i need a base map for my ls vtec
Old Oct 1, 2012 | 12:52 AM
ej1bullet's Avatar
Post i need a base map for my ls vtec
hay guys im new to honda tech i just built my motor and will be runing a po6 ecu i also purchasing a moates ecu vtech kit also thare chiping kit .i will be chiping it my self dose any one have a base map for a ls with b16 pistons and b16 head port n polish , type r cams, type r valve spring, suppertec hi compression valves skunk 2 port polish manifull and str 68 mm trhotel body thanks for your help
Old Oct 1, 2012 | 04:39 AM
jdmadam's Avatar
Default Re: i need a base map for my ls vtec
What program do you need a basemap for?
I will assume you are talking about crome.
You can have one custom made to you setup here----> http://www.xenocron.com/custom-basemap-file-p-56.html
Or you can probably find something useful here----> http://www.xenocron.com/bins/
Old Oct 1, 2012 | 04:45 PM
ennah's Avatar
Your going to need a Moates Burn2 if your going to burn your own basemap. PM your email address and I can send you a basemap if you dont want to use one of the Xenocron bins.
Old Oct 4, 2012 | 12:14 AM
ej1bullet's Avatar
yes chrome
Old Oct 4, 2012 | 12:16 AM
ej1bullet's Avatar
yes i have a moates burn2 pm sent thanks so much
Old Oct 4, 2012 | 02:48 AM
ej1bullet's Avatar
pm sent
550whpcivic
Engine Management and Tuning
Feb 26, 2010 06:01 PM
jdragon1974
Nov 9, 2009 05:48 PM
shocker911
Apr 6, 2009 03:48 PM
chu77
Sep 28, 2006 07:28 AM
DSRxMilogen
Jun 27, 2005 12:49 AM
