intake length tuning.
Old Aug 8, 2012 | 09:36 PM
raverx3m's Avatar
Default intake length tuning.
how can i find whats the best length and diameter intake that would work for my engine.
i looked online and asked few people( emailed evans tuning) but no resuts.
i need to know before i retune my engine so i can have a better matching intake than b16 ebay pipe that i have.
Old Aug 12, 2012 | 04:38 AM
josephcmiller2's Avatar
What is your setup? What RPM do you want peak torque? What is your max RPM?
Posted from Honda-tech.com App for Android
Old Aug 12, 2012 | 04:41 AM
Oops, read it wrong. You want to know that tube length. Testing on the dyno is best. Trial and error.
Old Aug 12, 2012 | 05:36 AM
shipo's Avatar
Default Re: intake length tuning.
What are your goals? Best mid-range torque? Best horsepower output at WOT at redline? Best torque off the line?
As a general rule you can have all of one of the above and maybe some of a second (unless you're using forced induction, then the rules change a bit).
Old Aug 12, 2012 | 07:29 AM
raverx3m's Avatar
not very specific just want to know if theres a formula or something or whats the general rule of thumb on this? same as intake manifold runner size or different?
but in this specific case i want to up that curve between 6500 and 7500 rpm on my engine
its a gsr motor p30 pistons and bc3+ cams with skunk2 intake manifold
Old Aug 12, 2012 | 07:32 AM
raverx3m's Avatar
heres the intake pipe im using with v stack and k&n filter
Old Aug 12, 2012 | 02:49 PM
There was a thread on the general approach to this a while ago. IIRC the intake tube lengths ended up being fairly long. Probably at least 50% longer than what you're showing there. Take a look at this:
https://honda-tech.com/forums/honda-prelude-4/%2A%2Acalculating-intake-manifold-runner-length%2A%2A-get-out-your-vtak-calculator-yo-1963201/
Old Aug 12, 2012 | 05:02 PM
spAdam's Avatar
Loved
Community Favorite
He's talking about the actual intake tube, not runner length. Regarding manifold design, there are several sets of equations that will get you in the ballpark if you know what you want the engine to do and what rpm you want it to do it at. They all require trial and error to really get it nailed down though, unless you have access to something along the lines of Ricardo Wave.
dtran
19
Jan 25, 2012 05:53 PM
Devious951
18
May 17, 2007 10:21 PM
IheartHondas
Honda S2000
23
Apr 14, 2005 11:08 AM
gelocin1216
Jul 27, 2004 11:03 AM
Bluephatch
20
Jun 23, 2004 12:54 PM
