Check Engine light with paper clip, 04 civic ex
I have checked every youtube video and looked everywhere on the passenger kick panel in order to read the code without the obd reader. Any help will be awesome!!
Re: Check Engine light with paper clip, 04 civic ex
You cannot do that in the '04 Civic... the 2 pin service connector doesn't exist in that application. You must use the diagnostic port.
If you dont have an OBD II, follow this video with a paper clip and boom it tells you the code. It took me awhile to find a video and yes it does work....https://youtu.be/XzDjDCJ4GiI
So there are pins at the diagnostic port that can be jumped to do the same thing as the older DTC 2-pin connector. Awesome. Thank you for sharing.
johneejumpup
10-29-2004 01:49 PM
