Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A2 Blown Headgasket Advice
Old 01-18-2019, 02:57 PM
sumdewd's Avatar
Default D17A2 Blown Headgasket Advice
Alright peoples. The time has come. I've leakdown checked my buddy's 2002 EX with the D17A2. Engine was cold since he let the battery die and I don't want to potentially overheat more. Here are the results:
Cyl 1 & 4: 2% leak at 90psi.
Cyl 2 & 3: 9% leak at 90psi, radiator starts to push coolant and bubble.
It must be blown at the water jacket around those two cylinders. Does a hot engine normally raise those figures up by quite a bit, or do you think this is possibly a good candidate for a HG replacement?
I know I won't know 100% until I pull it apart and do some straight edge measurements, but has anyone gotten lucky with one of these? I'll basically be getting a head gasket set and new head bolts, taking measurements, and possibly getting resurfacing done at a shop.
Old 03-12-2019, 04:18 PM
sumdewd's Avatar
Default Re: D17A2 Blown Headgasket Advice
Update: Tore it down 2 weeks ago and ordered a straight edge. The head and block were well within the 0.002" FSM spec in all areas measured, so I did not need to send anything to a machine shop. Also found out the fuel injector o-rings were flaking apart, the EGR ports were completely clogged, and the connecting pipe hose was cut. Did a full gasket kit, adjusted the valves, and cleaned the IACV and intake, now the car runs freaking awesome.
To anyone considering doing a head gasket on one of these cars, it's really not that bad. It's also a good time to clean your throttle plate, intake, and EGR ports, and adjust the valves. I was also able to clean all of the carbon deposits off of the pistons and valves.
Old 03-15-2019, 08:22 AM
NDNV's Avatar
Also good time to do the timing belt service, if needed.
thechad888
12-01-2013 08:56 AM
lexluther
16
01-04-2010 09:51 AM
Hardedge
10
12-03-2007 08:51 PM
sir boostalot
05-25-2006 10:40 PM
Lei Siew Long
05-30-2002 03:32 PM
Quick Reply: D17A2 Blown Headgasket Advice
