PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Oil leak from spark plug?
  2. 2005 Honda Civic VP 1.7L Spark Plug Wires
  3. 2001 Civic - Won't start
  4. 02 Honda Civic Ex 1.7L - Won't start
  5. 03 Civic dies while driving starts right back up but dies several times
  6. High Beam Active Wire
  7. p0141
  8. No start don't know why
  9. thisguyaves turbo 1.7L build - F you, K series!
  10. 2002 ex coupe 1.7 v tech motor 2001 ex coupe exhaust manifold with cat built in
  11. High capacity fuel rails for 2002 Civic EX D17
  12. Replace alternator cable
  13. Starter problem?
  14. 2002 civic steering wheel removal
  15. Overheating issue
  16. 2001 Manual Click/Pop sound when starting from stop
  17. AC - High side is low, low side is high.
  18. AC warm when idle, cold when driving
  19. O2 Sensor B1-S1 2005 Honda Civic EX SE
  20. Timing belt tensioner bearing starts to fail after only 2,000 miles of use!
  21. AC Starting Problem
  22. 03 Civic Ideas
  23. 2002 honda civic
  24. Cammed stock k20a low performance retainer questions
  25. 2001 Civic EX Coupe fuse box does not match up to the fuses.
  26. 2001 Coupe EX water leaking onto passenger floorboard
  27. AC leaking onto passenger side floor/carpet
  28. 01 civic code P1361 replaced TDS now throwing code again
  29. diff and speedometer gears not meshed
  30. PO131
  31. What size bolt is used on the alternator?
  32. My Civic won’t idle correctly for a few seconds after Start.
  33. Ignition Assembly Help Please
  34. 2003 Honda Civic leaking fuel from drain line in front
  35. civic eu3 cvt problem. please help guys
  36. Honda Civic Coupe LX 2004 oil leak
  37. 02 civic Gauge went to H(hot) but drive normal?
  38. Car alarm
  39. CEL - P0301 & P0302 & P0303 & P0304
  40. Starter bolt size
  41. Power Steering Leak
  42. Alternator or Voltage Regulator Problems?
  43. Hood change
  44. 05 Civic coupe D17 oil leak
  45. Where to buy Alternator used?
  46. Brake pedal squeaks when released
  47. part number
  48. 2006 honda civic engine fit a 2001 honda civic?
  49. Rough idle/Yes I know this has been covered before
  50. Having trouble with 2005 Civic coupe lx..
  51. 2002 Honda Civic EX Weird Acceleration Problem
  52. WIDE RANGE of NGK spark plug choices!
  53. Wheels
  54. 01 LX Civic not charging battery.
  55. SRS connector question
  56. Squealing noise when decelerating and only when in gear
  57. 2005 Civic EX - ECT switch bad after replacing
  58. So I got a 2004 Honda Civic dx coupe and want to swap motors ?
  59. A/C Doesn't Work - Except if Bypassing Relays
  60. Transmission Bad ?
  61. 2001 Honda Civic coupe non-vtec to vtec engine
  62. ac vents wont switch to any mode
  63. Trunk won't lock
  64. 2001 civic clutch master cylinder
  65. 2005 Civic tan/brown spot on spark plugs
  66. 2002 Honda Civic si ( Canada ) intake air sensor
  67. Overheating / Burning Oil / Heat Not Working
  68. Does this look like a burnt exhaust valve?
  69. Steering wheel replacement
  70. 2005 Civic Dx Oil Leak
  71. Troubleshooting: 03' Civic car won't start due to fouled plugs & no ECM access
  72. Knock sensor and pulsing idle
  73. Cluster swap wiring help.
  74. 2004 EX Battery Light
  75. New to honda tech and cars! Questions
  76. Overheated
  77. 2004 honda civic best headgasket ?
  78. 2003 Honda Civic Hybrid 1.3 cannot find the correct pilot bearing. Need help
  79. Power lock won’t engage w/door open
  80. 03 civic ex coupe: seals keep leaking
  81. Honda Civic single power door lock not working
  82. 05 Civic ex
  83. D17A1 engine still runs hot after new head gasket.
  84. 2003 Civic not starting
  85. valve train noise
  86. EM2 Rear disk/replacement
  87. Trunk Won't Close due to Accident
  88. Detailing Engine Bay
  89. D17A2 rattle/buzz on deceleration
  90. What MT transmission do I have? 05 Civic VP Coupe
  91. Honda civic 04 water leak
  92. 2001 Honda Civic lx
  93. Could it be the water pump?
  94. 04 Civic keeps running hot
  95. Buying beater Civic for friend; is this one a lemon?
  96. 2002 Honda Civic ex oil leak
  97. 2002 D17a2 Flapping Noise & Auto shifter issues
  98. 2005 Civic D17A6 Engine Overheating on Highway and Standstill
  99. 2005 Civic Hybrid AC issue
  100. 7th gen Civic clutch and flywheel tutorial
  101. 2002 Honda Civic Overheating + Radiator fans not turning on?
  102. 2005 Misfiring Randomly!!!!
  103. 4g63 swap civic.
  104. A/C electrical issue 02 EM2
  105. OBD port
  106. Best Battery Terminals?
  107. 2003 Honda Civic Hybrid Transmission Issues
  108. Idle air control valve
  109. Coolant bleed valve in 2002 Honda Civic EX
  110. 2002 civic ex oil in wheel well, down running board, and popping sound
  111. rocker arm not engagin clutch
  112. Interchangeable parts
  113. 2001 honda civic
  114. 2003 Acura EL 1.7 - Questions about Temperature Sensor(s) and Readings
  115. 2001 Lx AC issues
  116. Brake failure?
  117. 2003 civic ex door panel
  118. keyless fob programming
  119. Easy Alternator Question
  120. '02 Honda Civic, multiple issues, please help
  121. 05 Honda Civic intermittent starting issue
  122. dashboard brake light is on honda civic 2001
  123. K24 gearbox on EM2
  124. 2005 Civic no crank
  125. 05 civic oil pan gasket
  126. GAUGE CLUSTER NOT WORKING
  127. d17a2 to d17a1 HELP
  128. key stuck in ignition - 2003 civic LX manual transmission
  129. 2004 civic dx auto doesnt shift into overdrive
  130. Honda Civic eu8 2001 D16V1 stalling when it's warm
  131. 2002 Honda Civic won't start
  132. 2002 Civic EX Coil Packs
  133. Transmission control module
  134. motor and trans sap
  135. 2002 misfire
  136. Car will not accelerate pass 50mph
  137. No power to the fuel pump
  138. 2002 Auto D17a2 Power Loss?
  139. Motor Swaps
  140. 2004 Honda Civic Hybrid w/ tranny trouble
  141. Unplugged oxygen sensor
  142. 01 Civic EX AC Compressor going
  143. 04 Civic Ex - possible PCM failure Advice needed
  144. 2004 Honda Civic Starts Then Dies
  145. Cooling Fans do not start
  146. Auto Shift Assembly Troubleshoot '01 Civic Ex
  147. 2005 Civic heater hose routing diagram needed
  148. Clunking noise.
  149. Replacing IAC Valve?
  150. Heater Core Replacement or Not??
  151. 03 civic manual cluster to 05 cluster swap automatic
  152. eld and idle issue
  153. brake upgrade
  154. Lights flickering, whiny sound at idle, voltage fluctuating
  155. Thermostat/cooling system
  156. Possible failing tranny?
  157. 01 civic p1259. Car starts and dies
  158. Civic will not idle
  159. 2002 Civic EX Coupe Trunk Leak
  160. Battery drain-Back up fuse-What to check?
  161. 2002 civic ex wheel question
  162. Bad Thermostat?
  163. 2003 civic Fog Light Install
  164. Ac not working
  165. Is it possible to remove vtec from the ecu
  166. Need help trying to figure out where this oil leak is
  167. struts
  168. overheating, no heat, leaking coolant
  169. 02 Civic EX Relay Click
  170. High Milage 02 Civic Boost?
  171. Acoord 2004 - PO741
  172. What is P1457
  173. Engine Starts Screeching at Low RPM and Continues When RPM is Raised
  174. whining only when AC is on???
  175. 2002 Honda Civic EX
  176. 2002 Civic EX Rear Upper Control Arms
  177. 2002 Civic EX Trunk Light
  178. 2004 Honda Civic Hybrid won't move in gear but will move on jack stands
  179. Head Swap 2002 Civic non Vtec to Vtec.
  180. Engine Swap
  181. Hard time bleeding my clutch. 2002 Civic Lx
  182. check engine light
  183. Oil pressure light
  184. 2005 honda civic SI
  185. Car cranks but won't start, but only sometimes
  186. The cigarette lighter fuse
  187. Vibration / wheel bearing issues
  188. Low Beams don't work - High beams do - 02 Civic LX
  189. 2002 Honda Civic EX Spark Plug Gap
  190. P1768 2002 Honda Civic Lx
  191. 02 Civic ecu
  192. 2001 civic oil pump install help.
  193. 02 ex cylinder head question
  194. installing keyless actuator to 2005 Civic
  195. NEED HELP I AM LOST
  196. 2003 Civic LX Exhaust Upgrade Question
  197. Dealer tried to charge me $128 for 4 spark plugs
  198. Sway bar help
  199. Troubleshooting: IAC and PCV errors. 2003 Civic LX
  200. 2003 honda civic lx
  201. Question about H22 swap in my Civic LX
  202. 2005 HCH Fuel Pump relay location, doesn't match diagrams/photos
  203. 2002 Honda Civic Constant Misfire
  204. 2002 Honda Civic Ex secondary oxygen sensor plug is missing off car
  205. 2001 honda civic ex fan not turning on
  206. Steering Vibration at Highway Speed
  207. Rear Main Seal - Remove Carrier or Not?
  208. Flickering Engine light
  209. 2002 Civic Kick Panel Removal
  210. looking to upgrade
  211. 2004 Honda civic Coupe LX Check Engine P0134
  212. Pinout for a cluster
  213. BMXA SLXA 5 click 6 click ???
  214. opds unit replacement
  215. D17A JDM Air/Fuel sensor
  216. Blue smoke exhaust pipe
  217. How to find engine light fualt codes and where is the blue clip to jump?
  218. HELP P0335 CPS code after new sensor, stuck limp mode
  219. 04 ex sedan 5sp CEL light not working
  220. Loose cable under dash
  221. Overfilling P/S fluid cause a leak in rack and pinion
  222. D17a2 swapped 91 civic hatchback
  223. 2002 Honda Civic ex crank but no start when warm
  224. HELP overheating problem with all new parts
  225. OPDS occupant position detection sensor?
  226. 2002 Civic Leather seats
  227. 01 civic head gasket?
  228. Ajustable end links
  229. 03 honda civic oil in throttle body crank no start
  230. 04 honda civic ex no start after warm up!!
  231. Clicking/Clunk sound coming from front passenger side
  232. Question regarding 2002 Civic LX lugnuts
  233. MIL after VTEC Swap
  234. 2001 Honda civic lx
  235. i want to swap engine
  236. Use EX resonator/muffler on LX?
  237. Transmission broken?? Help me figure out whats wrong 2005 honda civic
  238. 2005 Civic LX Manual - Twitter Noise When Pressing on Gas
  239. Starting issue
  240. 2002 Civic DX Possible Immobilizer Issue?
  241. Speed Limit Dropping To 20MPH
  242. LCA Poly bushing install Q's
  243. Transmission failure
  244. 2004 Honda DX change to HX engine .immobilizer help
  245. Help lost a screw changing the side left mirror on my 01 LX!?
  246. K-series swap 2002 civic lx
  247. 2001 Civic single camshaft: Should I change my timing belt or no?
  248. o2 sensor bypass
  249. No crank no start 2001 Civic
  250. Need some opinions, please!
