PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. SRS Light, Can i ground it out??
  2. Popping after new LCA bushings...
  3. Replacing intake mani gasket.
  4. can someone answer my question about my civic?
  5. 2001 Civic Manual Transmission ?
  6. 5 stud conversion
  7. 01 DX random "vibration"
  8. P1705 PLEASE HELP!
  9. Clean the intake manifold?!?
  10. Temp gauge fulctuation
  11. all needles shake
  12. 01 maintenance required light on, no cranking
  13. 2001 Honda Civic
  14. 2001 clutch problem
  15. 04 civic project questions D17A1
  16. BUG DEFLECTOR HELP
  17. electrical problem
  18. Wheel Problem
  19. "BRAKE" light stays on dashboard,cruise,central lock,AC not working
  20. k20 swap on 2002 civic
  21. 2004 civic A/C electrical issue
  22. OEM Front Under Spoiler - '04 Civic?
  23. Lower H Brace
  24. Vibrating noise
  25. Anybody know...
  26. Need advice with my coilover problem
  27. cd player code help!!!!
  28. Pulsing while coasting - 2003 automatic
  29. JDM projector lights not working?!
  30. Toe/Alignment Issues with KSPORT Coilovers installed
  31. CEL with increased gas mileage
  32. 2005 Civic LX (Broken alternator bolt)
  33. 2002 Civic leaking oil... need help!!!
  34. Civic 01 EX
  35. HELP PLEASE!
  36. rwd to 4wd?
  37. 03 EX Coupe leaking passenger side
  38. Won't Start on First Crank
  39. automatic transmission questions
  40. Tire Brand?
  41. 2001 civic climate control
  42. civic 01 - 03 side skirt
  43. positive battery cable
  44. 2005 Honda Civic Turn Signal Problem
  45. 05 Civic EX - Crank Position Sensor
  46. 03' Civic wont start, weird buzzing noise help!!
  47. PLEASE HELP!!!!!!QUESTION ABOUT A 2001 SEDAN
  48. Stutters up low grade, 1800-2k rpm, 40-45mph
  49. idle revs up then dies down over and over.
  50. em coupe ?
  51. Turbo Em2 T25 Dyno Tune *Pics with chart*
  52. power always on to A/C clutch
  53. Not pulling in first gear, CEL came on.
  54. Gauge cluster readouts failed
  55. Low Idle
  56. single clunk
  57. Pushing coolant and cant figure out why, please help.
  58. Not Starting
  59. A/C not working
  60. throwout bearing help!
  61. D17 Vacuum issues
  62. Air Conditioning Intermittently Works... Plz Help!
  63. 2001 dx to si(canada) head swap o2 wiring
  64. yet another O2 sensor question?
  65. honda civic 2001 ac not working
  66. 2004 Civic VP idle problem
  67. Extreme NEWB, with a real odd situation
  68. Need U help for EM2 1.7l swap 1.7l Vtec
  69. 1 Fog light went out
  70. Cold air vs Short ram ?
  71. bad noise inside the car
  72. Heater wont work when car Idle - Head Gasket Recplacment
  73. Will 04-05 front bumper fit 03 civic
  74. difference between 98079-5614P & 98079-5514G spark plug
  75. honda civic part help
  76. drivers side door dome light switch?
  77. Is 2003 civic LX bolt pattern 4x100?
  78. 2001 civc lx..brake light still on?
  79. installed camber kit front causing a pull
  80. Civic 01 fog Help !
  81. 2002 code P1259
  82. 05 civic
  83. New member from CO
  84. Torque Spec - Cam Gear Bolt | D17A1
  85. How did you fix your A/C problem?
  86. 105k Service this weekend, parts arrived.
  87. P0730 code in 02 Civic Ex
  88. Clearing an old Code
  89. changing shift knobs?
  90. how do i change the radio system
  91. automatic transmissions interchangeable?
  92. manual trans adjustment?
  93. trade-in or keep???????
  94. New Member
  95. 2001 Civic EX problems
  96. p1298 and p0141
  97. Auto tranny turbo?
  98. Turbo build
  99. Need help ASAP
  100. Please help!!!... My 01 civic is running funny...
  101. trying to gain some hp or looks ideas?
  102. 01 Civic cranks strong, wont start unless
  103. 2001 Honda Civic LX - Sputter and now no power
  104. How much different will ex head swap make and cost?
  105. B20B or D17?
  106. 2002 Civic EX : EGR causing CIL, and I am a dunce...
  107. THANKS
  108. 2002 Civic LX, No Air/Heat
  109. canyon based
  110. transmission swap question
  111. Shift issues?! 04 EM2 anyone have this problem?
  112. bike rack
  113. Questions about intakes
  114. help please. car is hydro locking itself
  115. ***2001 Civic GX transmission help***
  116. want to start some serious building on my lx need help wit a few stuff
  117. **01-05 civic ecu question..
  118. Pls help! Passenger window regulator is not working
  119. 04-05 Sedan Rear Lip
  120. head gasket help
  121. outer tie rod end castle nut size?
  122. 01 transmission...great
  123. What's behind this cover?
  124. 2002 civic ex 1.7 single cam
  125. Door Panel Fabric - What Glue?
  126. aftermarket steering wheel help please!!
  127. Looking Into Buying a 2003 Civic Hybrid 4Dr...
  128. I have a 2002 Civic LX (tranny problem)*urgent*
  129. Cat-less test pipe - 02 CEL
  130. door swap help!!!
  131. I need to ask 2 questions
  132. front lip?
  133. 01 civic LX wont shift from park... yes another one...
  134. Car leaking coolant.
  135. fasteerrr
  136. Header Fitment Help
  137. '01 Civic Starts but Dies After 1 Second of Running
  138. Replacing clutch
  139. potential car theft?
  140. Rattle after alignment?
  141. Couple Gasoline questions?!?! (No Owners Manual)
  142. help me buy a civic
  143. 2002 Honda Civic EX A/C Problem
  144. 01-03 HFP Front Bumper
  145. 01 Civic EX Speedometer/dash not working
  146. help on engine swap 01 ex coupe
  147. Random noise in engine! Help!!!
  148. Cluster Bulb Size
  149. Problems problems...
  150. Crush Washer??
  151. Two interior questions:light
  152. 2001 HONDA CIVIC A/C COMPRESSOR
  153. K20/K24 hybrid swap advantages
  154. UGGG Motor build or swap? again
  155. 2001-2005 civic questions
  156. Humming noise.
  157. Replace head gasket?
  158. 2001 civic 5 lug conversion help
  159. no power in my 02 civic
  160. baron340?
  161. NTC thermostat?
  162. check engine codes
  163. 01 Civic EX Runs on Half Power
  164. both fans stay on?!?!?!?
  165. Don't ever buy GSP axles
  166. DC5/EP3 Interchangeable parts list for EM2
  167. 04 Civic EX Manual Transmission noise
  168. I can't get the rear strut bolt off.
  169. Engine swap
  170. Replace headgasket or entire motor?
  171. Looking for some new exhaust hangers that is longer than the stock ones
  172. Price opinions on Built motor
  173. Possibly getting 02 EX
  174. Sudden jerks to the right - can it be fixed by an alignment?
  175. center console interchangeable???
  176. Help! 2002 Civic EX intermittenly won't start--cranks
  177. swap question
  178. Tranny slipping??????
  179. 05 HCH Fuel door and trunk release latch broken
  180. changing normal civic climate control trim for civic type R climate control trim
  181. New rims and tires
  182. Torn Ball Joint Boot During Wheel Bearing Replc?
  183. Car won't start
  184. A slight rubbing noise after ball joint replacement
  185. Transmission not engaging - '04 Civic
  186. Timing belt 2001 Honda Civic Ex VTEC
  187. Need Help with CEL code
  188. Gauge Swapping
  189. Idle Issues ect. - potential TLDR
  190. crower cams and AEM Fuel & Ignition Controller
  191. Honda dealership recommends axle replacement but no clicking
  192. oil pan replacement
  193. Power Window Problems
  194. Rsx Type S seats
  195. 2002 honda civic controller box.
  196. 2001 civic lx trans problem
  197. Tsunami trunk spoiler?
  198. misfire on my 1.7 V-Tec
  199. VTEC not engaging
  200. Loose lug nut stud
  201. Powerlock / Auto window problem !!
  202. Engine Swap/Trans Question.
  203. valve problem??
  204. DTC codes have me confuse ! any one help ??
  205. Another question about engine noise
  206. I seem to ignore my PM's, and this is what becomes of it.
  207. 2001 Civic LX transmission information needed
  208. mirror help
  209. Vtec Solonoid Problems
  210. compression and leak down test results
  211. metal on metal rattling.
  212. 2003 Civic LX Thumping Noise while Turning Clockwise
  213. Grinding by the starter
  214. Possible Blown Engine
  215. Reasonable labor at local mechanic?
  216. Suddenly terrible mileage
  217. Burning Plastic odor
  218. 04 and 05 ex manual transmission the same?
  219. K24A4 injectors in D series
  220. 03 CIVIC SPINDLE REMOVAL. BROKEN WHEEL STUDS.
  221. 04 Civic ES8, searching idle, quick help needed
  222. ATTENTION Honda Experts HELP NEEDED!
  223. 01 Civic Not Sure?
  224. D17a1-d17a2 vtec head swap
  225. '01 Civic EX Sedan weird noise on deceleration
  226. 2003 Civic EX - oil leaking into cooling system
  227. Polishing D17a2 Valve Cover
  228. Looking to buy new clutch
  229. Maintenence Light
  230. civic question on a k20 swap
  231. wiring universal o2
  232. 01 civic Canadian/Us si Question.
  233. 01 civic rear speakers 2dr
  234. wtf is this!? tranny fluid mixed with antifreeze...?
  235. 01 Civic EX valve adjustment jam nut size?
  236. CHP Vin Verification????
  237. 2004 Honda Civic Engine Issues
  238. 2004 hybrid grinding noises
  239. Wheel Vibrations after transmission rebuild
  240. What trans fits a 2001 civic ex
  241. Reusing oem headstuds
  242. 2003 Civic LX AC not working
  243. Anyone using polyurethane front/rear Engine Mount Inserts?
  244. Get Engine Code Without a Scanner?
  245. ABS Still Doesn't Work
  246. 02 civic LSD DIY
  247. How to Replace Camshaft Plug??? '02 Civic
  248. Tire size request.
  249. 02 ex ecu code
  250. Shifter notchy feel (as designed) how to get rid of
