- 01 integra struts with coilover sleeves on a 01 civic
- Cooling fans not coming on ?
- Z-max
- Need Help!!
- MPG with Cold Air Intake
- 05 Civic LX MT
- d16y8 intake manifold on d17 engine
- 2002 civic lx Major Coolant leak!
- no adjusting valves?
- 04 Honda Civic getting a new key made
- Too much oil in engine from Dealer??
- New to me Civic, keyless entry, random beeps
- rsx side skirt in 01 coupe
- Strange sound from underside of Civic?
- Quaife lsd vd mfactory lsd for d17 tranny
- Will a 2003 Civic EX harness work on 05 Civic EX??
- 01 CIVIC EX WONT START JUST CRANKS 3 CODES P0117 P1361 P1259 - HELP!!!!!!!!!!!!!!!
- 02 LX power door lock issue with aftermarket alarm
- What Are Your Favorite Rims?
- 2002 Honda Civic overheats on idle.
- can anyone figure this out please
- 02 ex, Question on flashing a ECM/PCM that's in limp mode and vtec cyl head codes
- 03 Civix tapping noise
- 2003 honda civic dx 1.7ltr engine rough idle
- brake compatibility
- Excess negative rear camber stock 2003 hybrid
- 02 ex won't rev passed 4000 rpm?
- 2003 civic lx 4dr (Oem side skirts)
- headlights and dome light slightly flicker at speed
- Header Swap (want to avoid the check engine light)
- Check engine light is on
- rsxs - civic em2 parts
- Need Help Slamming
- OEM fog light switch
- 01 civic won't start!!!
- 2003 civic airbag problem
- Key won't turn in igntion
- rearend of car squeaks
- 2005 civic new clutch
- 2001 Civic Wont run?????
- 2001 civic ex electrical issues
- full exhuast system
- 01 Civic SI Heating Problems
- Honda Civic ELD question...
- Idle Problems From Hell!
- brake lights
- 2005 civic dx ac issue
- Leaking fuel line on 2001 Civic
- what kind of antifreeze
- Throttle issue??
- uhh no front sway bar?
- 02 Civic EX Problems
- em2 chassis crap??
- 2001 LX 4 door replacement driver axle too short
- Where can I find one of these, and what is it called?
- car overheating :( someone plz help
- 05 Civic front end noise
- 01 Civic front end noise-Help!
- 2001 Honda Civic Loses Power off and on
- transmission filter?
- how to check lca bushings
- 2001 civic wheels
- ABS Dynamics rs grill honda emblem
- Wiring diagram for A/C
- Hello.. New to HT
- Hello Everyone!
- Transmission installation. Should I take pictures?
- Car wont start, and check engine light
- D17a2 vtec pressure switch help?
- Lighter flywheel
- Need help with clutch master cylinder.
- em2 wheel fitment
- 2001 Civic Overheating issues
- Car overheated please help
- 2001 civic limp mode problem and obd 2 scanner wont link up
- exhaust size
- 2002 honda civic ex idle\ starting problem
- Improper battery connection. Might have caused a blown fuse?
- Handfull of problems
- Decreasing Gas Mileage 2003 HCH
- 05 Honda Civic LX Special Edition Engine Swap?
- Stage 2 crower cam
- My new 01 civic sedan
- wind shield defroster dont work
- o2 sensor replacement
- Engine blown
- 2001 Honda EX Junkyard D17 Swap
- How NOT to install Koni Yellows
- Bug Deflector/Bonnet visor/Protector Question
- Service manual
- Really strange 02 civic ductwork problem
- 2003 Honda Civic Ex wont go over 20
- Grinding from right front wheel, wheel bearing?
- how to install a quick release?
- Diagnostic Trouble Codes Different from P Codes?
- Noise Coming from in my Steering area
- AC just suddenly stops blowing cold air
- D17 Engine with D16 transmission?
- head swap?
- Any full DIY front cross member removal?
- 05 Civic VP Upgrades
- 2002 civic sputtering/hesitation
- 2001 Civic -- cylinder misfires
- 2005 si-g head gasket nightmare
- 01 civic AC lines iced up with heat on in winter
- Passenger side airbag delete tray
- new here have an 04 civic vp
- Instrument cluster circuit board burnt wires
- 05 Civic JDM swap- Few issues, need help!!
- Steering/vibration, detailed description please help.
- Erratic speedometer - VSS?
- Rear windshield shattered - aftermarket OK?
- 2001 civic ex 5 speed mpg issues
- Coupe 03 A/C problem | Noise SuperCharger
- 05 civic 5 lug swap with DC5R rear knuckles.
- Dim headlight problem.
- rattling/creaking in lower control arm
- Just installed upgrade sway, hearing knock noise
- 03 Civic hybrid to 05 civic conversion
- 2001 honda civic transmission
- What's the recommended oil type for my Acura EL 2001
- n/a d17a2
- Evap 0497 code
- Public THANK YOU for moderators and Admin's. Please post YOUR thanks also.
- If you could change your suspension....
- URGENT: trouble removing wheel hub
- problems with idle after swap please help
- search FAQ's, engine swap result is K20 stuff, need R&R steps
- Car revs dont go up more than 3k!!
- Will 2002 EM2 stock font lower control arm fit 2002 RSX base?
- Trickle Charging Through Cigarette Lighter
- Civic 2004 si very bumpy??
- Hona civic lx 05 stock need some more HP!
- eBay alarm install
- em2 turbo winter beater whatcha think?
- 02 EX Error codes VSS, gear ratio and emissions
- Strange problem with radio..
- I'm Purchashing a Revo Racing Short Shifter and shifter bushings
- 2002 honda civic 1.7 won't start
- A/C No longer Blowing
- Having keyless entry issues...
- Turbo setups for a k-series
- ACURA EL 1.7 NOT DRIVEABLE...NEED HELP PLEASE
- Vtec engine in my lx causing issues or ok?
- problem with starter
- 2004 Honda Civic DX Engine Noise, Need ideas before i go to a shop!
- 2001 Civic won't rev past 4,000 RPM's every 3,000 Miles
- Engine noise/vibration
- How to dissemble Ignition lock cylinder
- D17 swap for Type-R
- rebuilt trans
- how to install a transmission cooler
- 02 ex stock exhaust question
- P1259 code but CEL goes on and off
- 2001 honda civic LX transmission problem
- 2001 honda civic ex 1.7 trouble!
- radio fuse location
- 2001 Civic - Temp gauge behaving weird
- D17 Engine swap..
- 2001 Civic Coupe Transmission Problem
- Colored lugs?
- ECU Problem - Difference between ECU model
- civic 2001
- Instrument cluster bulb size?
- Windshield spray nozzle-Mist pattern type for ES1
- EX Head on GX Short Block?
- gas leak smell from the rear problem
- where to find a rebuild diagram for a auto transmission
- Urgent: just got a 02 Civic uk from dealer does not start !
- 1flyex em2 build!!!
- 2003 Civic Coupe SI (Canada) ECU problem with car in USA
- Transmission compatibility..
- Fuel economy: is this normal?
- 2002 Honda Civic new seat/rails? I'm too tall
- 2003 Civic Ex Running light problem
- 05 Honda Civic blown Radiator
- torquing nuts
- Wont go over 4000 RPMs in any gear
- Cold Air Intake, Exhaust, etc.
- replacing lower control arm bushings
- 01 Civic w/ Type-P Interior
- Drivers door lock will not unlock or lock from inside.
- Anyone install small square race car style door mirrors on their 01-05?
- please verify what motor this is
- how can i get this low?
- Vtec Questions
- 02 civic Vtec malfunction to TDC sensor codes and Cat converter codes
- aspec sideskirts
- Squeaking relay. Nostart no crank
- Civic 2003 door keys
- Weird Noises. Need help solving
- knock sensor location
- r18 swap into 2001 civic lx???? Please help
- ebay jdm fogs brightness questions
- 2002 EX fan not working
- Black LED Tail Lights???
- Overheating Problem Solved 2003 Civic Vtec
- 01 Civic LX AT Starting Issue
- ENGINE SWAP?!
- ELECTRONIC LOAD DETECTOR HIGH VOLTAGE
- Passenger side door lock not working!
- P0497
- has anyone installed an oil cooler ?
- Looking To Do Some Minor Interior Upgrading
- Check Engine Code Help
- Starting problems after removal/installation of FI ECU fuse
- HID headlights, help!
- Possible bad throwout bearing
- how to remove the reflector thing inside the headlights of a 2001 honda civic
- 01 Civic Engine Replacement question
- Civic Project
- 2003 Civic LX Keyless Entry Install after previous alarm removed
- Quick release problem!! Help!
- Surging idle searched help before I lose it :-p
- Hood Latch
- '02 model timing belt replacement
- head swap question
- 2002 Honda civic makes scraping noise in gear with no gas
- Honda Civic 2001 Radio
- honda civic 2003 dont start
- P1457.
- Removing panel to get at SRS fuse
- Replaced/Changed Head Gasket. Still Leaking Oil
- Looking to buy 2002 Civic EX 5-Speed
- blown transmission and differences between the others transmission of the em2
- Window Glass Replacement Issues
- 2001 civic ex
- Car wont start
- roof rack advice
- fuel pump placement?
- Car Won't Start?
- check engine light
- Pulled Trans Now What?
- Welded/locked diff
- Weird Speedometer Problem / Head Unit
- 03 civic ex overheat/transmission problems won't start!!!!
- Has anyone ever heard this sound coming out of their car before?
- 2002 Civic EX Noisy 5spd
- New to HT
- error code P1433 - battery modulator
- all d17a(x) motors are stamped d17a how to differentiate?
- Battery Light FLickering at higher RPM's
- no heat
- Three Dead ECU's 2003 Civic
- EDM mirrors...HELP
- Replacement motor options 2001 EX
- sway-bar issues
- hood stuck shut on my em2. ideas how to get it open?
- '03 LX cooling issues
- Does this sound right?
