PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Manuel Transmission Fluid
  2. 2005 EX overheating
  3. 02 Civic DX Overheats on Long distance drives.
  4. clutch squeal
  5. Where can i find new cluster faces
  6. 2001-03 Oem full lip kit, not HFP.....Looking for Nighthawk black
  7. 11.7 volts from Alternator?
  8. Confused about 2002 EX Sedan stereo harness
  9. 2001 Honda Civic sputters and all the lights din
  10. Bad gas mileage and intermittent starting issues
  11. 2002 LX A/C problems
  12. 2005 Civic Won't Start After Head Gasket Replacement
  13. Battery Replacement
  14. 2001 civic ex question help please
  15. P0122 - TPS low voltage
  16. S2000 Oil Filter
  17. Fuel fill door opener broken
  18. 2003 EX - Problems with Iginition? Takes a couple turns for car to turn over/start?
  19. Drivers side door lock sticking
  20. My 03 civic EX Airbag icon went on!
  21. Code p0172 and Hesitation Problem
  22. Cabin Air Issue
  23. Problems w/ 05 Civic
  24. EM2 with less tranny issues?
  25. Cluster swap questions
  26. 6th gen cluster in a 7th gen?
  27. 05 Civic LX strut tower bar
  28. 2003 civic hybrid lights shortage
  29. D17A1 torque specs?
  30. K swap?
  31. squeaky clutch
  32. axles for type r swap
  33. A/C problem, serious?
  34. ECU Reset and Idle Relearn
  35. 2005 Honda Civic EX Over heating problem - Need Help
  36. Gas gauge off but then I get 54mpg?
  37. A/C Compressor Clutch not Engaging
  38. civic 2004 srs no light
  39. New Headgasket Install Questions Using Hylomar
  40. Manual Transmission Main Shaft Help.
  41. 2003 Honda Civic Red Addon Ideas.....
  42. 2003 Civic AC
  43. EM2 timing belt replacement, now it runs rough...
  44. 2005 Civic coupe,trunk lock chrome cap?
  45. 2001 - 2005 Civic Blown Headgaskets
  46. 2001 Honda Civic LX (Manuel) TDC Sensor
  47. 2004 honda civic rattling noise
  48. 01 civic coupe eletrical problems
  49. 05 Civic seat belt sensor help!!
  50. RSX ebrake cables on 02 Civic EX
  51. My Honda Civic 2003 Automatic Sleeps Suddenly During Driving.
  52. Sizzle Sound After Turning Off
  53. Replacing Engine Mounts
  54. Mud Flap
  55. can i put this lip on?
  56. A/C problem
  57. 01-03 RS lip
  58. 2003 Honda Civic Computer Chip Help!
  59. Jerk on Deceleration
  60. just bought my first honda
  61. 2002 Honda Civic Coupe.
  62. civic transmission help slipping when cold, fine when warm code po730
  63. Engine Codes 2002 Honda Civic EX
  64. 2001 Honda Civic LX help !!!!!!!!!!!!!!!!!
  65. 2001 LX 4-Door Grounding Issues
  66. 2001 Honda Civic LX help.
  67. New Carbon Fiber hood. Hood Pins?
  68. Please Help, my civic doesn't start!
  69. Lubricating a brake drum and brake assembly?
  70. P0740 DTC - Any additional ideas?
  71. Will a 2005 4dr rear bumper fit a 2003 4dr????
  72. Engine Oil Capacities
  73. 2002 Honda Civic - where can I get BMXA tran rebuild manual?
  74. 6 CEL Codes
  75. 96-00 auto trans in a 01-05 civic auto!!! help please
  76. what can i do for my d17a2 gets more power????
  77. Rear wheel brake cylinders leaking
  78. Back tires bigger than the front?
  79. 2001 Honda Civic: CEL on with P1362 - Car goes into Limp mode
  80. Pls help price my 01 civic ex coup
  81. D17A2 Swap / No Secondary O2 Plug / What Wire Goes Where
  82. 01-03 Civic Coupe/Sedan Fenders with Side Marker Cutouts**
  83. 2004 Check engine Code p0135
  84. Question about the 2 big main fans inside our hoods
  85. 04 Civic Cassette Player
  86. unique sunroof visor!! too cool.
  87. stop in go poping passenger front
  88. someone help tranmision removal 2003 civic
  89. Window problem.
  90. Battery Light Problem
  91. Civic 03 High Beam Issue
  92. swapped cluster for VP EM2
  93. 2002 civic ex right motor oil question
  94. Mag color help me please !!!
  95. 2002 civic EX door lock
  96. Warming up and cooling down an auto tranny?
  97. rsx type s wing to my em2?
  98. rsx center console swap
  99. Misfire Issues
  100. DRL, low-beam and high-bean (headlight) issue
  101. civic makes a loud sound when start the engine
  102. wipers not parking at regular spot
  103. 2001 civic trans prob..
  104. 2001 civic trans
  105. Radiator Removal...
  106. 05 HCH looking for more hp
  107. D17a2 head damage on delivery!!!! SOS!!!
  108. Help, please, I mean if you have the time.
  109. 02-04 RSX Ball Joints
  110. Install side skirt
  111. New motor ... sigh
  112. Odd ac issue, searched and searched...
  113. HELP!! my 01 isnt passing SMOG
  114. Whats the best strut tower bar for EM2s?
  115. will 2001 civic 2dr side skirt fit 4dr?
  116. hitch on 2002 civic ex
  117. trunk hard to lock
  118. alternator Noise
  119. new hub
  120. A/C ISSUES
  121. Oil
  122. 04 civic sounds like ecu is trying to kill the motor
  123. Check Engine- P0420
  124. clutch noise
  125. brembo brake swap
  126. best full coilover for best price?
  127. 2002 Civic EX Engine Swap question
  128. Rattling Noise
  129. My 2002 ex over heats when AC is on. Please help
  130. Civic 02 ac electical problem
  131. 05 lx rpm limit
  132. Changed Head Gasket & Timing Belt... Car Won't Start
  133. Rear lips for 01-03 Sedans
  134. What size are the gauge cluster bulbs on a 2001 honda civic lx sedan?
  135. can i fit 04 lip to 03 hybrid lip? anyone knows if there's much difference?
  136. Do i need to replace the rear mounting plate? (stud plate)
  137. New 04 EX clutch kit slipping
  138. Replacement Timing Belt hard to get On...What Do?
  139. Cel p0740???
  140. maintenance required light
  141. what kind ATF transmission fluid for 2003 civic
  142. 2002 Civic EX Idle Issues
  143. 2001 civic 1457 code
  144. ned hellp inproving my cars handling
  145. Help?? where locally can i buy a trunk latch??
  146. Car won't start - don't think it's the starter solenoid
  147. What is this orangish/yelloish light?
  148. A/C Condenser - 2005 Civic...help!
  149. 03 civic ex (vtec system malfunction????) HELP
  150. Misfiring? No spark? not running on all cylinders?
  151. Question about gear ratios on honda and acuras
  152. 2001 Civic EX D17A2 motor problem
  153. 02 civic not firing
  154. 2001 Civic LX Codes P0135 and P0141
  155. 2003 Honda Civic Sedan Taillight Pics!!! Please Share!!!
  156. US market alternator fit canada civic?
  157. Exedy HF501 flywheel not engaging starter
  158. Could I fix this window issue my self?
  159. Car shakes in idle 2002 civic ex
  160. 2002 civic EX A/C troubleshooting
  161. 2003 accord lx wiper problem
  162. Radiator issue and leak problem
  163. 2005 Civic Ex - What to do with bad Input Shaft Bearing
  164. Pushing the Gas Pedal all the way down.
  165. 02 Civic Lx Yea a A/c question
  166. Tranny failed...shocker
  167. 02 Civic ex misfire issues
  168. 2003 EM2 Murmur between 3000-4500 RPMs
  169. How to confirm the milage on a used tranny?
  170. Yes, another "A/C problems" thread...
  171. Replacing an 01 Civic Auto tranny with a 04 or 05 auto tranny
  172. 05 Ex Fog light install.
  173. big problem for me!!!!! please help! 2002 civic ex
  174. '04 Civic EX runs hot when AC in use
  175. New or used A/C compressor and other questions?
  176. 2001 LX tranny expectancy?
  177. blower motor
  178. Best procedure to check fuel pressure?
  179. Civic 2002 oil Leakage form oil pan gasket
  180. 2004 civic humming sound
  181. Car is over heating.. NEEP HELP!!
  182. A/C GETS WARM AND FAN SLOWS 2003 CIVIC EX
  183. Need help with Temp Gauge
  184. Cold start ticking
  185. 2002 honda civic ex auto trans need help
  186. My car is overheating. plz help!
  187. P0128 code
  188. Honda Civic Hybrid IMA Control
  189. 2003 Civic EX P1259 CEL Code
  190. Engine Swap 2001 Civic LX D171A
  191. retro fit 01-03 housing?
  192. 01-05 Coupe doors the same?
  193. 02 civic with bad times
  194. intermittent a/c -heat issue 03ex
  195. Headliner is peeling - NEED HELP ASAP
  196. fuel pump question
  197. Need to verify a quick A/C diagnosis procedure
  198. 2002 civic manual transmission problem
  199. 2001 civic lx auto P0304 misfire & idle problem
  200. 2002 Civic EX transmission problems
  201. 04 civic surges (gains power) at 50mph
  202. Tranny compatibility
  203. 2002 Civic Trunk Wont Stay Closed
  204. need help with clutch / slave cylinder
  205. Cruise Control in European EM2
  206. help with gauges
  207. Fog Lights Help
  208. Swapping K20A2 into my 02 Civic SI coupe. Some questions.
  209. Whole lotta shakin' going on...
  210. dome light??
  211. altitude change ?'s
  212. 2005 honda civic looking to swap in k24a2
  213. Good Aftermarket Intake Filter?
  214. 02 civic AC freezes up
  215. intake removal and cleaning
  216. code namber for radio
  217. 2002 civic LX - headgasket?
  218. New Here....01 ex A/C problems. Please Help
  219. trashed engine?
  220. 05 Civic won't start, please help a noob!
  221. playing engine check light
  222. Bad vibrations coming from front suspension
  223. Looking for some help im stumped
  224. Can I find OEM spark plug at Advance Auto parts?
  225. Overheating
  226. how many people here did just timing belt and water pump not tensioner
  227. Em2 lighting problem
  228. Roaring sound?
  229. EM2 K Swap Auto?
  230. Ignition timing? Knock sensor?
  231. Vibration after putting into park or putting into reverse
  232. Grinding Noise with clutch
  233. Fog light harness
  234. Changing out old bumper?
  235. which brand water pump & timng belt?
  236. 02 civic ex keeps stalling
  237. GenesisAutoParts.com? pffft
  238. Need help relocating/customizing windshield washer reservoir
  239. factory alarm going off all the time
  240. Interior LED Bulbs
  241. Power steering noise?
  242. Exhaust question
  243. d17a2 gx piston
  244. 2005 Honda Civic SI D17A2, throwing some EGR codes
  245. 04 Civic Coupe Car peeps when trunk is open
  246. Tyre close to fender
  247. Heat Protector from Exhaust Fumes on Bumper?
  248. Bad Pulley?
  249. Issues with reverse. 02 ex
  250. question regarding updating the audio equip. to a 7" touch screen
