obd1 gsr swap problems need help!
Old Oct 26, 2012 | 07:31 PM
kfol215's Avatar
Default obd1 gsr swap problems need help!
ok so i bought a 96 ek hatch with a gsr swap when i first got it i noticed it had the wrong ecu in it (p75) i switched that out with a p72 i drove the car and when i would floor it, it would break up and not go anywhere but if i ease into the gas it will go. the car also will not hit vtec. the previous owner wired a rsx gage cluster in it the rpms are the only thing working. i check my plugs and they are fouled out...i changed my plugs took it for a ride and it fouls out...i changed the map sensor i checked the wires and i noticed it had a ls distributor i dont know if that matters but i changed the cap and rotor anyway now the car will not start!
any help please let me know
Old Oct 26, 2012 | 09:15 PM
ED3 SEDAN-GSR's Avatar
Default Re: obd1 gsr swap problems need help!
I had the same issue with my gsr in my 91 civic. It sounds wierd but i had two vaccum lines wrong. I reran them and it instantly stopped fouling my plugs. I just googled obd1 gsr vaccum hose diagram. As far as the distributor goes, get one for a gsr. As far as i know u need a vtec dist. For a vtec motor. Hope this all helps
Old Oct 26, 2012 | 09:52 PM
kfol215's Avatar
ok ill check the vaccum lines in the morning and let you know thanks!
Old Dec 8, 2012 | 07:24 PM
kfol215's Avatar
alright so i got a conversion harness for the new obd1 distributor put it on adjusted the timing on the dizzy checked my engine timing the plugs arent really fouling out anymor but I cant punch the car or it will just studder and break up if i ease into it the car will go but anything punching over half throttle the car will break up any suggestions?
Old Dec 10, 2012 | 04:39 AM
mtber's Avatar
Is your check engine light on?
If it is, check your codes & resolve them.
Old Dec 17, 2012 | 06:09 PM
maplemaf's Avatar
check your code
Old Dec 19, 2012 | 05:36 AM
MitchELL.C.'s Avatar
Check all your basics first, a lot of the time is something simple.
If you have any codes resolve that first.
Old Dec 19, 2012 | 03:14 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Ls distributor works, just all the bolt holes won't line up.
Old Dec 28, 2012 | 06:17 PM
kfol215's Avatar
so i bought a new dizzy no vaccum leaks i had a cracked manifold put a new manifold but i still cant press the throttle more then half way with out the car like choking or missing any suggestions?
Old Dec 31, 2012 | 05:24 AM
kyden's Avatar
check codes. this has been stated a million times.
Old Dec 31, 2012 | 05:42 AM
outage's Avatar
Check the fuel injectors. One might be bad.I had the same problem with my gsr swap and I found that one injector was cracked.
Old Dec 31, 2012 | 06:14 AM
outage's Avatar
Check the fuel injectors. One might be cracked making function improperly.
kickinneon
Oct 9, 2011 11:29 PM
DA STRIKER
Mar 2, 2011 08:48 PM
IntegraLS90
Apr 16, 2008 12:20 PM
BoostedVtecGsr
Apr 30, 2007 08:49 PM
90HFCrX
Jun 9, 2004 09:20 AM
