- NEW CARD!!!
- No heat at idle?
- new car!!!
- K24 swap in EM2?
- Clear Bra?
- decisions, decisions, decisions?
- Civic RS
- HID's don't work on my ES!!!
- front lip pic request:
- trans
- Sway Bars for 2001 Civic LX 4 door
- suspension and wheels
- paddle shifting for 2004 civic
- Broke off wheel bolt...should I drive it?
- Thoughts on these gauges??
- I found some s2k brake calipers. I need to make em work!
- headlight code for 02 civic?
- Locking lug nuts Ex-Lx The same?
- Might sell my Civic for an RSX!! HELP!
- Odd Idle...
- I had a problem with my factory aero kit and installing fog lights
- grill install
- Looking for Fog Light need help
- Wheels/Tires - Is Bigger Better?
- fuel pump kill
- anything i need to be aware of
- So... think this'll buff out? :(
- Install cruise control
- Changing Grille
- How would I get rid of the yellow corners on my headlights??
- dimensions for em2 and rsx?
- 02 civic ex coupe, door lock and stereo problem. HELP
- what loweing springs are best?
- How do i replace the fuel pump on a 2004 Honda Civic Ex
- Car not cranking...now it does...
- need alilttle help guys
- do I need a camber kit to lower my car?
- Your next Car?
- Coupe vs Sedan headlights OEM
- Can't Open Fuel Door
- Why did you buy your Civic?
- Void Warranty or Buy a Beater?
- Proper Intro
- wheels doesn't turn, but engines starts and reves smoothly... please help!!!!
- hood deflector/visor?
- ctr or itr dash where to buy it?
- 2002 Civic -- "ERR6"
- rear camber kit
- b16 or k17
- Question about fittment on suspension (searched)
- Engine and lights.
- interior change out on em2
- Rear Struts install
- How To raise My Suspension Hight!! Tokico HP suspension
- EM2 interior
- EX catback onto LX
- Cam Gear
- 2004 Honda Civic won't start
- Motor Mounts
- Carbon Fiber Hood Question
- Engine sensors?
- Dash Cluster Lights Going out??
- EP3 Rear seats into an EM2 coupe
- Big Trans Issues, Searched*, Need Answers
- trilogic remote car starter reprogramming?
- Door Actuators
- si door panel to em2?
- Do These Spark Plugs Make a Difference?
- 01-03 and 04-05 Front end question!!!!
- car alignment
- 2005 Civic Service Manual
- Brake question for track people
- 2001 Honda Civic Automatic - RMP Jumps while shifting
- Has anyone swapped a K base model??
- wheel base?exhaust?
- 7th gen grill
- Repairable or just buy new and paint?
- Tire size for 16x7 rim
- 05 civic ex 4dr- spark plug wire replacements/upgrade
- 02 Civic DX Coupe cluster swap
- buying a steering wheel without an airbag...worth it?
- Seized rear shock bolts
- Civic High Output Alternator
- front bearings
- Head Unit install
- difference between d17a2 VTEC and d17a6 VTEC-E?
- Seido-ya brake pads.
- kcari headlight pitures?
- 5-speed swap
- Tire Rotation
- quick suspension question
- slim fans with turbo
- Strut tower
- how much is my car worth?
- zeta wide armrest
- Rear Defroster NOT working.
- My Build Thread
- Suggestions Please...
- need help bout k swap
- decah lambo door kit, what do you guys think
- Radiator and heat issues
- honda OEM steering wheels = direct fit?
- Ball bearing vs journal
- car shaking
- help with megan header/downpipe/exhaust on automatic vp/dx
- Can i put an 05 front end on a 2001 coupe????
- What speaker size will fit my 2004 Civic coupe
- 01 em1 pic request!!!!
- Question about k20Z1 swap into Em2
- all mud guards created equal??
- 01 civic trans trouble code 1753
- 03 EX AUTO QUESTIONS
- Radio Removal
- clutch
- issues with turbo
- Where to find carbon fiber plastic valve cover and titanium finish headers?
- dc5 dash on em2
- Quick Question
- maybe a short somewhere??
- What are the part numbers for these lights/ how do I change them (2002 EX)
- No Brights
- Would this Intake Work?
- Oil Pan Gasket in 2005 Civic LX
- Rear Brake Conversion On ES1
- Security questions with the em2's......Easy to steal??
- engine swap/tranny swap
- 2001 Ex Transmission Pull Help!
- ► For Sale / Wanted to Buy
- do 04 civic dx/lx parts fit for 04 vp (value package)
- Spring, Shocks, Struts
- DIY- 01-02 civic manual cluster to 03-05 cluster swap
- stipped nut
- Remove Headlights???
- Help: Remove Center Console - 2005 LX
- Front Strut Squeeks...Goes away if I lube it
- replace headgasket for new header?
- 05 Civic VP What's the chassis code?
- REAR ENDED BY A FREAKIN TRUCK!!!
- poping noise?
- ingalls front camber / tein basics
- Materials needed to make t25 custom downpipe
- Front wheel drive and balance
- Need advice about manifolds
- custom seat rails
- output converter
- How do I install M3 style LED mirrors on Honda Civic 2005
- trunk weatherstrip
- CAN SOMEONE PLEASE CLARIFY THESE BRIDE SEATS AUTHENTICITY!!
- Installing a Speed Chip, please help?
- LX/DX to EX Head swap question
- help....
- Intake manifold for d16w7?
- cluster question?
- 05 Ex Super AFC Neo HELP
- coilover installation price
- trans swap?
- k20 engine swap.
- Thinking about heading to IA '08 from out west? talk about it here
- where do i buy the em2 deca everyone has?
- Replace Climate / Heater Control Bulbs (oddmut)
- Side Skirts
- Cluster Problem 01
- Looking for some Special Edition wheels
- Gear Shift Lock installed! Take a look...
- need help on the cluster.
- DIY: Driver's Seat Rock (oddmut)
- Replacing some suspension parts
- color coded
- Spend $1500 For Me...
- 02 Civic Si...engine and heeating troubles, replacement of front control arm bushings
- cel light flashing at startup?
- blower motor broken?
- just Bought a new 05 EX
- does a ES1/4/5/6/7/9 suspension fit a 01' EM2
- Tranny/Cluth/Flywheel Questions... 5spd
- m/t gear slipping out. 1st -> 3rd
- maintence required light.
- need ideas for a class?
- Shift Knob Question...
- 550cc injectors
- Sticking/Jumping downshifting between 3rd to2nd A/T
- VTEC in a LX
- slipping out of 2nd gear in m/t
- armrest question
- Power steering
- si rims
- keyless entry programming
- Ckicking noise when breaking.
- Clutch Bypass??
- Battery Problems
- Replacing Power Steering Belt...
- New user, new build, where to start?!
- Radio, alarm and interior lights no longer work after new battery installed
- Question on k20a
- ep3 front seats weight compared our stock fronts?
- Rear diffuser from RSX?
- 04-05 bumper
- '02 HX Tranny (ctv)?
- Stock offset question
- turbo ?
- Need opinons!...
- Factory keyless entry?
- What will I Need TO have a Complete tune up!
- Need help identifing the drop on this car.
- Wat size are my speakers??
- Car Troubles
- I Blacked Out My Headlights
- RSX-S axle back exhaust question.
- turbo for 02 ex
- Front Housing
- Quick post i want to make some Em2 and Es1 stickers any ideas
- NEED HELP WITH KONI SHOCKS.
- Will this cluster fit my 02 4dr dx??
- 01 Honda Civic sedan Performance
- how do i take off front grill?
- Service Bulletin 04-036 -- FYI
- 01 EX Auto.. How many RPM's @ 60 MPH.
- Wiper Blade sizes?
- Used car warranty AUTOSAVE... Anyone use?
- 02 civic ex suspension swap?
- My Build Thread
- Can Some one tell me If this is a stock suspension??
- little help guys
- koni shocks.. or other recommendations
- Megan Street Coilovers VS Koni/GC setup
- Center Console Removal
- locating a dyno for tuning
- Ebay Carbon Fiber Grill VS procivic.com carbon fiber grill
- 2001 civic front hub bearings removal....HELP!!!
- brake pads
- Trouble Getting Honda to Move...Please HELP!!
- EP3 Coilovers
- WHATS YOUR FAVORITE FRONT LIP FOR OUR EM2'S?
- problems with my transmition
- swap question....
- Civic Maintenance
- Best gen7 year to get?
- Tranny clicking
- Heat / Over Heating Question
- Tail Light problem
- SOME OLD PICS OF MY CAR
- Optional OEM Lip 01-04.... How much should I pay?
- my car stuck at parking
- engine and brake questions.
- Got a question about Side Skirts
- What is the best suspension kit?
- Any real honda dealer techs in the house? (Civ Hybrid Question)
- My Build Thread
- Honda TSBs (Technical Service Bulletins)
