placement of the IAT sensor
Old Aug 31, 2012 | 03:54 PM
flangemastermike's Avatar
Default placement of the IAT sensor
Just wondered if anyone had experience with moving the IAT sensor to the boost pipe rather than the intake manifold.
Im mapping a turbo b18c just now and after a hard run and coming to a stop the heat soak is effecting it , i have adjusted the IAT correction tables so it doesnt cause it to run lean.
But how much difference does it make moving the sensor?
Old Aug 31, 2012 | 06:11 PM
xenocron's Avatar
Default Re: placement of the IAT sensor
Quite a bit really, moving it about 6" in front of the TB would be the best.
Part of the problem though is that the Honda IAT is quite slow in response since it is a closed element
Old Sep 1, 2012 | 10:25 AM
EF9_TryMe's Avatar
What exactly do you mean the heat soak is effecting it ?
Are you doing WOT runs and shutting the car off to check plugs or something ?
Old Sep 1, 2012 | 11:21 AM
no no , just if you have been on boost for a bit or racing and come to a stand still you done have the same air flowing into the engine bay, the intake manifold gets really hot, i mean with the manifold holding heat. but you can touch the boost pipes fine.
Not a problem as every car is like this , i just mean from a tuning point of view what would be the best practice.
More accurate sensor in the boost pipe..
Old Sep 8, 2012 | 08:14 AM
.dave's Avatar
i HAS questions ?
What engine management are you using?
Do you know if there are ignition trims based off of the IAT sensor? Its been years since I messed around with the S300/Neptune software, but I remember there being a scaling/table for IAT/fuel in there.
mike93eh2
Sep 1, 2011 09:56 AM
xxdevilzeroxx
Engine Management and Tuning
Oct 21, 2009 03:01 PM
pjr710
Apr 3, 2009 08:25 AM
graftuner34
Apr 15, 2008 05:09 PM
KamikazeSol
Nov 20, 2003 03:11 AM
