2004 D15b I believe it is a jdm. Need info
Hi, I bought my 2004 Honda civic off my friend. Who bought an engine off I believe Ebay. I went to get some parts and needed my engine type. Which was supposed to start with d17 lol imagine my face when I saw d15b. My question is where do i get 02 sensors that fit. I bought some off Amazon for a d17 but they don't plug in completely and the downstream one is different. Any help would be appreciated
Thanks Tim
Thanks Tim
Re: 2004 D15b I believe it is a jdm. Need info
D15B VTEC[edit]
- Found in:
- 2001-2005 Honda Civic JDM VTEC (Japanese market, Europe)
- Bore and Stroke :75,0×84,5 mm
- Displacement : 1,493 cc (91.1 cu in)
- Rod Length : 137 mm
- Rod/Stroke : 1.62
- Compression : 9.3:1
- Power : 130 PS (96 kW; 128 hp) at 7000 rpm[8]
- Torque: 139 Nm at 5300 rpm
- Redline : 7200 rpm
- Valvetrain : SOHC, four valves per cylinder
- Connecting rod length : 137 mm
- Connecting rod big end diameter : 48 mm
- Fuel Control : OBD2b
- Head Code : P2J-07
- ECU Code: P2J (small case ECU)*** AUTO CVT: P2J-J63*** MT P2J-003*** & ***MT P2J-J11***
- Piston code : P2J
Find an OEM parts supplier and cross reference part numbers between newer D15 and older D15, if they match up then you should have no problem getting parts
