 +35
  174. civic lx 02 what can i use to replace tranny?
  175. Mysterious P1457 Code
  176. Power door locks and power window fuse's keep blowing
  177. **too stiff? Or normal?**
  178. Speed Chip Question
  179. 02 Civic EX Jerky Off Gas
  180. CEL light flashed before the car is started.
  181. Traveling Abroad
  182. Civic '04 EX - Audio
  183. pics of em2 es2 on coilovers
  184. need help guys with srpings
  185. Question
  186. Strange starting problem
  187. Question about lowering springs.
  188. hid retrofits?
  189. Terrible sounds in rainy weather...
  190. headlight harness burning
  191. 03 civic transmission swap
  192. Has anyone found a 4-2-1 header made for the 01-03 civic EX?
  193. 03 civic LX foglights installation
  194. AC compressor cycling on/off
  195. rear bumper help
  196. Oxygen Sensor Upstream
  197. Ksport issues with tie rod ends?
  198. please help asap. the anti theft system broke
  199. Noise from front suspension
  200. Another P0420 code
  201. side skirts?
  202. Oil in spark plug well, sputtering
  203. Can someone verify that this intake is from a 01-05?
  204. engine swap
  205. 02 Civic EX transmission issues
  206. 03 ex manual trans
  207. My Build Thread
  208. Cel//p1298//p0420//p0132
  209. Cigarette lights plug problem??
  210. question on OBX short shifter!!!
  211. Breaks
  212. srs light
  213. Suspension?
  214. Please Help and Explain!!
  215. 2003 Civic Hybrid Transmission Problems?
  216. Question about suspension.
  217. Where to Buy JDM style grill?
  218. D17A2 Help.
  219. where to start
  220. does any other ecu fit a 7th gen civic
  221. Engine flush didn't work
  222. Suspension
  223. 2003 Civic LX Speakers
  224. Cold Air Intake for my 05 civic?
  225. Ferio Es1 set-up
  226. rsx hub
  227. Progress rear sway bar adapter kit.
  228. How to remove CIvic back panel???
  229. Air Bag Help!
  230. Second time ECU has died
  231. rsx front conversion?
  232. Radio Help
  233. Headlights.
  234. Looking to lower my 05
  235. Advice on a 04 lx a/t
  236. Show your headlights!
  237. sub frame
  238. KW Variant 2- Help
  239. what transmission will fit 01 civic
  240. My 01 Em2
  241. Help! Someone ripped out my ignition starter switch thing, can't start up my car!
  242. Problem with 01 civic lx.
  243. 2005 Honda Civic EX Questions (sedan)
  244. Transmission Failure?
  245. Bumper Problem...
  246. Should the PCV valve be replace regularly?
  247. radio not getting power.
  248. CEL ~ Help me out!
  249. Should i add a bottle?
  250. jdm honda badges
