tps and mil light
Old Aug 31, 2012 | 06:55 PM
siguy2k's Avatar
Default tps and mil light
So i calibrated my tps in neptune as it was only reading to 66%. Now when i go above 96% the check engine light comes on. Any ideas? Thanks.
Old Aug 31, 2012 | 07:19 PM
mtber's Avatar
Default Re: tps and mil light
Double check that your tps's mechanical calibration is at .45 volts at 0% throttle and 4.5 volts at 100% throttle with the key on & engine off. (Probe the middle red wire with a multi-meter).
Old Aug 31, 2012 | 07:37 PM
siguy2k's Avatar
Gotcha. I take it its adjustable where it mounts? Will do that tomorrow. Thanks.
Old Aug 31, 2012 | 08:48 PM
mtber's Avatar
Not from the factory. The factory uses rivets to keep it in place.
I am assuming you are using an aftermarket throttle body.
Old Sep 1, 2012 | 06:49 AM
HRTuning's Avatar
Already responded on my forum, but this will be good for others who see this. When using NepTune if the engine is off and you push the throttle down all the way you can check your codes as if you jumped the service connector.
Old Sep 1, 2012 | 09:18 AM
spAdam's Avatar
Loved
Community Favorite
Didn't realize that was what that was for. Cool feature.
Old Sep 2, 2012 | 10:45 AM
HRTuning's Avatar
Thanks. Makes it easy to check codes.
random2008
Honda Civic (2006 - 2015)
Jan 13, 2019 11:31 PM
ReillyEK
31
Jun 6, 2013 08:20 AM
19_hatch_93
Nov 23, 2008 07:08 PM
dc2integtypR
Oct 5, 2005 11:02 PM
trbob16a
Jun 23, 2002 10:52 PM
