tried to remove pin from ecu connect...
Old Aug 8, 2012 | 01:10 PM
AH419's Avatar
Default tried to remove pin from ecu connect...
In the middle of a mpfi swap and went to de-pin c1 wire and accidently pulled out the wire and not the pin. Now i need this c1 port to finish this project. How do i remove this pin?
Old Aug 10, 2012 | 03:27 AM
blackEXcoupe's Avatar
Default Re: tried to remove pin from ecu connect...
You will need 2 or 3 very small picks and a super bright flash light to look in the backside of the clip, and actually see the tab holding the pin. You must have been pulling on that wire pretty hard for it to pull out. Once the tab is located, depress it with a pick and the pin should come right out.
SCMFOX
Dec 21, 2017 09:16 PM
racerock
Feb 28, 2011 04:58 AM
steve0unce
Nov 19, 2004 09:48 PM
FourthGenHatch
21
Apr 17, 2003 04:35 PM
Mikey3000
Jul 7, 2002 04:53 AM
