- 01 Civic Ex Coupe..... Switch to leather?
- 01 CIVIC SEDAN PICTURE REQUEST
- HELLLLP!!!!! PWR window PROBLEM!!!!
- How hard is it to piece together a turbo kit?
- Clutch Grinding Noise HELP!!!!!!!!
- Fuel management
- lights
- Brake Fluid
- 01 TO 05 CIVIC CAR CREW STARTING UP IN LOS ANGELES COUNTY
- WTB: Honda Alloys!
- Turbo Pistons
- do civics allow more outside pollution into the cabin?
- 04 EM2 questions
- Just bought an ingalls camber kit
- Oil Gush From Behind The Motor When Cranking
- racing seats
- Accessroy Slot doesn't work
- DRL module removal.
- resistor?
- Intake/Gauge Cluster/ Work Yes or no? PLZ help
- 2002 Civic a/c compressor not running
- any one know of a good turbo kit?
- Automatic Transmission fluid change
- 2004 Civic Brake Problems?
- What should i do next?
- nitrous TPS
- Update on my Lambor..... uhhhh i mean civic
- 05 civic lx (noob question)
- Quick 2003 vs 2004 question
- How hot does an exhaust manifold get? Mine is cracked and I just want to do a quick fix until I get
- ITB
- Hubs from 4 - 100 to the 4 - 114.3
- k-series swap info
- URGENT: How to remove/install the valve cover on a 02 lx
- Turbo kit with Auto-Trans??
- whats next
- 04-05 owners... Tein basic + upper mount??
- Yum! I've got a torque-sandwich!
- Megan Coilovers... feedback??
- B series in 2002 civic?
- 05 bumper on 01-03 Coupe
- Castrol Edge Sport 10w60
- vtec engagement point
- What is the best online source for buying genuine Honda Parts, with out outrages S&H Charges?
- Will this intake fit???
- redo-ing wheels, redid calipers/rotors
- How do you replace the headlight assembly on a 2003 Civic EX?
- maintenance required light
- eibach pro kit?
- chrome exhaust trim
- Blinking Battery Light
- TSI turbo
- Seat Bag Warning Light
- Post you Action photos here
- Vtec controller
- EM2 Shoot at IA... 56k no no.... This picture is huge lol
- ECU Chips??
- Factory performance kit for '03 Civic EX?
- what car are these from and what are they worth?
- Sooo I replaced my brake pads...
- how much boost can d17 handle
- Civic running too rich
- Amsoil 5w 30
- do you have EM2 OEM lip kit?
- Cat and O2 sensor
- Lowering/Drops Pics
- DIY- How to Fix, AC power transistor
- my plan w/ my car..
- trip odometer ........
- Supercharged A3 in an EM2... feedback??
- Automatic Transmsission Drain Plug is really tight
- Honda Warranty on Brakes?
- GLOW GAUGES HELP INSTALL
- cluster change...k20 swap....miles change???
- k20a2 type S swap????
- where to buy gauges?
- 03 civic tie bar fit 04 civic
- Oil Leak - Help
- Need help finding the right tire size for my new wheels.
- Pulse Plugs
- cracked exhaust manifold
- new exhaust
- I have a bomb attached to my seatbelt... wtf???
- Wheel Help
- WTB 2001 Civic EX Auto Transmission
- Tire Issues
- oem lip kit?? help
- need help!!!! clutch squeak
- tires
- Cluster Swap
- 01-03 tail lights on 04 EM2
- 04 Hybrid problem
- car stalls
- what lip is this?
- Website for OEM Parts
- em2 steering wheel emblem help
- WTB:01-03 cleared headlights
- 16" rims on front and 17" on rear.
- Honda Civic Type R from Mugen - COOL design
- O2 Sensor
- Friendly "Your Top 5 EM2s from Honda-Tech" Topic :)
- Cv Axle problem??
- Will the front clip from a 2001 LX fit a 2003 Ex?
- Invidia Exhuast owners
- ac prob
- Vacuum leak or charcoal canister which is my problem?
- Where can I get factory gauges from?
- Exhaust Help
- grounding kit/headers, are they worth it?
- 2003 Honda Civic overheating and radiator has muddy substance
- FAQ: Lower Control Arm Socket
- 5spd Swap Worth It? Please Read
- 2 door or 4 door
- Power Window Conversion
- Someone please help me!!!!
- civic electric window
- radio clock blinking...
- New Deck. Need a better faceplate
- 2004 Civic EX - Water damage due to dehumidifier backup
- painting interior
- light wieght radiator???????
- import alliance
- If you HAD to choose what would it be?
- blacking out head lights
- New Seats + New picts
- Blower Motor Stopped Working! Need Help!
- Touch Up Paint
- before/after, junk yard hood detailed
- 2001 Honda Civic Car Deck CODE
- Air conditioning; Where do you put the frion in a 2002 honda civic
- Drag racing vid of my DX
- coil packs
- Which brake pads you can recommend?
- local shop in illinois
- Si Seats
- 2001 civic ex coupe power doorlock actuator R&I?
- Need help?
- 2001 Civic EX problem
- more engine noise muffler
- OEM Gauge Replacement
- Where can I get a turbo kit that keeps the catalytic converter?
- Had this printed today for dub show....
- painting my rims today.
- im new here and need help
- Civicforums.com Down?
- retro fit
- RSX-S Stock Muffler for EM2?
- 01' LX exhaust system.......????
- Well im new here
- 2001-2005 dx header
- vandalized
- Transmission Cooler
- Radio Code
- another newbie question: 04 civic gas door and trunk lock issues
- Japan turns off their engine at red lights, should we?
- A/C water leaking into passenger side floor area HELP
- B16
- 2003 honda civic brakes!!
- Looking for experienced answers for
- GC w/ Tokico D-Specs
- i was being a noob....
- engine light caused by intake
- I am a shox.com whore.
- Here's some pics of my 02' DX in the wet
- how much boost can handle
- Advice wanted about trading my 2001 lx civic for a 1997 ex civic with half the mile plus 2300 cash!
- ANYONE HAS PICS OF THERE CAR ON WHITE P1s
- Fujita CAI Installed!
- Baltimore/ DC/ NOVA
- Aftermarket steering wheel help
- radio removal?
- Removal Instructions for Civic 2002 Door Panels
- vtec controller
- Hollow/ Adjustable sway bars
- water in engine?
- new member got a couple questions
- Wheel or Tire Problem
- turn signals
- HIT & RUN!
- EX header swap.
- so my friends bought an ebay grounding system...
- Where should I go for Acura EL parts?
- Help with 2002 Turn Signal Bulb Replacement
- Spark plug wrench size, etc.
- What Color GT3's
- shock questions.........
- help me!! climate control lights.
- Tire Size ???
- Hood Release Cable..
- Best place to shop for clutches?
- Extended Fuel Rail?
- Some new picts
- ES Tuning Muffler
- air intakes on ebay
- Tachometer
- first time lowering
- transmission fluid brand
- what is the weight of insight wheels
- Crank Pulley Torque spec for 2002 Civic EX
- ***2 EM2s Photoshoot
- which are better?
- KYB GR-2 issues (Acura = Honda? Pic attached)
- finally finshed my hid reto
- fog lights!?
- belt problem....
- civic 2006-07 steering wheel
- Crack whore ruined whip
- Another sway post.
- Position of Hangers on EX-LX
- S2000 Steering Wheel for Civic2005?
- coilover question
- How do I take my tail lights off?
- Looking for a EP3 stock hood?
- powersteering pump gone bad?
- brake pads
- Intake for 2003 si??
- LOOKING FOR honda civic 2004 si HOOD stock?
- Nitrous guide
- A/C Problem...need help
- Turbo and cam...
- front rims turn black
- Check out this beauty...
- sincro's for tansmition.....easy fix????
- pulley kit from AEM and hp gain
- Redline of 2002 Civic
- THROTTLE BODIES
- Adding Second Cigarette Lighter Socket
- got into an accident
- check it.
- painted the mugen lip
- d17a2 valve cover custom powder coat
- Buying 2004 civic, timing belt question. Someone please help.
- Struts are gone need advise!!
- K20a3 in EM2
- Drum to disk
- Major brake and control arm assembly question
- Wheel mounting: Hubcentric
- EP3 Civic Si Info/Facts/Specs
- question about coverting a D17A1 to a D17A6
- Rplace engine air filter
- 2000 honda civic si
- new member 1st car and curious
- I need to know Will skunk2 EP3 full coilovers fit my 2001 em2
- Recomand new Exhust
- camber kit
- 02-05 CIVIC SI engine specs
- airbag light
- rims on inca pearl??
- solo 2 video
- Help-fuel gauge problem
