Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Used Ignition switch
Old 03-25-2019, 02:30 PM
kathrine's Avatar
Default Used Ignition switch
Quick question my mechanic installed a used ignition switch. The locksmith says it cant be programmed. Is there any way to get ton run. ?
Old 03-25-2019, 07:02 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Used Ignition switch
If you still have the original key just hang it on your key ring. That should work well enough.
If you don't have the original key then go to the Honda dealership with proof of ownership and explain what happened. Programmed key should only be ~ $50.
Old 03-26-2019, 04:33 AM
hondandy's Avatar
https://cimg8.ibsrv.net/gimg/honda-t...a371fb83b8.jpg
Old 03-26-2019, 04:38 AM
hondandy's Avatar
Ya put the old key close to the antennae ring. Dangling from the key chain may work but it could be too far away. Those autozone type replacement ignition switches do come with a non-programmed chip key. But you can defeat this anti-theft measure and box the original key. Or program the new key. I just posted about how I replaced my locks the cheap way. Thread is a little ways down the page.
Barf Hat
10-09-2019 05:45 AM
95lscivic
08-08-2007 01:58 PM
GregT
Acura TL, RL & ZDX
12-24-2006 07:13 PM
EricUSC
11-01-2003 09:38 PM
Quick Reply: Used Ignition switch
